| Author | Topic: Anchor Lifting Float |
| erik selis |
I was watching "Rex Hunt's Fishing Adventures" on the Discovery channel last week and there was a very interesting scene where the guys demonstrated how to easily retrieve your anchor without much effort. They used a so called "anchor lifting float". Basically a large air-filled float, connected to a separate rope, that is hooked around the main anchor line using a shackle. When the anchor is to be retrieved you start the engine and manoeuvre away from the anchor line (that is tied to a cleat at the stern). As you move forward (pretty fast in the TV demonstration), the line of the float is let out as the anchor line runs through the shackle attached to the float. At a certain point the chain runs through the shackle and the anchor is water-skiing behind the boat. It cannot sink as long as the chain has passed though the shackle. Now you stop the boat and pull in the floating anchor that has become virtually weightless. I had never seen this technique before and found it interesting. Here is a link explaining this type of anchoring in detail: http://www.marinews.com/boat_article_details.php?recordid=41 Has anybody here tried this before? Rex Hunt is Australian and the article in the link is from an Australian boating site. Seems like a technique they use often down-under. Erik |
| JMARTIN |
Anchor retrieval system. I have used them to pick up 40 pound shrimp pots. They work and I keep one aboard when shrimping even though I have an electric puller now, just in case. They are scary and the float takes up alot of room. They have a one way do-hicky that the line passes thru and the do-hickey is attatched to a 60 pound floatation float. You pull in the slack sliding the float/do-hicky combo down the line, toss it in, cleat it off and take off, fast, almost to plane. I went too slow the first time and could not tell if I was getting farther away from the float that looked like it was wake boarding. You pull pretty quick and that is scary if the pot or anchor in this case, gets hung up on the bottom. I am pulling pots so I want to stop when the pot gets to the float. Then I have about 400 feet of line in the water between the pot and the boat and I want to get to the pot quickly. You want a good deck hand using these things. John |
| kingfish |
Erik- That is a very common accessory on boats that fish wrecks and man-made reefs in the Gulf of Mexico. They are sold by most of the larger chandlery chains (West marine, etc.), and are nothing more than a round bouy or fender with a ring and shackle at the other end of about an 18" length of line. My first exposure to one of these was a couple of years ago about 40 miles off of Apalachicola Florida fishing in my Outrage 22 with a couple of good old boys who knew the territory in their 25' World Cat. We were fishing (anchored) over an abandoned oil well template that rose up to about 90' deep in around 140' of water, and as the day wore on the wind built and it got a little choppy. When it came time to leave, my anchor (a danforth - the "pros" use wreck anchors that look like grappling hooks) turned out to be absolutely and seemingly irretrievably stuck in the framework of the old template. It would slide up and down about 10', and that was it. I tried everything I knew, and battling the building seas, I was starting to contemplate cutting the anchor line. Then my partners in the World Cat came over and tossed us one of those devices and told me to clip it to the anchor line, then let out all my line and circle the stuck anchor. They said the anchor retriever would "go down and get my anchor". Well this yankee knew better than that. But by damn if that isn't exactly what happened! The bouy was pulled down out of site, and the next thing I knew, there was the anchor with its shank through the ring of the retriever, floating at the surface, ready to be pulled aboard! I have an anchor retriever of my own now, and I don't go out for that type of fishing without it. John |
| Barry |
I have one of these http://www.thmarine.com/product.cfm?PRID=163 . I used it repeated this last week in about 90' of water, fishing the artificial reefs off of Orange Beach, Alabama. It worked great. Here is another link http://www.ironwoodpacific.com/products/anchorlift.asp that shows both the AnchorLift and Anchor Ring systems. |
| highanddry |
Those vand home made versions are used a lot in the Northern Gulf. The wrecks and artificial reefs and occasional natural rock bottom make them useful. Most boats there use the grapple type anchors. My grandfather used that type rig. I am always careful not to set mine on living bottom. |
| erik selis |
I think I'll be getting one of my own soon guys. It looks like a very handy piece of equipment. I've lost some anchors in the past but it's losing the stainless steel chain that usually bothers me. I was just wondering what would happen if the anchor was truly stuck and wouldn't budge. Wouldn't you pull the boat under fast? Barry, the first link you posted is exactly the one used by Rex Hunt's team in the demonstration. Erik |
| pglein |
That sounds like an absolutely useless accessory. Perhaps someone could explain it in a little more detail. What advantage does it offer over a simple retrieval line? |
