BEARCAT Engine Water Pump Parts
Posted: Wed Apr 10, 2024 4:22 pm
What is a source for a water pump repair kit for a Bearcat engine?
A boating forum for Boston Whaler boats and Marine Electronics
http://continuouswave.com/forum/
The long history of how Powell Crosley's 1940's engine became the 1970's Fisher-Pierce BEARCAT engine is described in rather good detail in the article already mentioned and linked above, which has been available for the past 23-years on the website. I think anyone interested in the BEARCAT engine history would benefit from reading it.frontier wrote:Some, if not all Homelite - Bearcat outboards used Crosley engines.
With regard to a replacement water pump, I suspect that a water pump intended for automotive use with the Crosley engine might not be appropriate for use in the BEARCAT outboard version. Typically an outboard engine water pump would be in the gear case assembly, and a gear case assembly would not be something manufactured necessarily by the original manufacturer of the engine, which in the case of a BEARCAT engine was an automobile manufacturer. For example, when automobile engine manufacturer Honda began to produced outboard engines, I think they initially used gear case assemblies made by another outboard engine maker, Mercury Marine. Honda is mentioned has having stopped using Mercury Marine gear cases in c.1998. Cf.:frontier wrote:Check vintage Crosley automobile parts suppliers for engine parts.
