ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods VRO Warning Buzzer and Diagnosis
Author | Topic: VRO Warning Buzzer and Diagnosis |
rumrunner |
posted 08-17-2004 07:26 PM ET (US)
I've researched the archives in regard to OMC VRO systems, and found a lot of info in regard to this topic. But maybe somebody could clear up a few basic questions in regard to a 1986 Montauk with 1986 Evinrude 90-HP. I just started to get a continuous warning from the buzzer. My understanding is that there are only two alarm combinations, the "no oil" warning (continuous), and the "low oil" (intermittent). Is that correct? I don't believe there is a problem with the VRO (probably wishful thinking on my part), but I seemed to get the usual slight blue smoke output during the period of time (three minutes or so) that the engine was running when the alarm was going off. I plan to go thru the OMC troubleshooting procedure tomorrow. The manual is somewhat vague on some VRO problems, so I thought I'd throw it out here.<>Does the "no oil" sensor detect a lack of oil at the engine itself, or is it located at the VRO tank proper (center console)? I would assume that either way, the sensor would detect a "no oil" situation as a result of a clogged line. Should the alarm normally sound while going thru the start procedure (key in ignition while engine is cranking, prior to combustion)? This one rarely does. Is there a filter in the tank on the oil line? I'm aware of the VRO argument and the two lines of thinking in regard to this topic (connect vs. disconnect). This is not the original VRO pump; it was replaced in 1989 by the previous owner. |
holiberry |
posted 08-17-2004 11:26 PM ET (US)
When you start your engine you will get that blue smoke from fuel left in the system, however you know the argument on use vro or not. i use one but am always told by mechanics to mix my own because of faulty alarms not catching it. also be aware of sensors indicating insufficient water flow(overheating) especially with johnsons. you should test your sensors as they can be bad. also may be an indication the your electrical system may be going out(rectifier,powepack) just a thought.these kind od things generally happen when one starts to go bad. are your gages working properly? these are all signs of an electrical problem(maybe?) hope this helps |
where2 |
posted 08-18-2004 12:00 AM ET (US)
The VRO tank in my garage collecting dust has a float sensor in it that tells the control box when the oil level is low or getting low... Unfortunately, if they ever added a sensor at the engine, it took some time to do that, and I suspect 1986 was too early in the evolution to get that. Does your tank have a wire attached to it?? My 1985 OMC service manual describes the tank as having a 10' oil hose and 12' of electrical wiring for the low oil level warning. Low oil warning (beeping) sounds when the level drops to 1/4 tank. I premix and save the space in the boat... |
dt stansell |
posted 08-18-2004 12:18 AM ET (US)
I had a 1986 90hp Johnson that was rebuilt in 1992. The VRO was removed. Never had a problem with lubrication. The engine still runs strong. I bought the oil to gas ratio bottle from west marine, made measuring the oil a snap. |
seahorse |
posted 08-18-2004 07:14 AM ET (US)
When you say continuous alarms, are they continyuous tones or an on and off sound, about 1 second apart? Continuous tone is an overheat, or flakey electronics in the system. For VRO info and troubleshooting click on: http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=36;t=000028 |
newt |
posted 08-18-2004 08:01 AM ET (US)
The following is based on the shop manual for a 1990 Johnson: A continuous alarm means either an overheat condition or a fuel restriction. NO oil would be a continuous beeping 1/2 second on - 1/2 second off. Low oil would be a beep every 20 seconds. The sensor for low oil is in the tank. The sensor for NO oil is at the fuel/oil pump. Temp sensors are on top of the powerhead, and fuel restriction sensor is a vacuum gauge near the fuel pump. If you let your engine cool down and the alarm goes off, then you are having a cooling problem. If the alarm still goes off when the engine is cool, then you have a fuel restriction. I have just read up on the alarms after spending 45 minutes on the water drifting around trying to figure out why I had a continuous alarm going off. At the time, I was not familiar with the alarms. I finally figured it out when the engine would not start. First thing I did was check temp gauges and pissing stream. Both OK. Then checked oil in tank. OK. I had plenty of smoke from engine, so I at this point I was stumped and about ready to disconnect horn, and limp home. Then, the engine wouldn't start. I Checked bulb and it was flat. Drained fuel filter and then could not get it filled back up. Blew air back thru fuel line into tank and felt no resistance, so I bypassed the filter and problem solved. Turns out my filter was way over due for a change. When I got home, I spent a couple hours reading the shop manual! |