| alfa |
Loosing anchor ? It depends howw you rig it. Never attach chain on top of the arm of the anchor. Always at the bottom. Then with little material of your choice (50 or 80lb line), tighten the chain with top of the arm of the anchor. If the anchor is truly stuck, the little material will break and you can retrieve all stuff because the anchor will not struggle with rocks. Alain |
| pglein |
Alfa, That's only a good idea if you don't rely on your anchor to keep you put while sleeping. The retainer line could break in the middle of the night and unset the anchor. You could then awake to find yourself bashed against the rocks, or drifting in the middle of the sea-lanes. I much prefer to use a small retrieval line attached to the retrieval point. Although, I've never once had an anchor become fouled, and never had to use the retrieval line. |
| kingfish |
If you will never once have an anchor become fouled, then they are an absolutely useless accessory. So buying one would be a foolish investment for anyone lucky enough to count themselves in that number. |
| alfa |
Peter, You're right. Regards Alain |
| jmorgan40 |
erik, I use the THmarine retrieval system Barry listed a link for. I was first introduced to it while fishing wrecks in the gulf off of Perdido Key and the Pensacola area of Florida. The think works great, in fact someone said don't leave home without it and I did just that two weeks ago on my trip to Key West. I fished the reef and wrecks one day and could of kicked myself for leaving it at home. What a bear it was retrieving the anchor in those currents. I learned my lesson and they are so simple to use |
| Barry |
pglein, The main benefit is that you don't have to lift the anchor and chain up from the bottom. With the anchor ring system the anchor ends up floating on the surface suspended by the float. You just pull in the line. Sort of a poor man's winch. |
| pglein |
Seems like more work than it's worth to me. It doesn't do anything to prevent a fouled anchor? If your boat is big enough to require an anchor that is hard to lift, it's big enough to have a windlass. It seems like a rather dangerous and wild way of bringing up an anchor. |
| bsmotril |
Then I guess that 80% of the charter captains on the TX coast who fish wrecks don't know what they're doing. The other 20% have a windlass. BillS |
| pglein |
I'm just saying it doesn't make a lot of sense. If they're anchoring around wrecks, I'm assuming that the posibility of snagging your anchor is high. This process seems like it would increase your chances of snagging exponentially, which wouldn't be a good thing. Plus, in an area with lots of divers, it seems like it would be REALLY dangerous for any unfortunate diver who happened to get in the way. Coming from the big-boat world, I tend to think of a windlass as being a basic piece of equipment that nearly every boat has. Virtually every production boat over 25' comes from the factory with one these days. I certainly remember when that wasn't the case, but pulling the anchor up by hand was never much of a problem for me, even on a 30' sailboat with a heavy steal danforth. |
| kingfish |
It doesn't prevent a fouled anchor - it retrieves a fouled anchor. Contrary to the notions of those who can't understand that, and/or have never used one for that purpose, guess what? As hard to believe as it may seem, these anchor retrievers work like crazy, and many *experienced* boaters who have other choices, like them and use them. |
| pglein |
Ok, then explain to me again how it works. Becuase what I'm picturing would do nothing to clear an anchor that was fouled on wire, log, or wreck debris. If anything, it would rip your cleat right off the back of the boat when the line went taught. |
| kingfish |
The line doesn't go taut. Read my first post (again?). With the retriever ring snapped over the anchor line, the boat *circles* the fouled anchor. Apparently when circling, the bouy provides for different angles of retrieval than one can achieve by snubbing the anchor line off to a cleat and trying to use the motor to release the fouled anchor (especially in rough seas or fast current, where the conditions don't permit floating directly over the snag and working on it in a liesurely fashion). And by the way, we're talking primarily of boats here 25' and smaller with the respective ground tackle found in boats of that size. This little gem has saved my anchor 4 times and counting on my Outrage 22 with a 12# Danforth. |
| pglein |
So is the intended use to speed recovery of an unfouled anchor, or disengage a fouled anchor? I'm confused. The simplest, safest, and easiest way to unfoul an anchor is to use a retrieval line. That will work virtually every time, with minimal effort. If not, you have obviously become very extremely fouled and no mount of moving around will help, with or without the buoy, and your only option is to either dive for the anchor or cut it free and replace it. No boat under 25' should need to carry an anchor too heavy to manually lift, unless the operator is elderly, or suffering from a disability, in which case, one would hope that they have an able-bodied deckhand with them.
