posted 09-19-2009 02:01 AM ET (US)
Thanks for the replies. This is the type of info I was hoping to get. I have a few more questions to be sure I understand it. Clark Roberts: "your motor idles on timing only!"
Yes I read that in the service manual but my knowledge originates with cars. On my old VWs if you change the timing by rotating the distributor the car will run badly or not at all. That is why I haven't adjusted the idle timing screw. I thought it might affect the outboard the way rotating the distributor affects a VW. But it won't affect it that way correct?
The motor is idling at 900 RPMs and the manual says Carburetor idle speed should be 675 plus or minus 25 RPMs. So it is definitely idling high.
Is it okay to adjust the idle down to 700 RPMs with the idle timing screw?
LHG:
My Mercury service manual says: "slide shift actuator toward rear of engine until resistance is felt" Is that "resistance" what you mean by preload? By "shift connection" do you mean where the "cable end" connects to the "shift actuator"? Therefore to increase the space the barrel is adjusted toward the front of the engine. Correct?
When the service manual discusses checking shift cable adjustment it mentions a "cable end guide" but the diagrams do not show a "cable end guide". Is the "cable end guide" the same as the "mounting stud" on the "shift actuator"?
Is it correct that if the idle is set too high then the barrel adjustments will not eliminate the grinding?
Thanks to everybody again for helping me understand how this works.
