posted 09-27-2001 09:13 PM ET (US)
Joe - you will notice on the '85 console that the instrument panels are very vertical, and almost impossible to read standing up. In 1986 they eased these back, to the design still being used on the current Montauks. So check that out and see if you like it.The Reversible Pilot Seat, an extra cost option, would be a plus, since you then have the luxury of putting either a cooler seat or extra fuel tanks under it.
Check out the condition of the factory twin cable steering. These often went bad and was not a very good solution. Hydraulic steering would be a plus.
The engine you couldn't give me, but that's my prejudice. The probable reason for a new powerhead was a VRO failure, common to mid-80's OMC's, so check out that system. You may want to disable it and simply pre-mix. Value the engine at about $1000 toward your purchase. And look at how clean and free of corrosion it is. A dirty, corroded and crudded up engine exterior usually indicates that boat wasn't kept very well also. The hulls are easier to detail and clean up for selling than an old engine is! OMC's paint jobs back then have never been very good at surviving the elements, so don't expect too much in engine appearance.
But if this old engine really looks good and polished, it's safe to assume the guy took good care of the boat also.
Check the trailer carefully, not only for it's mechanical integrity, but for keel roller support. If it is an all bunk trailer, carefully check the sides of the hull for undulations. These indicate improper hull support by the trailer bunks.
A lightweight 18 is much less susceptible to this than a much heavier 25, but I've still seen it. This type of damage is almost impossible to repair without fairing out the entire sides of the hull and re-gelcoating. If the trailer is not of the keel roller design, try and determine if keel rollers could be easily added, which you will probably want to do at a later date. If not, consider the value of the trailer quite low in your offer. If it should happen to be an Easy Loader style "roller cradle" type trailer, dont' buy the boat - period. The hull will be damaged and possibly delaminated on the bottom. Many whalers were sold by unscrupulous or un-informed dealers in the mid 80's with these not-recommended trailers.
Look at the condition of the teak, but don't be put off if it's grey and badly weathered, or treated with that orange Sikken's stuff. Just assume you will have to orbital sand it to bring it back.
The front cooler seat should be an old style Igloo 86 qt model. These didn't hold up as well as the newer designs, so it may have to be replaced with a new 94 qt model.
Open up all of the round floor plates, and look at the condition of the fuel hoses and tank connections. It's safe to assume that if not previously replaced, you will have to do that, as 1985 boats did not have alcohol resistant lines and they are probably getting mushy. This is an expense you will have to do.
And finally, put your finger into all of the through hulls, feeling for ones that are corroded out. If so, there will probably be signs of leaking or corrosion where they exit the hull, indicating water intrusion into the hull at these points. These can be a pain to replace.
The boat came with a genuine BW tan battery box. Is it still there?
Is any canvas factory original Mills, or is it aftermarket junk? Same for any boat covers.
How oxidized is the gelcoat? And are there any signs of serious hull repair? Lack of bottom paint is a real plus, as it often covers up a multitude of previous sins. So be careful there.
Any of these suggestions would apply to the 20 you're looking at also.
Good luck with your purchase.
