Experience with HONDA BF2.3 Outboard engine
Posted: Sun Apr 19, 2020 8:12 pm
by Maverick
Please tell me about your first-hand experience in owning a HONDA BF2.3 air-cooled lightweightoutboard engine. I have never owned a HONDA outboard engine.
BACKSTORY: I am ready to re-power a 17-foot Boston Whaler boat with a new main propulsion engine. I also want a small auxiliary engine that is lightweight and air cooled in order that when operating in shallow water the auxiliary engine won't suck up mud in the cooling system.
I have found a good buy on a new Honda BF2.3. a 30-lbs, air cooled. 20-inch shaft, outboard engine for $900 that will easily clamp on the the transom of a 17-foot Boston Whaler.
Re: Experience with HONDA BF2.3 Outboard engine
Posted: Mon Apr 20, 2020 11:28 am
by biggiefl
Double check [about water intake for cooling because] many air-cooled engines still water cool the exhaust, and therefore have a water pump.
I don't know for sure about the newer HONDA engines, but the older air-cooled engines were noisy.
Posted: Mon Apr 20, 2020 3:54 pm
by L78steve
The little air cooled Honda engines are fine engines. They are [made in China since c.2015 according to a NEKKEI news article].
Posted: Mon Apr 20, 2020 7:02 pm
by frontier
We have a 2015 Honda 2.3 HP long-shaft outboard engine used as an auxiliary engine on our classic Montauk.
The 2.3-HP HONDA engine is a good quality engine, but not as good as our Honda lawn mower. THe 2.3-HP HONDA engine is somewhat noisy. It is very lightweight and does its job.
I always use Sta-Bil and fresh gasoline. The tiny carburetor jets plug easily.
My HONDA 2.3-HP engine was made at the Honda outboard factory in Hosoe, Japan.
Posted: Tue Apr 21, 2020 8:22 am
by macfam
We have a Honda original 2-HP short shaft, not the 2.3-HP. For all practical purposes, they are the same. I only use engineered fuel in the little Honda, simply because of seldom use in our 9-foot-long inflatable. Placing the engine on the transom of the inflatable is easy; it only weighs 30-lbs.
I have not had any problems at all, but there are two slight concerns:
--the engine is AIR-COOLED, no water pump and therefore noisy, but bearable;
--if tilting out of the water, the fuel tank cap vent MUST be closed to prevent leakage.
Our HONDA 2-HP was made in Japan.
Posted: Tue Apr 21, 2020 8:26 am
by Maverick
Thanks for the feedback.
There are some knockoffs for $400 to $500, about half the price of the Honda, but I don’t mind paying more to get reliability--if that’s possible for any of these little aircooled engines.
Posted: Wed Apr 22, 2020 8:13 pm
by dtmackey
Mercury has been building outboards for years in China in the 60hp and below power ratings.
Posted: Thu Apr 23, 2020 10:14 am
by biggiefl
D--Most of Mercury's smaller engines are made by Tohatsu. Yamaha used to make them up until early 1990's.
Posted: Thu Apr 23, 2020 10:41 am
by dtmackey
biggiefl wrote:Most of Mercury's smaller engines are made by Tohatsu. Yamaha used to make them up until early 90's.
Clarification: Mercury outboard engines under 30-HP do share a relationship with Tohatsu. Mercury outboard 40, 50 and 60-HP are built in China at the Mercury manufacturing facility in Suzhou China with production at this facility dating back to 2005 .
Mercury also licensed designs of their smaller 2 strokes to other (non-Tohatsu) manufacturers in China that build Mercury clones (dating back to 1986) and I'm sure there's plenty of knock-offs being built as well.
Posted: Thu Apr 23, 2020 11:39 am
The topic of how TOHATSU makes smaller outboard engines for Brunswick to be sold as Mercury-branded engines in a TOHATSU-run plant in Japan has been exhaustively discussed in many prior threads.
