| Author | Topic: Cost of Service to Winterize Outboard? [Was: Winterizing Outbards $?] |
| Outrage18 |
Hello- I wanted to find out what people are paying to winterize their outboards. Thanks. PL |
| vermilionwhalers |
Outrage: I'm doing it myself this year, but smaller motors: Johnson 60 and Evinrude 30. Parts are running about $15-$20. Have to dispose of lube, etc. so it can be a pain. Did the 60 last night in about an hour. Hands get oily injecting the lube. Many years ago I had the smaller motor winterized for about $75. You're paying for time and labor, mostly; I don't think the price is way out of range. Also gives you cause to complain if the motor doesn't work well next Spring; I can't. If this helps, I'm also having winterizing done for an I/O Mercruiser 235; gets way more complicated with the hoses and stuff. That's going to run $200 plus w/an oil change. Throw in a power wash and wax and you're talking near $500, but that's a 23 footer... Hmm, I need to get rid of a boat! HTH, |
| Contender25 |
Twin Yamaha 200's/1999 Shrink wrap 28ft boat Winterize water systems on board $525.00 In Rhode Island |
| andygere |
Winterize? I just put on fresh bottom paint and I'm getting ready to put her back in.......Oh how I love California! Sorry guys, After many years of 3 month boating seasons back east, I couldn't resist. |
| Sinclair7 |
What does winterizing a small 25 entail? |
| Macman |
Last year I paid $60 for a Yamaha 70. This included changing lower unit oil, repacking bearings, greasing, etc. I thought that it was a good deal. |
| B Bear |
2000 Honda 90, $60 - oil change for the engine and lower unit, fogging the cylinders, draining the gas from the carbs. It has been a few years but it used to be that much just for an oil change on a 5.7 ltr. Mercuiser. |
| where2 |
South Florida, Johnson 70Hp, 1985, $0 Winterize? It's 85F out today? Dec 25th, it might be 73F. If I get a night that is cold enough to freeze something, I'm more worried about the plants in my yard and my jacuzzi. To be fair, my wife is from Maine, and I still don't understand how people live through that cold weather... As for the bottom paint in California, I keep my whaler on a lift, so I don't even bottom paint! |
| andygere |
Where2, you've got me beat! But hey, we don't have any mosquitos! On the serious side, to winterize the 40 hp on my old 13, I would flush the motor, squirt fogging oil into the carb, change the lower unit oil and remove the prop and grease the prop spline. I'd try to use up the remaining gas in the tanks, and put the battery in the garage on a scrap of 2x10. For small motors, it's a do it yourself job. On bigger outboards, what else is done? |
| Taylor |
We don't have winter here in Seattle, but Fall starts next week and the rain will last till late June. So what we really need to do is waterproofing. Actually, I was just chatting with a guy at the Merc Parts & Service place this morning and they said: 1) Lower unit oil change. This is done in case of water in the oil and keeps your gears from rusting which avoids stiff shifting. 2) Treat the gas left in the tank, run it enough so you have treated gas in the carbs. (anyone know how to drain it out of carbsm that sounds safer) 3) Spray in fogging oil until the engine just about dies, then shut it down. Anything else? |
| Taylor |
The reason for the list, is that the guy at the service place said many customers do their own winterizing, and he 'does not seem most of them in the spring, so it must go alright'. If my list is complete $180 sounds a little high, I can't see that it would be three shop hours. Three Taylor hours, sure, but not for a pro. |
For the Do-It-Yourselfer, I started a new topic with some suggestions and a procedure. See: http://continuouswave.com/ubb/Forum3/HTML/001212.html I think my local Mercury dealer charges $75 for an outboard. I'll check tomorrow when I drop by to buy some materials. |
