Topic: Evinrude XD-100 Oil Retail Pricing and Other Costs
JayR |
posted 05-28-2006 08:46 AM ET (US)
[Does Bombardier sell their branded oil products like XD-100 at retail outlets other than dealers?] It seems at this point that getting it from my dealer is my best bet at $30 a gallon. Where's the best deal? What price are other retailers charging?
crabby
posted 05-28-2006 09:34 AM ET (US)
My dealer sells it in bulk for $26/gal but it is likely a long haul just for oil from RI. |
posted 05-28-2006 11:37 AM ET (US)
The XD-100 oil is mixed with the outboard fuel at a ratio of 1:100. Thus, you will use about one gallon of XD-100 per 100-gallons of fuel. Let's assume gasoline costs $3/gallon. What effect does the price of XD-100 have on the cost of the boat's fuel?For each dollar per gallon of savings on the price of XD-100, the effect is to reduce the fuel cost by 1/100-th dollar, or one cent. Given the $3-gallon cost for fuel, a change in the fuel cost of $0.01 is a change in percentage of the fuel price by (0.01)/3 = 0.3 percent. So every dollar saved on a gallon of XD-100 oil reduces your fuel bill by 0.3-percent. The government figures it costs over $0.40 per mile to operate a car, so you probably do not want to drive too many miles looking for the lower priced XD-100 oil. |
andygere
posted 05-28-2006 12:59 PM ET (US)
My not-so-local dealer gets $38 per gallon! Needless to say I'll be looking for a cheaper source. |
JayR
posted 05-28-2006 04:14 PM ET (US)
Jim, all I know is that it adds an additional 30 to 38 cents to each gallon of gas. At $3 a gallon, that .30 is an additional amount that I don't like so much. I would buy a large quantity of oil if the price reduction was reasonable. Oil does not go bad...... It does however, get more expensive with inflation. BTW... the first 20 hours on the motor will be at an increased ratio of 50:1 It adds up..... |
fourdfish
posted 05-28-2006 08:24 PM ET (US)
JayR-2hrs over 2000rpms not 20hrs of breakin. Seahorse cleared that up awhile back! |
fourdfish
posted 05-28-2006 08:32 PM ET (US)
Sorry- It is 2hrs over 2500rpms. |
JayR
posted 05-28-2006 10:22 PM ET (US)
Not according to what my dealer told me.....Does it mention it in the owners manual? If so, I missed it. I'll look once again. |
fourdfish
posted 05-29-2006 11:22 AM ET (US)
JayR- My dealer told me different when I bought mine in Nov 04 also! However, Seahorse has said several times that the new engines are programmed for the 2hrs above 2500rpms and I believe him. Not all ETEC mechanics are created equal. Mine admitted he was not an expert on ETECs. I could not find it in the manual. |
posted 05-29-2006 09:34 AM ET (US)
The expense of two-stroke engine lubrication is borne incrementally as the fuel is used. Thus, as Jay notes, it adds directly to the cost of the fuel, and, in this case, it adds about $0.30 per gallon. Let's compare that to a four-stroke engine. I will use my own fuel consumption figures as a basis for the comparison. Last season I used 508-gallons of gasoline. We were underway for about 63 hours. If using XD-100 oil, this would imply using about 5-gallons of the oil, or about $150 in oil expense. If I buy the oil in bulk from a retailer I can re-use the same container for each oil purchase. This avoids creating trash in the form of oil-contaminated containers. My labor consists of pouring it into a reservoir as needed. What happens to the oil I am using in terms of environmental impact? Here I assume I am burning it in an emission compliant outboard motor, such as an E-TEC, so the oil is totally combusted and enters the environment mainly as water and carbon dioxide. Any hydrocarbons or other combustion emissions are within the EPA limits. If my motor were a four-stroke motor, it would have required one oil change if following the 100-hour interval. If following a shorter interval, at least one oil change and possibly two. Because the engine is laid up for a long storage period over the winter, it is generally recommended that the oil be changed before storage so as to eliminated the contaminated oil from the sump before storage. Each oil change would require six quarts of oil and a new filter. If using the same OEM branded and priced products, I estimate the cost of the oil change to be 6-quarts X $5 = $30 1-filter X $20 = $20 TOTAL = $50 There is some labor involved in performing the oil change. Let's accumulate the labor time and worry about the labor costs later. We figure the labor at one hour. We now