whalercop |
posted 08-20-2004 05:41 AM ET (US)
There is much debate about the vro question. After my rebuild, which my mechanic said he thought it was due to the vro failing, I removed all of it and just mix it, never have to wonder if the motor is getting oil or not. I believe my alarm went off as the motor went into the slow feature, it was already too late. It locked up immediatley, and $1200 later, I learned my lesson about the variable ratio oiling. It reminds me of an idiot light on a car without guages- when it comes on, it's already too late. Good Luck! I will never trust the vro's again. I would buy one of these motors again, I trust OMC, I just don't trust the expensive vro systems. I would remove it first thing and mix it and never worry about it again. |
Joe Kriz |
posted 08-20-2004 03:55 PM ET (US)
Under NO circumstances would I even think about disconnecting the VRO system. It is a very simple system that RARELY, if ever, fails. It is usually the mechanics lack of knowledge speaking when they say it is the fault of the VRO system or the operator uses cheap, or non-recommended oil in the system. Here are several threads on how well the VRO system works. http://continuouswave.com/ubb/Forum4/HTML/000252.html http://continuouswave.com/ubb/Forum4/HTML/000814.html There is another great article stating that most mechanics always blame an engine problem on the VRO system but I can't seem to locate this article at this time. |
Joe Kriz |
posted 08-20-2004 04:06 PM ET (US)
http://continuouswave.com/ubb/Forum4/HTML/000252.html http://continuouswave.com/ubb/Forum4/HTML/000814.html Newt has given you the correct info on the alarm sounds. The alarms should not sound when starting the 1986 model. I believe the sounds when starting, started in 1996 with the introduction of the "System Check" system. There is a filter in the bottom of the VRO oil tank. It sounds like you may have air in your oil line or some of your sensors are going bad. |
WyldeLee |
posted 08-20-2004 05:31 PM ET (US)
Can you suggest an article or refernece regarding proper maintenance of the VRO system (60hp 3cyl evinrude)? |
Joe Kriz |
posted 08-20-2004 05:40 PM ET (US)
Here is the article that was written by JB on another forum. (He is also a member here for those of you that don't know). http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=36;t=000028 |
newt |
posted 08-20-2004 08:26 PM ET (US)
Joe, I have read that article and hope it's all true. No pre-mix for my big Johnson. Ramrunner (if you are still there), nothing you have described indicated a problem with your VRO. Your constant alarm indicated either a fuel restriction, overheat, faulty horn, faulty temp sensor, or faulty fuel vaccum sensor. |
Jerry Townsend |
posted 08-20-2004 11:45 PM ET (US)
I have a '96 115 HP OceanRunner - and have never had any problem with the VRO system. My problem is me - as my hearing is not too good at some frequencies due to a few close explosions et.al.. Anyway, I can't hear the buzzer and will modify the buzzer system on my boat - make it louder or change the frequency. I can make my own - but does anyone know of a ready-made system that is available? ---- Jerry/Idaho |
Peter |
posted 08-21-2004 06:59 AM ET (US)
I ran a 1987 150 Johnson for 10 seasons with not a single VRO pump problem. Only maintenance performed was to replace the filter screen on the end of the pickup in the VRO tank at the beginning of every season. |
seahorse |
posted 08-21-2004 02:05 PM ET (US)
Jerry, Your 1996 outboard should have the System Check gauge and 4 warning lites for different malfunction warnings. The horn will sound for 10 seconds and the appropriate lite should remain on until the problem is corrected. If you have a 1995 or earlier motor that uses the 4 wire "VRO" pump, you can buy a retrofit kit and gauge for your outboard. That way you will have a bright red LED illuminating what the malfunction is.
