Topic: Engine "Bogging" Down
rmart |
posted 06-25-2003 10:24 PM ET (US)
This site has helped me time and again with questions re: a 1987 18' Outrage I purchased last year. Now, after my first run of the season, I am experiencing a frustrating engine problem with my 1987 Yamaha 115 that I thought had been resolved last year.The best way to describe problem is that the engine bogs down and sometimes stalls when I increase the throttle from a trolling speed. The bogging and/or stall can be minimized quite often if I click on the full choke switch at the same time I increase the throttle. What is most annoying is that I took this boat to a local marina last year in September and had the following work performed: (1) engine tune-up; (2) replaced spark plugs; (3) rebuilt carbs; (4) replaced water/fuel separator; (5) changed oil senders in both remote and main tanks; (6) changed lower unit oil; and (7) water test. Following this work the engine ran much better for the month of September 2002. However, this afternoon on the first day of use the engine is boggin down again. I am frustrated and don't know where I should start at this point and would greatly appreciate any suggestions. Thanks in advance.
Peter
posted 06-26-2003 08:39 AM ET (US)
Have somebody check the fuel pump. Perhaps it is weak. |
Tom2697
posted 06-26-2003 10:22 AM ET (US)
Check for a fuel filter under the cowling. You are describing a fuel flow restriction problem. Let me also ask this, when you stored the boat in September, did you drain the carbs or at least put a fuel stabilizer in the tank and then run the boat? If not, your carbs are gummed up again. |
Sal DiMercurio
posted 06-26-2003 03:23 PM ET (US)
Sept of last year was 9 months ago. Either your carbs are gummed up again from leaving the fuel in them, or your fuel is old & probably only about 85 octane. Sal |
rmart
posted 06-26-2003 03:27 PM ET (US)
Thank you both for input. Fuel pump was checked last year and was fine.As far as winterization process, fuel stabilizer was added into the tank at appropriate ratio and the engine was run on this stabilized gas while I fogged the engine. During fogging process I disconnected the fuel line and continued to fog until engine and carbs ran dry. Would a can of Valvtech Motor DeCarb solve problem if this sounds like gummed carbs? Or should I bring the boat immediately to a mechanic? |
Tom2697
posted 06-26-2003 04:17 PM ET (US)
It could work depending upon how much varnish has formed. Try it and see....a $6 bottle of cleaner costs less than a mechanic...Since you state that you added stabilizer AND drained your carbs, I am thinking something else...was the fuel tank (mostly) full when stored? Metal fuel tanks will develop a lot of condensation over the winter that will dilute your fuel. Or, your fuel water separator could have been the trick last time and it could be it again. Check this out and let us know. |
rmart
posted 06-26-2003 04:35 PM ET (US)
The fuel tank was filled "to the rim" over the winter so I wouldn't have thought much condensation would occur. I did not change the fuel/water separator yet this year. It was one of the items changed last year in September and then only had minimimal use for 2002 (less than 6 hours). While I planned on changing it, I must admit that I had not changed it yet. |
Buddy
posted 06-26-2003 05:56 PM ET (US)
Ground the sparkplugs, remove the output line from the fuel pump and crank the engine. If you get erratic, pulsing spurts , not a uniform flow, its fuel starvation. Search for eEither a clogged fuel filter, fuel line connector fitting, or crimped fuel line. Otherwise finding nothing, I'd replace or rebuild the fuel pump: not a big deal repair.Try pumping the gas line bulb while at high revs. If the problem goes away, it's almost surely poor fuel pump output. |
rmart
posted 06-26-2003 10:16 PM ET (US)
Sal, What would you recommend for a winterization process next year to hopefully avoid any question of old fuel when I am usually going to have a layup time of approximately 8-9 months. Would you recommend tank run dry or filled with fueld treated with stabilizer? |
Tom2697
posted 06-27-2003 01:52 PM ET (US)
rmart, you made an interesting point. It sounds like you did everything correct but have a recurring problem. Is there any chance that the fuel was contaminated with water from last year? You stated you changed the fuel/water separator and the problem disappeared but then reappeared after about 6 hours. Could be the fuel has enough water in it that the separator is full again...Do you have the separator with the sight bowl at the bottom or is it a solid metal canister (looks like an oil filter)? Change the separator again (or drain it) and see what happens. If the problem goes away (for a short while - 6 hours again), you will need to drain the fuel tank as you have a lot of water in there. Before you do any of this though, try running off a small portable tank with fresh gas to see if this helps...Even better if you can bypass much of your existing fuel line (filters, fittings, primer bulb, etc). If this works, try connecting the temp fuel line to each fitting to find where the problem is. It's a time-consuming investigation but it will be better than replacing items that are in good shape (including 60+ gallons of fuel). |