have to dispose 6-quarts of contaminated oil. This represents something of a problem. In most cases one cannot just throw contaminated oil out with the trash. You have to take it to a collection center. I am fortunate to have a collection center about five miles away. This is a ten mile round trip. According to the federal government, this will represent about a $4 expense for my transportation. This takes about 30 minutes of labor time Unfortunately, the collection center only accepts the contaminated oil. It does not accept containers. Now I have a new problem. I have at least one and possible more containers which are contaminated with oil. I have a couple of choices to make. One option is to retain the contaminated containers for eventual re-use at the next oil change. Another option is to throw the contaminated containers out with my trash, burying them in some other garbage where they will not likely be found. The arrangement of trash collection services provided by my municipality does not include the collection of oil contaminated containers. However, my experience is that you can throw them out in the trash and they will be accepted for disposal if not discovered. This is an unethical way of transferring the burden of the cost of the disposal of the contaminated container unto another person or entity. I also have the oil rags and other trash resulting from the oil change. Again, to dispose of these I probably would have to travel to some collection facility or throw them out in the trash. I also have a used oil filter contaminated with dirty oil. As far as I can tell, this is a very difficult item to dispose of legally. Again, one option is to throw it out with the trash and transfer the burden of its disposal to another person or entity. What happens to the dirty oil taken in at the collection center? Most of it will be re-used for combustion in industrial furnances. The combustion products will again enter the environment. It is not clear to me if the combustion process is as clean as that performed by an emission compliant outboard motor. Also, I am not aware of any vendor who sells four-stroke oil in bulk. Thus every time I purchase four-stroke oil I have a new problem with oil contaminated containers. Again, I have to decide if I should transport and pay for the proper disposal of these myself, or just throw them out in my trash and transfer the cost of the disposal onto another entity. Thus, each four-stroke oil changes cost about $54 and requires about 1.5 hours of my labor. There are other costs associated with the disposal of the oil contaminated trash that each oil change produces, but it is hard to quantify them. One way to avoid these disposal costs is to hire a mechanigc and service agency to perform the work. This will shift the problem of the disposal of the oil and contaminated materials to them, and they will include the costs in their charges. We have at least one hour of labor, and let's figure it will be about $75. This also makes a better comparison to the cost of the two-stroke oil as we do not have to perform this labor in the case of the two-stroke motor. Thus we see that the true cost of a four-stroke engine operated about the same amount of time is now $75 + $40 = $125. This is only $25 less than the cost of the two-stroke oil. Further, when the oil is being changed on the motor, the boat is not available for use. This imposes a cost in terms of lost opportunity. How much is 1.5 hours of prime boating time worth? I think it is certainly worth $25 (the remaining difference in costs). Also, to transport the boat to a mechanic may involve other costs, such as highway towing, ramp fees, towing vehicle mileage, and towing vehicle fuel, oil, and depreciation. These costs are all likely to total at least $25. This brings the cost comparison to at least equal cost between the two-stroke and four-stroke engine lubrication costs. Overall, I do not think the cost of the XD-100 oil represents a significantly higher burden or added expense to the total cost of boating than the real and total costs of using a four-stroke motor. For many people, the true costs of the four-stroke motor oil change are shifted onto other entities which have to dispose of the oil-contaminated trash. |
Dick
posted 05-29-2006 01:21 PM ET (US)