Perhaps the interest in this device is just that it allows the operator to use his big noisy engine to pull up the anchor in a splashing blaze of glory instead of an unglamorous 1/4" nylon line. |
| JMARTIN |
OK, the system I have used for pots is the anchor lift. I had not seen the anchor ring before. Two different critters entirely it looks like to me. John |
| kingfish |
Well I agree that there is some confusion here. However, that confusion would seem to be in the minds of those who have never used one of these things, and/or more specifically in the minds of those who don't want to use them, don't want to become un-confused about their efficacy, or who simply want the soapbox. I'm not interested in fighting for the soapbox or preaching to the lost. So if you don't think these retrievers work as I've described, or if you think you have a system that works better, I repeat what I said above: you'd be foolish to spend your money on one. End of story. Me, I'm ambling back to where I was when I responded to Erik's initial post, in what was intended to be a friendly and relevent way. Erik, I have used one of these before, and I was impressed enough by how it worked that I now own one of my own, and I'm glad I bought it. John |
| bsmotril |
Same here. I anchor a lot in depths of 80-200 feet, and retrieval with the float is a simple 5 minute affair versus 15 minutes of straining your back. BillS |
| Backlash |
Erik, I have never used one of these anchor retrieval systems, but have seen them in use and they are an amazing way to effortlessly retrieve an anchor. It's certainly much easier to pull in your anchor and line when the anchor is floating on the surface. I have planned on purchasing one for some time, just haven't yet. I am constantly amazed at some people on this site who discredit obviously experienced boaters when the discussion involves something they know absolutely nothing about. Steve |
| Plotman |
I started using the Taylor Made ball fenders last year - they make great fenders on the log crib docks I find myself tying up to weekly. Based on this thread, I just bought a ring to keep on the boat. Best price on the TaylorMade TuffEnd balls I have seen is Bass Pro - the 12" bouy is $19, the 15" are $27. |
| erik selis |
Thanks for your comments guys. I guess it isn't easy to explain how it works unless you have seen it in action. When I saw the demonstration on TV, I found it to be a great way to retrieve the anchor without having too much hard work involved. Especially when you're out there alone (what I usually don't do when I know I'm going to anchor). The places I go fishing have some very strong currents (7kn) and the anchor can be a pain to get off of the bottom. I use a 9lb Standard Danforth anchor (I always have 2 with me) with a long stainless steel chain connected to the top and 300ft of rope on each. I know this is a heavy anchor for my boat but I feel more comfortable with it than the 5lb version. Alain, I don't see how you can attach the chain to the bottom of this type of anchor unless you modify the anchor. Another advantage I can see is that you don't damage the rub-rail, bow chock and underside of the bow when lifting the anchor from the water. Not everyone, who's out with you, has the strength or is as careful as you would like them to be. You can also easily remove trapped-in mud from the anchor before lifting it in. I think it's a great device. Simple and buy the comments I have read here from experienced and respected skippers, effective in it's use. I can't wait to get mine and try it out. I learn something on this site every time I come here. Thanks again fellas! Erik |
| highanddry |
Recently I dove a wreck about 20 miles out of Pensecola. I counted and lost count at 11 anchors of various description. Since I was on a boat we had chartered I left them lay where they were. Oh, the boat we chartered, the captain used this metod for his retrieval. He still has his anchor. |
| pglein |
