| Author | Topic: Raising Transom to 20-Inch |
| thebulkinator |
I've a 1968 Whaler 13-foot boat that has a 1978 Johnson 2-stroke 30 on it. I've been looking at getting a new or slightly used outboard in the 25-40 horsepower range that is remote (non-tiller) and would fit it. But I have a problem: I don't think any manufacturers make a 15-inch shaft engines anymore. I think I saw a way to raise the transom on the boat 5-inches, but can not remember where. I thought this would be a good place to ask. Also any suggestions on rigging the new motor would be very helpful. Any motors that would be good for this application. I'd like to keep the cable steering but would like to know the other alternatives. Any pictures or websites would be VERY helpful. Thank you all for your responses, Ben. |
| andygere |
Don't [attempt to modify the transom height]. Nissan/Tohatsu still makes a 40-HP 2-stroke and direct injected 2-stroke in 15-inch shaft with remote control, electric start and power tilt and trim. The other manufacturers seem to have abandoned this configuration for some reason. |
| Jarhead |
In their 2003 and 2004 catalogs Mercury lists the classic 40- and 25-HP engines as 15- and 20- inch shaft, remote or tiller, electric or manual start. Would one of these fit the bill? |
For one method of adapting a 20-inch shaft engine to a 15-inch transom height, review the Cetacea Page 56 article: That Elusive Smell of Forty Year Old Wood For details of conversion to cable steering on an older 13-foot hull where the curved transom requires a special bracket for installation of the cable steering, consult Cetacea Page 57: [57 Varieties? |
| andygere |
The classic Mercury 40 does seem to be available in 15" with tilt and trim as an option again. The 15" was not available with tilt and trim for several years. At 204 lbs. for the lightest version (not including the tilt and trim) I think the Mercury is too heavy for a classic 13. The Tohatsu is only 158 lbs. for the lightest version, a huge difference on the transom of an older 13 foot Whaler. |
| Mullet |
I have a Merc 40 on a 1968 classic. The weight doesn't seem to make it sit any lower but it will fly. I did change out the old pulley steering system. thebulkinator, get a 15" motor of whatever brand but don't try to modify that transom. They can be built up and you can also use a jackplate but jackplate = more money, more weight, not original. Just my .02. |
| 13dave |
i raised the transom on my whaler 13 and it worked out great.i now can use long shafted out boards and the transome never floods when throttling down, i would say raise it but make sure that you enforece it properly. |
Also in the Reference Section is this link: Rebuilding 13-foot Classic: how to raise the transom to 20-inches on an older hull (off-site link). |
| keltonkrew |
I built mine up out of mohagany, with SS embedded inside. I hope to have some pics up later in the week ------------------------------------------------------------ |