rmart
posted 06-27-2003 02:19 PM ET (US)
Tom, Last night I ran the engine on a portable 6.5 gallon tank with fresh gas on a flush kit in the driveway and also sprayed a can of Valvtech Motor DeCarb as well. I will see tonight how this worked for me when I run the engine on the portable tank with new gas tonight. I have not changed the separator (which is the solid metal canister type) yet but plan to do so this weekend. What are your thoughts on dry gas or other methods to rid a tank if water is present. Thanks again for the insightful comments. |
JDH
posted 06-27-2003 02:39 PM ET (US)
One of my neighbors on the lake got water into his jet ski. He was going to put Heet in, but the mechanic said that it will screw up the engine because the oil won't mix right.I have never heard this, and in an attempt to fix my own issues I hadd added the STP version of a gas drier - if this is bad for a 2 stroke, into the mower the gas will go! BTW - carbs come off mine tonight - we pulled the boat last night. Jim |
Bigshot
posted 06-27-2003 03:01 PM ET (US)
I used to run dry-gas every spring when I filled up after the winter on the way to the ramp. Won't hurt a thing. It is basically alcohol that absorbs the water. Over continued use it can eat gaskets but not once or twice a season. Run on 6 gal tank and see what gives. Change the fuel filters and check for leaks or air sucking in. When it bogs, see if bulb is soft or hard. If soft that is your problem, you are running out of gas. try a new bulb or check for kinks in the line. If none of the above happen, check the fuel pump again. |
lhg
posted 06-27-2003 03:28 PM ET (US)
I experienced this identical problem for over 5 years, on same boat, right after I installed Tempo primer bulbs. After extensive engine tests, mechanics insisting the engines were in perfect condition, I switched to Attwood primer bulbs (Walmart @ $5 vs Tempo at West for $10!) PROBLEM GONE! The Tempo primer bulbs were defective, but any brand can go bad. I would not recommend Tempo after this experience.The check valves in these things go bad, and you experience fuel starvation and vapor lock. Engines die out on acceleration from too lean of an idle adjustment mixture, also. The first thing I would do is install a new bulb, maybe the Yamaha brand. I'm betting it will solve your problem. |
rmart
posted 06-28-2003 08:10 AM ET (US)
Status report. Ran the boat last night after de-carbing the engine with a can of ValveTech. Ran the engine on a new 6.5 gallon tank, new gas and new fuel line (with new primer bulb) running the new line directly to the engine (no water/fuel separator). Engine still bogged down while increasing throttle! Only help continues to be full choke toggle switch.Afterwards, changed the water/fuel separator and drained the old cannister to find no water or debris. |
rmart
posted 06-28-2003 10:25 PM ET (US)
Based upon my limited knowledge and review of engine manual and the information this site has provided, I think I have narrowed problem down to the engine and I will have marina look there and likely change the fuel pump. Any idea on what I should expect to pay for such a change? |
lhg
posted 06-30-2003 07:10 PM ET (US)
Stalling out as you describe is also a result of carbs being adjusted too lean. Might also check into that situation. |
bothedog
posted 06-30-2003 11:23 PM ET (US)
Experienced the same problem w/ my Johnson 1984 70 hp 3 cyl years ago. We were in Florida vactioning (this is an important element to my possible stupidity which follows). Took the boat out and did the same thing as you describe. Found an OMC mechanic who could work on the boat and had all carbs rebuilt as per his diagnose. With X dollars coming out of my pocket when I picked up the boat, was advised that it continued to stall out and I should push the choke to get it powered.... Mechanic said that OMC put a gel b/w the blocks (apologies for getting the terminalogy wrong) which can wear w/ time. This was probably where the problem was as air was getting sucked in, I was informed. He could fix the problem which would lead to a total of 1350.-- (carb rebuilds included). Opted not to go this route.Being stuck in the keys on vacation, I took the desparate route and caulked the seam where he claimed the leak was with JB Weld (here enters the possible stupidity move...). When I primed the bulb at launching for a test run, I noticed a small pin hole leak in the bulb. Replaced the bulb with an Atwood Bulb from Wal-Mart (as noted in the above post). Boat ran like a dream for years. Unknown if it was the mysterical OMC gel that had gone or the bulb. From some mechanics opinoins, I would tend to lead towards the bulb (always open to other opinions if they are out there). Long story short - try the new primer bulb. And I obviously wouldn't suggest the JB Weld route! I was desparate - which will lead to problems if the motor needs to be rebuilt (which will probably not be the case, as might be time to repower - this motor has served me well). |