Kingfish, I'm not trying to take the soapbox, I'm just trying to get a clear picture of how this thing works. If it does what I'm picturing, I guess it takes some of the effort out of lifting the anchor, but at great risk not only to divers and passengers, but also of becoming snagged on bottom debris, which seems to me to make it LESS desirable for use by divers around wrecks, rather than more. From what I'm picturing, it seems like more traditional methods (retrieval line, bow roller and a windlass) make a lot more sense for accomplishing all the same things with much less risk. But again, I've read the descriptions as carefully as I can, and followed all the links, but I still figure I must not get it. If you guys swear by it, and experienced captains use it regularly, it MUST not work the way I'm picturing. So please, someone explain it better. What I'm picturing is a float that attaches to the the anchor line and can slide freely along it. To lift the anchor you attach this float to the anchor line and gun the engine, leaving the anchor line attached to the boat (but moving it to the stern, I guess, which seems dangerous in and of itself to me) The float then travels down the line, being drug by resistance in the water, and it's buoyancy lifts the anchor somewhat vertically. Once the anchor is at the surface, it basically drags behind the boat, with the chain portion becoming entangled in the float and you then bring in the anchor line like you would a waterski rope, rather than lifting it vertically. Why this doesn't make sense to me: 1, the act of gunning the engine and lifting the anchor seems to me like it would do significant damage to your ground tackle and deck hardware if the anchor was fouled on something solid. 2, it seems like the lateral travel of the anchor through the water as it's being lifted would greatly increase the risk of becoming fouled or hitting a diver. 3, The heavy part of any ground tackle isn't the anchor itself, but rather the 200' of chain attached to it, which you'd still have to haul in by hand. If you're anchoring in a small boat that wouldn't carry that much chain, I don't see how it's any big deal to lift it by hand anyway. In my 13' Whaler I carry 300' of line, 20' of chain, and an 11# claw anchor (a perfectly suitable rig for any boat up to about 25', certainly oversized for my 13', anything larger should carry at least 100' of chain). This is such a light rig, I would never complain about having to haul it in by hand. Considering the risks of what I described above, it seems like a pretty small price to pay. If you're so out of shape that you can't even lift 30#, what do you expect to do if you fall overboard? Because you sure as heck aren't going to be able to swim anywhere. |
| kingfish |
I don't know anything about gunning the engine, and at least where and how I fish, there are no divers present. Nor do I know of (nor can I imagine) 200 feet of chain rode in any of the boats we're talking about here. More like 20' to 25' max. When my anchor is fouled on something on the bottom and I am unable to retrieve it in any other way, I snap the ring around the anchor line, throw the retriever bouy in the water, let out all the anchor line if it is not already out, and idle (or fast idle) in a circle around the spot where the anchor is fouled, close to the limit of the anchor line. I've yet to have to go further than one complete circle before the anchor is freed. I for one am not interested in dealing with virtually another anchor line, 1/8" diameter or any other size, when I'm anchoring in 100-150 feet of water and dealing with strong winds and/or currents. The notion of attaching the chain rode to the base of the anchor with a break-away line attaching the chain to the end of the shank holds some interest for me, but I've not found a good place on a Danforth to attach the chain to the anchor base, and the retriever system (which is what we're talking about here) works for me. |
| Al_A_Buy |
King - I when I bought my boat, the previous owner gave me a round buoy with a ring thingy attached. After reading this thread, it seems that I have an anchor retriever. I am still not picking up the technique for how to employ it and the Aussie article has too many local terms to be crystal clear. Can you recommend a resource that is a bit more step by step with pictures for us graphically oriented types? Thanks Al W. |
| Barry |