JimWhere did you come up with the prices for a 4 stroke oil change? The Mercury filter for my 60 4 stroke is $9.90 25W40 4 stroke oil is 2.99 a quart. These prices are full retail, not what I buy them for. Max time to make the change is 30 minutes {that is free as I work cheap} The empty oil bottles go in the garbage. The old oil I dump in the container for our furnace at the marina where I work {again free} it's only 3 quarts so I wouldn't have a problem dumping it on the back lot if I had to. Now if we did the oil change at the marina there would be an hours labor at $95.00. Dick
posted 05-29-2006 01:36 PM ET (US)
Dick--I did not research the suggested retail prices for OEM branded four-stroke oil very thoroughly. I am glad to see they are available are more modest prices. Same for the filters.As I mention, disposal of empty CLEAN oil bottles in the garbage may be available, but it depends on the municipality. Disposal of used oil by pouring it onto the ground is one method, but I don't think you can find many authorities that would sanction it. Disposal of dirty oil containers may also be more of a problem. You should call up your local municipality and ask them if they have a problem with accepting plastic containers filled with used motor oil. If they are willing to accept them, I bet you could act as a disposal point for many people whose local cities and towns will not accept waste materials like that. There is no doubt it is possible to avoid some of the costs of disposal, but that does not reduce the actual costs that eventually have to be paid. Soil soaked with contaminated motor oil and landfills full of plastic bottles of used motor oil will eventually present a bill to someone which will have to be paid. The two-stroke motor converts oil into combustion products like water and carbon dioxide as you use your motor. A four-stroke motor puts a lot of oil contaminated trash into the waste disposal system or, if you pour it out onto the soil, perhaps eventually into our drinking water. |
Dick
posted 05-29-2006 02:18 PM ET (US)
JimThere are probably more 2 stroke oil bottles in the land fills than 4 stroke. That's probably not true when you consider the amount of bottles that go in from car oil changes. I don't advocate dumping your used oil in the back yard, only as a last resort. Most auto parts stores will accept the used oil if you don't have a marina that will. I did not suggest puting bottles filled with used oil in the trash, only the empty ones. I am not looking at enviromental issues but the cost of operation. I think that the 4 strokes are getting a bad rap on operating/maintenance costs.
JayR
posted 05-29-2006 07:54 PM ET (US)
Jim, When you personally and so thoroughly change the topic and the initial question in a thread, it is disingenuous to leave the authors name as the original poster.Looking back at the thread, the title is not mine nor is the opening statement/question mine. At the very least, you should add a note indicating the changes. Left as it is, you are putting words in my mouth. The original question was in regards to where I can purchase it in bulk quantity. So much for that.... |
posted 05-30-2006 01:11 AM ET (US)
Jay--I change almost ALL of the article titles here, and this one is no exception. This has become so common that I no longer denote it. The topic often changes to reflect changes in the discussion as the thread progresses. Also, I clearly delineate any material I add to articles with the square brackets. Both are extraordinarily common conventions in publishing. Even Ernest Hemingway had to suffer through the changes of his editor and publisher.Considering the cost of driving long distances to get lower oil prices or the expense of having it shipped, it is probably much more effective for you to just call a couple of your local marine outlets on the telephone and ask them what they are charging if you want to find a local source that has a better price. As a general topic, discussions of where to find the best price of a $30 item are not of great interest, and the website makes no attempt to collect, organize, and archive information about best-deal pricing. This applies even to $15,000 items like outboard motors. You will just have to tolerate these situations. Personally I use FROOGLE to find good prices. And people sometimes mention particularly great bargins. But we generally don't consider it to be compelling content to hash out who can save you a buck on a gallon of oil without it costing you more in time and expense to actually go buy it. I buy all of my oil from my dealer who sells in bulk. It is a good way to keep in touch with your dealer, see what is new, and shoot the breeze. So what if I pay a dollar more than at WALMART. Predatory retailers like WALMART won't fix my motor when it is broken, and the never have the same kind of oil on the shelf twice or in two stores at once. |