ENGINE TEMP |
posted 08-21-2004 02:19 PM ET (US)
I have a 1992 Evinrude Model E225TXENR. There does not appear to be any "System Check" warning system. Is this engine one that can be retrofitted with the four lamp indicator system? |
Joe Kriz |
posted 08-21-2004 03:20 PM ET (US)
jimh, The "System Check" system did not start until 1996 for Johnson. I am not aware of anything you can add to make it the System Check system but check with your dealer to be certain. |
Jerry Townsend |
posted 08-21-2004 03:52 PM ET (US)
seahorse - thanks for the information. I have the alarm system with the lights and the check-out feature works properly. My problem is with my hearing - and as such, one of the first things I do is remind the others on board that if they hear the buzzer (which I cannot hear) to let me know. I'll have to modify my alarm system - or get hearing-aids - a minor problem. ----- Jerry/Idaho |
seahorse |
posted 08-22-2004 07:49 AM ET (US)
jimh and Joe, Re-read my previous post. You CAN retrofit the System Check warning and indicator lites to your motor as long as you have a 4 wire VRO pump. |
seahorse |
posted 08-22-2004 07:50 AM ET (US)
rumrunner |
posted 08-22-2004 10:01 AM ET (US)
seahorse- Would you happen to know OMC part number for that light kit? The pump on my 1986 Evinrude is a 1989 "VRO2", and while I haven't checked yet, I believe it is a 4 wire type. My troubleshooting has isolated the likely problem (see original post) to an intermittent contact problem on the low oil float plunger in the oil tank itself. While I continue to pinpoint the problem, I'm going to hand mix the fuel with a 50:1 oil mix. Anybody see a problem doing that while I still operate the VRO? Thanks for all the info, a lot of good comments have turned up here. |
rumrunner |
posted 08-22-2004 10:35 AM ET (US)
Just checked the VRO2. There is a 2-conductor "zipcord" type wire from the tank to the engine. Is this the wire you are referring to when determining whether you have a "2-wire" or "4-wire" VRO? Maybe I won't be able to add the l.e.d. lights after all. |
seahorse |
posted 08-22-2004 01:46 PM ET (US)
Look at your fuel:oil pump assembly and trace the wires from it. On your oil tank, if the electronics in the pickup assembly get flakey, you can disconnect the "zip cord" terminals at the motor, and then visually check your oil level often. If you do install the SystemCheck warning kit, you will get a new oil pickup, and there are NO electronics in it, just a switch that closes when the oil gets low. I'll get part numbers for y'all when I can. |
Joe Kriz |
posted 08-22-2004 02:43 PM ET (US)
seahorse, Thanks for the info. I would be very interested in converting my 1985 Evinrude 150hp but it looks like I only have 3 wires going to the VRO pump. 1. Purple (Power) I assume I have the older style VRO pump? Bummer... Where does the 4th wire come from and what is it for? The "Low Oil" and "No Oil" which is already built in the buzzer alarm sounds, should also activate the corresponding lights if hooked up properly? This is also an assumption. Any further info would be very helpful. |
seahorse |
posted 08-22-2004 04:04 PM ET (US)
Joe, You will have to buy ($270) a new VRO to make the system work. It wouldn't be a bad idea anyway, since you have a very old pump at the moment with a questionable warning system on it. The 4th wire (purple) in the new pumps is for the 12 volts used to power the electronics in the warning system. It is a lot more reliable design. |
Joe Kriz |
posted 08-22-2004 04:36 PM ET (US)
seahorse, I already have the purple wire. I have 3 wires coming from a harness that plugs into the VRO pump. Because I already have the purple wire (12v), what color wire am I missing that the newer style has? And, what does the wire do that I am missing? I will probably have time to visit my Bombardier dealer on Wednesday and ask him a few questions also. Thanks, |
Joe Kriz |
posted 08-22-2004 04:46 PM ET (US)
One more item. I replaced my Oil Tank last year with a brand new one. (Non-System Check) I tested both the Low Oil buzzer and the No Oil buzzer when I installed it so I know the buzzer alarms are working. I also tested both Thermostat (Overheat) buzzers at that time too so I know these buzzers both work. (actually same buzzer) Prior to owning my 1985 Evinrude 150hp which was used, I owned a 1985 Evinrude 70hp with VRO since it was new. I owned the 70hp for 15 years and never had any problem with the older VRO system. I never changed the filter in the Oil Tank because I never knew there was one there until recently. |
seahorse |
posted 08-22-2004 07:03 PM ET (US)
I had to re-read your post. I'm confused with your response, you say there are only 3 wires and one is purple. The 4 wire VRO has black, tan, gray, and purple wires. The old style 3 wire pump has black, tan, and gray wires. These are wires that exit the pump itself. |
Joe Kriz |
posted 08-22-2004 07:19 PM ET (US)
seahorse, Upon very close inspection, here is what I found.