My 22 Outrage, like the majority of Outrages, does not have an anchor pulpit. All of the boats I've owned from 17' to 24', including this one have used Danforth style anchors with 6' to 20' of chain. Retrieving the anchor from my 22 Outrage without the anchor ring means standing in the bow as far forward as possible and working over the bimini and forward shelter that are stored there or working inside the deployed forward shelter out of the front window. It involves dragging the line in over the rub rail and hopefully away from the bow rail support. I consider myself fairly able-bodied but still find this method a pain especially if the water is deep, conditions are rough, there is much current, the anchor is fouled, and/or I'm boating alone. The two links I provided above give fairly detailed directions. To use the Anchor Ring system I just:
| andygere |
Kingfish/Barry: Do you leave the anchor line cleated to the sampson post at the bow, or do you move it to an aft cleat? JMARTIN: Do you need extra line on your crab/shrimp pots to use this device as a puller? How much? I rarely anchor my boat, but after pulling some crab pots in just 50 feet of water last week, my back is looking for a better solution. |
| JMARTIN |
Andy, I have only used it on shrimp pots that were about 350 feet down and on 400 feet of 3/8 weighted line. It is the anchor lift set up, not the ring. I do not know why it would not work with 75 feet of line on a pot 50 feet down. The secret is having a bouy that squats in the water so the pot comes up to the bouy instead of the whole thing taking off after the boat. I was told that you can hang a bucket from the bouy/lift set up to help keep it from moving. I have not tried that but it sounds like it would work. After using one for a season of shrimping, I bought a pot puller. The bouy has to be big enough to float your pot, so it takes up alot of room in the boat when not in use. Mine was yellow so it is legal to leave on the line for shrimp, but not for crab. You can also lose the whole thing and the pot, if you leave it on and the current takes off with it. I also did not like tying off to the boat and taking off. If the line breaks, you have lost your pot. If you take off and drag the pot on the bottom for a while before it starts up to the bouy, you can wreck your pot. I was at least 300 feet away from the bouy, so it was kind of hard to tell when the pot had reached the bouy. You also have all the line in the water between the boat and the bouy when you go back to grab the pot hanging under it. You certainly do not want some one to run in between the boat and the bouy and you have to make sure you do not run over the line also. John |
| Barry |
I've always just left the anchor line cleated on the sampson post. So far (knock teak) I haven't fouled an anchor bad enough that I had to let out additional line and circle. |
| pglein |
We can debate the effectiveness of the system for pulling an anchor all day long. I guess I can see where on a boat that did not have a windlass, and had poor access to the bow, it could offer a little reprive for your back muscles IF you are in open water with a flat and unobstructed bottom, and there are no other boats anywhere hear, and you have a heavy anchor with a short chain (a sure recipe for dragging anchor). But I can say without a doubt that I would never use it to lift a crab pot; at least not one of mine. The pots are fragile enough as it is, the last thing they need is to be drug through the water at 8-9 knots. And you must be pulling some pretty full pots if you're tired after lifting them just 50'. I crab in 200' of water and usually bring up no more than 5 or 6 crab per pot, so it's not exactly backbreaking. If you're anchoring in 100-200' of water with a danforth, you should really have more than 20' of chain. A danforth requires about 1/4 to 1/3 of the line deployed to be chain in order to hold a set. At 5:1 scope in 100' of water, that's 125' of chain. I suppose you could get away with 50' if you ran 6 or 7 to 1 scope in order to lower the angle. But in order for a danforth to hold, the chain needs to be puling perfectly laterally on the shaft. The slightest upward pull will unset the anchor. This is why I don't use a danforth. I assumed when you said you were anchoring near wrecks you were diving, not fishing. I've never heard of dropping an anchor while fishing, but I guess it makes sense if you're trying to target the fish around a specific spot. |
| kingfish |