posted 06-01-2006 09:48 PM ET (US)
Above I mentioned a price for an OEM oil filter as being about $20. This drew criticism. I just noticed this report of OEM oil filter pricing in another article:"Oil filters for my 2004 YamaMerc 225 EFI four-strokes are over $30 from Mercury and only a dollar or two cheaper from Yamaha." (Cf.: http://continuouswave.com/ubb/Forum8/HTML/001712.html) I guess I was UNDERESTIMATING the cost. I will have to revise my figures upward 50-percent higher. |
posted 06-01-2006 09:53 PM ET (US)
I just used FROOGLE.COM to search for good prices on XD-100 oil. I was surprised to find not a single vendor listed. This makes me believe that the distribution of XD-100 oil may be limited to sales from authorized dealers of Evinrude motors. (This was the question I thought was perhaps implicit in the original article, and which I made explicit via the introduction of it in the brackets.]Is my assumption correct? Is XD-100 oil only sold via retail outlets that are authorized Evinrude dealers? |
andygere
posted 06-02-2006 01:51 AM ET (US)
Jim, I have read reports on other forums that in the past some large retail chains in the southern US carried XD100 oil at a good discount, but don't carry it anymore. I have never seen it anywhere but at the Evinrude dealer. |
Buckda
posted 06-02-2006 10:53 AM ET (US)
Jim -My local authorized service center has XD-100. He does not sell (new) Evinrude or Johnson motors. I can also get it at another chandlery in town, but they actually sell the motors as well. I can get it for $36 in the originall gallon jug and about $28 in bulk. Dave |
JayR
posted 06-02-2006 12:11 PM ET (US)
I looked for an MSDS for it and came up empty handed. I was hoping to gleen the components.There would have to be an MSDS so that leaves me thinking that it is under a different name. Mobile 1???? JKOC..... |
Perry
posted 06-02-2006 12:55 PM ET (US)
Anyone who sells it, stores it or transports it should have an MSDS on file for it. It would be interesting to compare the contents with XD-50 or another brand of oil. |
JayR
posted 06-02-2006 04:53 PM ET (US)
Any Evinrude techs on this forum willing to share a copy? |
seahorse
posted 06-03-2006 04:28 AM ET (US)
Perry wrote:Anyone who sells it, stores it or transports it should have an MSDS on file for it. It would be interesting to compare the contents with XD-50 or another brand of oil. Perry,
The MSDS forms do not list all the ingredients of a product, especially if they are propriatary. Several years back Bass and Walleye Magazine lab tested a bunch of TC-W3 oils to see if they were different and every brand had different formulas. |
Sal DiMercurio
posted 06-03-2006 10:48 AM ET (US)
That was an excellent artical in Bass Walley Boats [ I think May of 2004 but not certain ]. They also did another good artical on 4 stroke oils called..........."The Duke of Oil". Sal |
andygere
posted 06-03-2006 11:42 AM ET (US)
Does BRP allow non dealer vendors to sell BRP oil and other basic service items? Price is one thing, but availability is another. It would be great if on of the chandleries in my area sold XDD-100 so I would not have to drive 30 miles to buy it. I live 2 miles from the only Marina on this part of the California coast, and there are plenty of Evinrudes in the harbor. |
ConB
posted 06-03-2006 11:47 AM ET (US)
I just saw XD100 at the local Gander Mountain for $29.99 per gallon. Usually there is XD50 and XD30 there also, but there was not today.I buy XD50 from the local, family run Evinrude/Johnson dealer in bulk. Con |
cyclops
posted 06-03-2006 12:43 PM ET (US)
Jim HTo get a better idea of what an oil change costs, next time you are in Lockeman's why not ask them for the price of an oil filter and oil for the Evinrude/Johnson Suzuki fourstrokes. |
Buckda
posted 06-05-2006 11:59 AM ET (US)
Andy -Buy two gallons at a time. I now have about 350 miles of use on my motors. When I bought the motors, I added about 1 3/4 gallons of oil to fill the tanks from empty. I then refilled the containers and have added about 1/4 gallon to top off the tanks on the motors. The level is still very high. If you keep this oil on hand, you would need to put a lot of use on that motor to get really concerned about your supply at home. Dave |