These 4 wires then go into a plastic tube (wrap or cover) and at the other end of the tube only 3 wires come out and are connected to a rubber plug that plugs into it's respective plug-in. I have no idea where the Black wire connects to so I assume that the Black wire is connected to one of the other 3 wires inside the tube? Maybe not? Maybe it is not connected to anything and ends inside the tube? I can't pull the tube enough one way or the other to see what the Black wire is doing. If you can tell me what the Black wire is connected to, this will help. Or, what it is supposed to be connected to? For the Record, I have a 1985 Evinrude 150hp which apparently came original with the VRO2 system. Does anyone know for sure when the VRO2 system started? This might help other people in the future. Thanks again, |
Joe Kriz |
posted 08-22-2004 07:55 PM ET (US)
I re-read JB's post and saw that the VRO2 started in 1986. Interesting, as I have the VRO2 system in my 1985. |
seahorse |
posted 08-23-2004 07:31 AM ET (US)
The System Check retrofit kit is #176709 for about $226. The book says it fits back to 1991 motors, that was the first year of the 4 wire VRO pumps, and it should work on all motors with the latest pumps. Joe, your motor must have been jury rigged or played with by someone who wasn't familiar or trained in the wiring system. Your 4 wire VRO harness should connect to a round rubber 4 wire connector, called an Amphenol connector. From there, the tan, black, and gray wires go to the main wiring harness, and the purple wire should be attached to the terminal board. If yours is not this way, find a QUALIFIFED person to get it right for you. here is your wiring code: Good luck to you. |
seahorse |
posted 08-23-2004 07:32 AM ET (US)
I forgot to mention that when you install the System Check kit, you will also need either the 2" 4-lite warning gauge or the System Check tach with built in lites. |
rumrunner |
posted 08-23-2004 08:56 AM ET (US)
Seahorse and company- You have answered many questions for me since my original post, I appreciate it. The Evinrude manual is a disappointment to say the least. Not very well-written. What I have determined is that I have a 3-wire 1989 VRO2 (a replacement of the original 1986 VRO), and my buzzer issue does not seem to be related to the VRO. However, I'm running a 50:1 mix to play it safe until I figure this out. |
Joe Kriz |
posted 08-23-2004 12:55 PM ET (US)
seahorse, I NEED NEW GLASSES............. You are correct. The Black wire does go into the Rubber connector. (Amphenol connector). The Black wire was very hard to see as it was in and behind the other wires. My VRO pump has been updated somewhere down the line as I have a 1985 motor that has the 4 wire VRO2 pump and wiring system. Thanks for all the great information. |
newt |
posted 08-23-2004 01:25 PM ET (US)
Rumrunner, I will try this one more time. Forget the VRO for a moment. If your '86 is similar to my '90, then a continuous alarm indicates either: 1. Temperature problem. Does the alarm sound when the engine is cold? Does it sound only at wide open throttle. Have you checked your fuel filter(s)?. Was the fuel primer bulb soft when the alarm went off? Tell us more about what makes the alarm go off, and what you have tried so far in terms of diagnostics. The Johnson/Evenrude SERVICE manual has plenty of info on diagnosing warning alarms.