FXSTB
posted 07-01-2003 11:09 AM ET (US)
I just successfully fixed the same exact problem you are experiencing with my 150 Evinrude. I did all the things that you have tried and was still experiencing the bogging. The fix was to remove a well disguised fuel screen that is hidden at the point where the fuel line connects to the fuel pump. Even though the inline fuel filter was the screen was almost completely clogged. How the debris got past the filter I don't know, but right now it doesn't matter because it has been discovered and fixed. If your Yamaha has a well hidden fuel screen somewhere in the stream of gasoline I would find it and make sure it's clean. Good Luck! It almost drove me crazy! |
rmart
posted 07-06-2003 10:16 PM ET (US)
I am thrilled to report that the engine is now running great without any bogging down at any speed including getting up on a plane.I am not sure what the problem or final fix was that solved the problem but here is the re-cap of my efforts: 1. Purchased the following: A. Can of ValvTech Motor De-Carb; B. Portable 6.5 gallon tank; C. New tempo fuel line with yamaha fittings 2. Ran the engine on ear muffs with the above items and de-carbed the engine per instructions on can. 3. Ran the engine the following day in Barnstable Harbor but experience continued bogging down when increasing throttle from a trolling speed. 4. Returned home and performed the following: A. Checked water/fuel separator (found no water present); B. Checked fuel filter on engine (found the same to be clean); C. Tightened all fuel line fittings. 5. Have since run the engine one four (4) separate days with absolutely no problems. My only thought is that I didn't run the engine long enough the day after I De-Carbed to complete the de-carb process. Either way my engine is currently running great and I did not lose the boat to a marina for weeks or pay the price for a mechanic. Thank you all for your help and assistance in working out this engine problem. This site is the best. |
FXSTB
posted 07-15-2003 11:07 PM ET (US)
Tightening the fuel line fittings probably eleminated an air leak into the fuel system that could have been your problem all along. |
bsmotril
posted 07-16-2003 08:06 PM ET (US)
If the problem comes back and you want to replace the fuel pump, it is an easy do it yourself job. It is a simple rubber diaphragm under a cover plate. The part is inexpensive and takes about 20 minutes to make the change. BillS |
videorov
posted 03-06-2006 07:27 PM ET (US)
Be sure to check you connector on your motor. I had the same problem and it was the connector. If I wasn't carfule how I put the fuel line on with connector I would not get a clean conection. The center stem on the connector on the engine where you connect the line was loose because the little cap the keeps the pin in the center came out. You might check that.Jack 115 Yamaha |
Liteamorn
posted 03-07-2006 11:58 AM ET (US)
Sounds like a fuel pump to me, an easy way to check these are to loosen the mounting bolts (no need to remove them)GENTLY pump the ball and if gas leaks out of the back of the fuel pump it is bad. This is a common problem with Yamaha's and is relatively cheap to fix (and easy)no need for a mechanic for this job.ps You should have 2 fuel pumps. |
Liteamorn
posted 03-07-2006 11:59 AM ET (US)
Sorry I should have looked ,this thread is a few years old. How did this get dug up? |
posted 03-07-2006 01:57 PM ET (US)
This three year old discussion was revived by the first or second contribution from new user videorov who must have discovered it via some search engine, perhaps our own fine search engine on the website itself, or through the extraordinarily fine granularity with which the website is indexed by the premier web search engine, GOOGLE. The old age of the discussion was perhaps not noticed and it bubbled to the top when a new reply was added. |
MyOutrage
posted 03-07-2006 02:28 PM ET (US)
Old or not, it's still valid and relevent as spring approaches. I know I read through the whole thread and probably wouldn't have noticed it's age till I got to Liteamorn's post. |
posted 03-07-2006 09:03 PM ET (US)
While reading the description of the problem, the cause that came to my mind was a faulty accelerator pump on one or more of the carburetors. |
MyOutrage
posted 03-07-2006 10:52 PM ET (US)
I hope never to have to refer to this thread again but I'm glad to know it's here (Yes, I do own a late '80s Yamaha) |
capedave
posted 03-08-2006 08:24 AM ET (US)
In my line of work I have been finding that the needles and seats are swelling and throwing the float levels way of witch lead to a fuel starvation cant get enough in the bowl. A lawnmower surging while running is normaly an indicator of this condition. Is the neadle or seat included in the Yamaha carb kit??Face it fuel today sucks!!! And we are buying it,and paying the mechanics to repace carb components way to soon...... Dave |