Al and Andy- Following is an edited quote from one of my earlier posts in this thread, that describes to the best of my ability how *I* use my anchor retriever: When my anchor is fouled on something on the bottom and I am unable to retrieve it in any other way (or I am not interested in trying anything else), I snap the ring around the anchor line, and throw the retriever bouy in the water. I make sure the bitter end is tied off to the bow lifting ring then let out all the anchor line if it is not already out and snub the anchor line to one of my bow cleats. Then I idle (or fast idle) in a circle around the spot where the anchor is fouled, close to the limit of the anchor line. The bouy submerges sometime during this part. I've yet to have to go further than one complete circle before the anchor is freed. When the bouy pops back up to the surface, I straighten the path of the boat out (keeping a slight angle so I don't foul the anchor line in the prop) until the bouy is clearly following the boat; the anchor is then hanging from the bouy with the shank through the retriever ring. The anchor line could easly be cleatd off amidships or aft. John |
| kingfish |
pglein- This was a response to Erik's question whether anyone had used one of these things. It wasn't a debate about the effectiveness of the system for pulling an anchor but for your argumentative posts that apparently weren't even based on having read earlier posts in the thread. You say now that you assumed we were talking about diving because we referenced wrecks. The first reference to what *anyone* was doing before they utilized the system to pull an anchor was the 3rd post down from the top (mine): "That is a very common accessory on boats that fish wrecks and man-made reefs in the Gulf of Mexico." You must have missed that.... |
| pglein |
I'm sorry if in 37 posts I missed one word. I'll try to be more detail minded in the future. |
| kingfish |
l.w. |
| Barry |
Regarding anchor rode, I was under the impression that all-chain rode was typically used on larger boats with windlasses. On smaller boats, I believe a combination of a small section of chain (6-30') and three-strand nylon is typically recommended. The benefits being less expense, less weight, and no windlass requirement. In this configuration the chain primarily provides resistance to abrasion by bottom structure. The downside is that significantly more scope may be required, as much as 7:1 to 10:1, in order to keep the pull horizontal. I have seen recommendations for using more chain, say 50-100', in addition to several hundred feet of nylon. |
| Bthom |
Hi all, I have used both the anchorlift unit and a different type that incorporated a drift sock to minimize lateral movement,and I find either of them is preferable to a winch on the pulpit or pulling by hand. I found a winch too slow and pulling by hand was much more work. I pull my anchor with my kicker regularly and leave it tied to the cleat on the pulpit, I just drive a big loop,starting in the opposite direction to what I set the anchor,keeping the rope out of the prop. The beauty of any anchor retrieval system is that it is much easier to haul your anchor when it is already floating on the surface, in rough water it is a lot safer. The only drawback is you need room to use them. Cheers, Brian |
| Plotman |
quote: Say what? I have never heard any reliable authority claim that a danforth requires this much cahin. Can you cite one? |
| Buckda |
This sounds very interesting. I'm going to try this later this summer. I use the method mentioned further up. I use a small plastic ZIP tie to my Bruce anchor and have the shackle at the elbow. That way, if I'm truly stuck on the bottom or on anything, I can tug very hard and break that ZIP tie and retrieve the anchor. I've needed to use it once. I don't worry much about breaking anchor and drifting into shipping lanes, etc, because if I were sleeping aboard in conditions that would put that much strain on the anchor; 1. I would not be able to sleep and 2. I'd put out a second anchor, my danforth. Dave |
| CHRISWEIGHT |
I have used a similar system here but we whip a six inch piece of wire coat hanger or similar to the anchor rope about five feet obove the anchor. when the clip passes over this, the wire springs back and will not allow the the anchor to drop back to the bottom .its then easy to collect the anchor suspended five feet below the buoy. regards chris |
| pglein |
plotman, Just going off of years of experience. But if you're looking for authority, check out Chapman's Piloting and see what they say. |