From a long-ago post from a person who had inside knowledge [i.e., he worked for one of the companies,] of the Brunswick-Tohatsu relationship often cited vaguely as "a joint-venture" I excerpt these comments:
Brunswick and Tohatsu formed a joint real estate company. That company owns the land, building and a couple of pieces of manufacturing equipment [at the plant in Komagane, Nagano Prefecture, on the island of Honshu, Japan]. Tohatsu then leases that plant back from the jointly owned company. The plant itself is 100% under Tohatsu management and control with zero oversight by Brunswick. It builds Tohatsu engines and then labels them under Tohatsu, Nissan or Mercury depending on who is buying what. The designs are from Tohatsu engineers. The sole exception to that is on the 4-stroke, 25 to30 EFI model. Some Mercury engineer did have input at some point on its EFI system....
Tohatsu began making the 5-HP and small engines for Mercury in the early 1990's. Up until a couple of years ago [c.2010] it was still routine for [Mercury] to deny any relationship with Tohatsu at all....
It's a world economy now and loyalty to one brand or another because it's "home built" is a thing of the past. I don't particularly like it that way, but it is what it is.
Posted: Thu Apr 23, 2020 12:46 pm
by dtmackey
Sounds about right Jim, I still have a 1990's vintage Tohatsu 5hp, purchased new and now sitting on an engine stand in the basement and it's a clone to the Merc 5hp 2 stroke and also built at the plant in Japan.
The relationship you mention, I do not believe has a connection to the Merc plant in China with the 40 - 60 range, nor the Wei Min Machinery Factory in Le Ping in Jiang Xi province producing Mercury 7.5/9.8-horsepower outboard engines or the Hangkai Outboard company producting clone like Merc motors.
I'm sure the relationships are very twisted with a lot of questionable intellectual property concerns.
Posted: Thu Apr 23, 2020 5:04 pm
DT--I think Mercury became very wary of partnerships with other outboard engine makers after their relationship with Yamaha went south. Some history:
Mercury tried to influence the U.S.International Trade Commission (USITC) to create a tariff on imported four-stroke-power-cycle outboard engines from Japan back in the 2000's. Of course, at that time Mercury was making only ONE four-stroke outboard engine in the USA, a 25-HP model. All the other four-stroke-power-cycle engines Mercury was selling were, themselves, imported from Japan. This all came out in hearings before the trade commission. The real target of Brunswick's attempt to use political influence to impede their outboard engine competitors was, of course, Yamaha. Yamaha and Mercury had a deal in place in which Yamaha was making four-stroke-power-cycle outboard engines for Mercury.
After the USITC heard testimony from many outboard engine dealers, and Mercury themselves had to reveal the extent of their own importation of outboard engines from Japan they were selling under their Mercury brand, the USITC did not impose a tariff. Yamaha then decided it would stop making outboard engines for Brunswick. And Brunswick had to sue Yamaha to force them to fulfill their contract and make more outboard engines in Japan to be imported and sold as Mercury engines.
I have a printed copy of the entire transcript of testimony before the USITC--at one time it was on-line--and it makes for very interesting reading.
After Brunswick was burned by Yamaha and their reluctance to make engines for sale as Mercury engines, I believe Brunswick cooked up their deal with Tohatsu so they could not be left in a bind. If Brunswick is a part owner of the land, the building, and some machinery for the factory Tohatsu leases as their primary engine production plant, then Brunswick has a rather secured position in the future of that plant's operation. That gave them much more leverage in dealing with Tohatsu than it did with their dealing their former partner, Yamaha. Live and learn, as they say.
UPDATE: in the archives of the old forum there is a very interesting thread regarding the topic of outboard engines built in Japan and imported to the USA. Here is a good discussion on that topicL
Who Really Builds c.1990 9.9 and 15-HP Mercury Two-Cycle Outboards
https://www.continuouswave.com/ubb/Foru ... 20646.html
Also on this topic, in the archives there are several references to a United States International Trade Commission investigation into a complaint filed by Brunswick alleging that outboard engines made in Japan were being imported into the United States and then being sold below fair market value. The links to this report in the archives no longer work, as the location where the report is available on line has changed. The new URL is
Outboard Engines From Japan
Investigation No. 731-TA-1069 (Final)
https://www.usitc.gov/publications/701_731/pub3752.pdf
Another document mentioned in the archives regarding this investigation is a transcript of testimony given to the USITC. That document's location has also moved, but it still available at
https://www.usitc.gov/trade_remedy/731_ ... 4-open.pdf
In particular, the 375-page transcript has some interesting segments, particularly where dealers selling Mercury engines testified that their customers were buying Japanese engines for higher reliability and quality, and not due to lower price.
