  The Big Deal About RING FREE Fuel Additive
Author Topic:   The Big Deal About RING FREE Fuel Additive
PeteB88 posted 08-09-2006 01:20 AM ET (US)   Profile for PeteB88   Send Email to PeteB88
I have been using SEA FOAM Motor Treatment in my 40 Yamaha for sometime now - maybe 10 tanks of gas. I can only correlate excellet results.
The Yamaha outboard motor ran quite rough when I first got it last year and I admit I was worried. It started instantly and ran great WOT but rough low and mid.
I did a compression check which was well within specs. Then I worked through trouble shooting, did Sal's decarb procedure, changed to Yamalube (major positive results) and, of course, new plugs. I also spent considerable time shooting Deep Creep into the carbs and all that.
Every tank of gas I have run through that motor has had SEA FOAM Motor Treatment added. At the beginning of this season I was still very concerned about rough running in mid power settings. However, I am here to tell you all this motor has consistantly run better with every tank of fuel and now runs great. I attribute most of that to Yamalube but not sure.
What about RING FREE Fuel Additive?
I have been intrigued by RING FREE Fuel Additive - had somebody go on and on about it a couple of weeks ago. What is the difference between RING FREE Fuel Additive and SEA FOAM Motor Treatment? I'd like to know.
I have considered going to RING FREE Fuel Additive for a few tanks--what the hay?
I am interested in your experiences and wisdom.
THX
88
bsmotril posted 08-09-2006 03:29 PM ET (US)     Profile for bsmotril  Send Email to bsmotril
Well RING FREE Fuel Additive is about $36 dollars a quart and SEA FOAM Motor Treatment is about $6 a can. I use SEA FOAM Motor Treatment for my 50 hour decarb, but don't put it in the fuel. It works great for that application. I use RING FREE Fuel Additive when I purchase a new/used motor and give it the shock treatment dose for the first 12 gallons of fuel run through the motor. I do that in addition to a SEA FOAM Motor Treatment De-Carb. Other than that, I normally don't run any additives in the fuel. But if I did, I'd go with SEA FOAM Motor Treatment over RING FREE Fuel Additive Fuel Additive for regular (non-shock treatment) usage because of cost. BillS
PeteB88 posted 08-09-2006 03:42 PM ET (US)     Profile for PeteB88  Send Email to PeteB88
Thanks but in the real world does RING FREE Fuel Additive accomplish somethign that SEA FOAM Motor Treatment doesn't? I understand the dilution is something like one ounce/six gallons. Just trying to figure it out.
thx
Sal DiMercurio posted 08-09-2006 10:47 PM ET (US)     Profile for Sal DiMercurio  Send Email to Sal DiMercurio
I can't really tell you if one is better than the other but they perform the same purpose & thats to remove carbon & prevent it from forming again or slow it down.
They are both excellent products & have excellent reputations.
Sal
NJCoastFlyFish posted 08-09-2006 10:49 PM ET (US)     Profile for NJCoastFlyFish  Send Email to NJCoastFlyFish
I was told to use RING FREE Fuel Additive to keep my cylinders clean.
I switched from Yamalube to a generic brand of oil and noticed the engine is beginning to show signs of running a little rougher. I am going out before my next trip to get more Yamalube
jimh posted 08-09-2006 11:21 PM ET (US)     Profile for jimh  Send Email to jimh
SEA FOAM Motor Treatment:
http://www.seafoamsales.com/motorTuneUp.htm
http://www.yamaha-motor.com/outdoor/apparel/apscitemdetail/3/122/all/1/ 346/detail.aspx