rumrunner |
posted 08-23-2004 02:47 PM ET (US)
newt- Thanks for the response, and the guidance in terms of looking past the VRO as the source of the problem. I tend to be paranoid when it comes to the VRO, despite never having a problem with it. With that said, I do understand the continuous buzzer is indicative of: 1) fuel restriction 2) temperature issue The fuel filter is fine, and there is no apparent fuel restriction as the engine is not fuel starved when the buzzer is going. Bulb is fine when the buzzer is on. |
Joe Kriz |
posted 08-23-2004 04:01 PM ET (US)
rumrunner, The only thing I can think of pertaining to the continuous sound of the buzzer when the key is just turned on is that one of the Thermostat overheat sensors is making grounding out and sounding the buzzer. One way to check this is to disconnect both (or one at a time) Thermostat overheat sensors. The sensors have tan wires coming out of them with a "Knife" terminal covered with a rubber boot. Turn your key on and if the buzzer is sounding, dissconnect one of these at a time and see if the buzzing goes away. Good Luck. |
rumrunner |
posted 08-23-2004 04:17 PM ET (US)
Joe, I did such (seperately disconnected each sensor) during the troubleshooting process, and the buzzing continued. The temperature sensors were installed last season. |
newt |
posted 08-23-2004 04:22 PM ET (US)
Rumrunner, I can appreciate your frustration...the sound of that warning horn is not pleasant. If you email me with a fax #, I will photocopy and send you the applicable troubleshooting steps for the horn and the sensors from my service manual. At least that way, you can systematically work your way through the problem. In your last post you asked if there was any condition that would cause the alarm to sound without the engine running. I can tell you that when I had a problem with the fuel restriction, the alarm DID sound with the key on and engine NOT running. At the time, my fuel bulb was flat, so I suspect that there was still a vacuum in the fuel line. |
Joe Kriz |
posted 08-23-2004 05:05 PM ET (US)
I love a good mystery. But, I know this can be frustrating for you as newt mentions. We seem to have eliminated the Overheat sensors when you disconnected them and you still got the warning buzzer. I think we are getting a little closer to the problem. As newt again mentions, fuel sensor. Locate the fuel restriction sensor and disconnect this TAN wire and see if the buzzing goes away. If this doesn't work, then maybe: |
rumrunner |
posted 08-23-2004 05:59 PM ET (US)
newt- I'll send you my fax #. I'll be out of my office for a few days, so I'll wait until I'm back there to send it. I am utilizing the 1986 Evinrude/Johnson Service Manual for the engine, and I'm not sure if what you're referring to is different from that. Joe- re the "fuel restriction sensor". What is the physical location of it? The only reference in the manual to it that I've found is a picture of it (not attached to engine), saying that some models are equipped with it. Since I'm not experiencing any overt problems with the engine indicative of a fuel restriction problem, I'd like to verify that the sensor itself is functioning properly before chasing ghosts in the fuel system. Is there a way to test the sensor itself first prior to going thru the whole fuel system test (vacuum gauge) as described in the manual? |
rumrunner |
posted 08-23-2004 06:03 PM ET (US)
You already answered the question I asked- disconnecting the tan wire should silence the buzzer. I'll let you know if that does it (as soon as the buzzer starts in again). |
posted 08-23-2004 11:10 PM ET (US)
On the OMC Shop Manual V-6 wiring diagram, what are the following unidentified gizmo's which are associated with the tan wire that is the ALARM lead: (my guess in parenthesis) --lower left corner, tan wire and black/white wire connect to gizmo; case of gizmo is grounded. (Oil Tank Level Sensor?) --center middle, tan wire connects to gizmo under starter solenoid; black wire from gizmo to ground. (Fuel Vacuum Sensor?) --left middle, tan wire connects to something just below main connector plug; does something plug in here? (No guess!) I have deduced that the other unidentified gizmo is probably: --lower right; engine cylinder head temperature sensor; tan wire connects to it; case is grounded. (But aren't there two of these? One for each cylinder head?) These OEM drawings leave quite a bit to be desired in terms of labels! |
newt |
posted 08-24-2004 08:08 AM ET (US)
JimH, So I'm not the only one scratching his head tryng to interpret that wiring diagram! At least my engine (150 hp, 9 amp charging circuit) is a little simpler. There are only tan wires - no black and whites - to each of the sensors. Your unidentified gizmo must be the NO OIL sensor built into the VRO pump. The diagram for my engine shows two temp sensors wired in parallel. Each sensor has a ground symbol attached but no additional wires (blk/wht). I wonder if the additional wires you see are related to the SLOW feature? Rummrunner, I would follow Joe's advice, and pull each tan wire until you find the offending sensor. Good luck! |
