Topic: Stainless Steel Disc Brakes for Trailers
peteinsf |
posted 03-15-2004 07:49 PM ET (US)
Hi All,What do I need to know before ordering stainless disc brakes? Best source? Hub type? Size? Pete
Royce
posted 03-16-2004 01:41 AM ET (US)
Use the Kodiak disc brakes. They are ventilated like a truck disc. You can buy them through Century Tire and Wheel. If you have the 5 hole plate on your axle you can use 12" brakes. The 4 hole plate takes the 10" brakes. Google Kodiak and go to their website. royce |
posted 03-16-2004 07:15 AM ET (US)
This is rather funny: I spent about ten minutes searching on GOOGLE.COM for the Kodiak Brake website. I never did find it. Finally I downloaded a catalogue PDF from another website that happened to include some information about Kodiak's website. They are not very visible on the web via searching.I'll save you the ordeal: http://www.kodiaktrailer.com/ Kodiak brand brakes seems to have come on the radar screen recently in a big way. They are getting a lot of mentions in magazines and forums. Previously there was more buzz about Tie-Down Engineering, but now the talk seems more about Kodiak. I don't have experience with either. I just thought I'd save you ten minutes of searching on GOOGLE.COM for their website. |
posted 03-16-2004 07:20 AM ET (US)
To follow up to my own post: that Kodiak website is very well done! If their brakes are that good, they'll be excellent! |
peteinsf
posted 03-16-2004 08:43 AM ET (US)
My goodness Jim,That is a web site, the most information I have ever seen on disc trailer brakes! Normally Tie-Down just has a 1/2 page basic sheet... Great, I am sure someone on here will have these installed on their rig... |
Royce
posted 03-16-2004 09:26 PM ET (US)
Pete- I recomended them because I installed 12" Kodiak brakes on my trailer for my Outrage Cuddy 25'. The are built well and they work flawlessly. Buy the e-coated discs with the integral hub assembly and the stainless steel caliper set. I was able to tow and stop my Outrage with a Toyota Tundra--I was never pushed--in fact , my trailer had more braking capacity than my Tundra. Highly recommend them! Royce |
peteinsf
posted 03-17-2004 10:22 PM ET (US)
Royce thanks, They look very well made! What drove your e-coated selection. Why not get the Stainless disks? Their web site seem to only have the wheel-end, what type of surge coupler setup are you using? Pete |
Royce
posted 03-18-2004 12:27 AM ET (US)
Pete- I talked to the engineers at Kodiak. They recomended the e-coated disc because the stainless disc is not offered with an integral hub assembly. With the integral disc there is very little run out when assembled--run out means hot brakes. They also indicated that they only sell stainless discs in very caustic applications. I used the new Attwood 8,000lb. brake actuator with the integral back-up pressure release solinoid. Royce |
peteinsf
posted 03-18-2004 02:23 AM ET (US)
OK, I'll have to give them a call. I wonder what "very caustic" means to them (boating in Love Canal, NY)? Being in San Francisco the brakes will only be dipped in salt water...But I am glad that their working, these drums have been a nightmare and I have trips planned to Seattle later in the summer. Last time I tried that I had overheated drums lock-ups, ahhhh
Backlash
posted 03-18-2004 07:48 AM ET (US)
Pete,Whichever disk brake you choose, Kodiac or Tie Down, they will be a significant improvement over your drum brakes. The Kodiac's appear to be the premier disk brake, but I have been very happy with my Tie Downs the last few years. Make sure your actuator is suitable for disk brakes...I see most manufacturers offer a model for each. BTW, Overton's seems to have the best prices on Tie Down. Steve |
peteinsf
posted 03-19-2004 12:21 PM ET (US)
OK I spoke with the folks at Kodiak, his concern was that the ss-discs are so expensive that if you run that pads down people get upset about the replacement cost $200+ per disc.He said the e-coated was not normally used in salt environments but the silver cadmium plated rotor with a stainless steel caliper is what they recommend for salt water customers. Here is the cost breakdown 100% Stainless: 1) Break/Caliper kit; $585 per axle 2) Spindle, seals etc; $36 per wheel. Silver Cadmium: $310 per axle Does anyone have silver cadmium plated rotors (in salt)? Is it worth that extra $600 for all stainless? The next step is to remove one of my existing wheels to match up the seals… Pete
Royce
posted 03-22-2004 08:39 PM ET (US)
Pete- I looked up my receipt. I was incorrect in advising E-coated--I used the silver Cadmium coated discs. The part # for 12" brakes(integral hub) with Stainless Steel rotor kit is 2/hrCm-12-SCADsS and the price I paid from Century in Hayward was $241.00 per axle set. Bearings and seals are extra.Hope this helps. Royce |
peteinsf
posted 03-23-2004 12:06 PM ET (US)
Thanks Royce,The E-Coated did seem a bit off... How long ago did you buy them? Century Hayward gave me the posted numbers, I can't beleve it went from $241 to $310 quickly in this market? Maybe you can fax me the recept before I head over there... Pete |
LHG
posted 03-24-2004 04:39 PM ET (US)
Tie Down has a brand new, greatly improved alum/SS Disc brake system just hitting the market now, complete with vented rotor. Might be worth looking into. Continental Trailer is going to be offering them on their trailers soon. |
Royce
posted 03-24-2004 10:08 PM ET (US)
Pete- I buy wholesale. $310 is fair. royce |
peteinsf
posted 03-30-2004 07:29 PM ET (US)
Thanks Larry,Do you know where I can find the new Tie Down information on the web? Pete |
larimore
posted 08-19-2007 12:53 PM ET (US)
I got the Kodiak s-cad brakes for my trailer after bad(short) experiences with tie-dowd SS and drum brakes. Initially I was impressed. I use my boat every month or so in salt water. In the past my brakes lasted 1.5 years. These lasted 2.5 years. Warranty is for 3 years. So I called my supplier - Warranty does NOT cover corrison !!! Can you believe that - Whatelse goes wrong in salt water.I'm now looking at both Tie-Down and Kodiak. The Kodiak SS is way too much for me. Kodiak SCad Problems- Mis-leading warranty Rotors rust when sitting out of use for extended periods Brake pads rust very quickly(auto pads) Must repack bearings each installation Tie-Down Advantages Stainless rotor Aluminum caliper Prepacked bearings I'm going to give Tie-Down a second try after 5 years. They are easier to install(important!) and appear to have better potential.
