Replacement Fuel Tank for 1972 OUTRAGE 21
79Panther
Postby 79Panther » Thu Mar 03, 2022 7:52 am
[This thread has been moved to THE GAM from MARKETPLACE because the intend of the thread was to solicit advice--Moderator]
Where can a replacement fuel tank for a 1972 OUTRAGE 21 be purchased?
Where can a dimensional drawing for the fuel tank for a 1972 OUTRAGE 21 be obtained?
Re: Replacement Fuel Tank for 1972 OUTRAGE 21
Postby jimh » Thu Mar 03, 2022 9:27 am
The OEM fuel tank for a Boston Whaler 1972 OUTRAGE 21 boat may have been fabricated by Florida Marine Tanks. I recommend you contact them to confirm they were the OEM. If Florida Marine Tanks were the OEM, they can probably fabricate a new tank for use as a replacement.
Obtaining a detailed drawing of a fuel tank originally made by Florida Marine Tanks from them at no charge and sufficiently detailed to permit a new tank to be made by someone else will probably not be likely to occur.
If Florida Marine Tanks is not the original fabricator, the best method to find a replacement tank will be to carefully remove the OEM tank from the boat, and use the OEM tank as a model or pattern for the fabrication of a custom replacement tank. Without knowing your location, the existence of a custom aluminum welded fuel tank fabricator in your area will have to be left to you to discover.
The OEM tank can also be carefully measured, and an accurate mechanical drawing of the tank can be made from the OEM tank by someone skilled in mechanical drawing and fabrication of objects from a drawing.
Postby Phil T » Thu Mar 03, 2022 2:41 pm
I have been told that FMT is no longer accepting orders due to its production backlog.
The standard advice for those too far from Florida Marine Tanks (Henderson, North Carolina), meaning west of the Mississippi or north of the Virginia, is to remove the existing tank and provide it to a local vendor to replicate. The average cost for fabrication and fittings is $10 per gallon of capacity.
If there is no tank to use as an example, take measurements of the cavity and/or make a cardboard template if saddle tanks.
frontier
Postby frontier » Thu Mar 03, 2022 3:17 pm
The 1972 Outrage 21 did not have a built-in fuel tank. My 1972 Outrage 21 ribside used standard on-deck fuel tanks.
The 1973 Outrage 21 smoothside had an internal 40-gallon aluminum fuel tank.
goldstem
Postby goldstem » Fri Mar 04, 2022 3:15 pm
My OUTRAGE 21 ribside had two aluminum fuel tanks, one (approximately) 18-gallon tank under each gunwale. Each tank's fuel feed hose ran to a shutoff or isolation valve; the valve outputs fed a T-connector; the T-connector fed the engine.
After I got the boat, I replaced the T-connector with a RACOR fuel-water separating filter