rumrunner |
posted 08-24-2004 09:28 AM ET (US)
Bear with me here guys, but I'm having difficulty in physically locating the fuel sensor. I don't see anything that looks like the part photo in the manual. The wiring diagram supplied w/ my manual is "vague", to say the least. They certainly didn't get hung up on details! |
seahorse |
posted 08-24-2004 06:09 PM ET (US)
Rumrunner, Only the V6 motors had the vacuum switch for the fuel restriction alarm. |
rumrunner |
posted 08-24-2004 10:21 PM ET (US)
seahorse, Thank you, I was starting to really doubt myself. So any idea what triggers a fuel restriction (continuous buzzer) on the 90 hp V4? Spent the whole day on the water, with no buzzer. That's good news, of course, but doesn't help me solve the mystery from the other day. |
seahorse |
posted 08-25-2004 03:12 AM ET (US)
What I am saying is that your V4 does not have any type of fuel restriction alarm or sensor or vacuum switch. Only the V6 models do. |
rumrunner |
posted 08-25-2004 05:30 PM ET (US)
Seahorse, Thank you. So, in absence of the sensor, any guess as to what the continuous buzzer is supposed to indicate? Shop manual only alludes to overheat for continuous buzzer, but if this is not equipped, then what does it mean!?!? I only have the generic 60 thru V6 manual, and do not have the operator's manual. |
BMack |
posted 08-25-2004 05:54 PM ET (US)
I replaced the warning horn for my 1987 150 Johnson VRO. OMC has updated the horn part several times. The old horn was partially melted and gave false alarms usually at much less volume then a normal alarm. Part of the problem turned out to be the bad VRO tank sensor. I disconnect the VRO and removed the tank. Added a second battery where the tank was mounted and premix. The two overheat sensors still operate and can be easily tested by disconnecting. The connection to each sensor has a rubber sleave. Pull back the sleave and disconnect the sensor (alarm should sound). Also, you should get a quick beep when you turn the key. This did not happen until I replaced the warning horn. Goodluck |
posted 08-25-2004 06:11 PM ET (US)
The advice given above is not correct. The overheat sensors trigger the alarm by connecting the tan wire to ground. If one disconnects the tan wire from the overheat sensor the alarm will not sound. The factory service manual explicitly instructs a test of the alarm to be made by disconnecting the tan wire from the overheat sensor and grounding it to the engine chassis to trigger an alarm. |
newt |
posted 08-26-2004 08:40 AM ET (US)
Rumrunner, Sorry to have led you on a wild goose chase with the fuel restriction sensor. It sounds like either the temp sensor triggered, or maybe you have an intermittant short circuit in the tan wire that made contact with a ground. Is it possible you picked up a bag or weeds on the water intake? If it were me, I would check the temp sensors to make sure they closed at the correct temp (as outlined in the manual), and if they check OK, keep running the engine until you get the alarm again. |
BMack |
posted 08-26-2004 02:54 PM ET (US)
Sorry, I forgot to add ground the connection to the block to trigger the alarm for each head sensor. The point is that the horn may be bad. Also, the VRO oil tank level sensor may be triggering the horn intermittenly. |
where2 |
posted 08-29-2004 10:14 PM ET (US)
When I had the alarm beeper fail in the continuous BEEP mode, I finally disassembled the control box and found that simply applying 12v to the buzzer made it sound continuously (whether or not the wire that was supposed to go to the temp sensor or the oil sensor was grounded!). A phone call and a trip to the parts supplier found one in stock. $60 later, I had a new buzzer and no more continuous beeping sound... They do occasionally fail in continuous BEEP mode. Although I really expected it was a wiring fault grounding out somewhere. Fortunately, it was at the source of that annoying noise. |
hiram |
posted 04-21-2006 11:24 AM ET (US)
Greetings! Question, I'm not trying to re-open the vro connect / disconnect issue. I've decided to keep my vro. Is there a way to retrofit the vro oil tank intake with a larger filter screen? The existring one I have has a small cone shaped screen the snaps into the end of the pick up line. It plugged yesterday with some sort of "green snot" the virtually shut off the oil supply, sounded that no / low oil alarm and nearly caused my heart to stop. I've heard that there is a much larger filter for the oil intake line but can't seem to verify. Anyone out there who can point me in the right direction? Thx hiram |
