Engine Safety Shut Off with Wireless Sensors
dtmackey
Postby dtmackey » Fri Apr 22, 2022 10:40 am
I never remember to wear [the engine safety shut-off lanyard] tether, and that comes from more than 45-years of never wearing one. If I were to wear the tether, I'm sure I would move far enough from the helm and unintentionally shut off the engine.
Now that enforcement of use of the safety lanyard shut off has increased, I decided to install the Fell Marine intelligent man overboard system.
FELL MARINE MOB+ Intelligent Man Overboard System
https://buy.fellmarine.com/collections/mob-wireless-man-overboard-system/products/mob-basepack-multifob
Since my kids are also running the boats, I figured it was a good idea to order additional (transmitters or) "fobs" so everyone could have one, and so that we would never be stuck without a fob. The MOB+ system has an override feature if needed that
The best feature is you can move away from the helm and not kill the engine, but if you fall out of the boat, the engine will be shut down.
So to make sure I covered my bases, I ordered:
  • two FELL MARINE MOB+ Basepack Multifob units, one for each outboard powered boat with remote steering, come with one fob
  • three additional fobs, so five fobs in total; all five will be be paired to both boats' base units
  • two wristbands to hold the fobs, and
  • two wearable tethers to hold the fobs
Fobs will be kept with each set of keys, so there's no worries of having one, but not the other.
I wanted to do this in 2021 but held off until I researched the company and technology and felt comfortable with their reliability and quality.
If you are like me and can't remember to wear the tether, or if you don't care for wearing a tether, look into the FELL Marine system.
Re: Engine Safety Shut Off with Wireless Sensors
Postby Phil T » Fri Apr 22, 2022 1:08 pm
Q1: Any views on pricing?
Q2: Accessories to avoid?
Q3: Preferred vendors?
dtmackey
Postby dtmackey » Fri Apr 22, 2022 2:10 pm
The system is a good looking dash mounted set-up that splices into your wiring for the engine shut off. I provided a link to the company website was provided in my original posting. Here's a link to their shopping page. https://buy.fellmarine.com/
Phil T wrote:Q1: Any views on pricing?
PRICING from FELL MARINE store
  • $209 MOB unit
  • $41.99 fob (as in key fob)
  • $20.99 wrist band for fob
  • $25.99 neck tether for fob
Phil T wrote:Q3: Preferred vendors?
A savings of 15 to 20-percent can be found at other vendors, using a search engine.
Phil T wrote:Q2: Accessories to avoid?
Not sure how to answer this since everyone's needs vary, so what works for me, may not be the same as other prefer.
Postby jimh » Fri Apr 22, 2022 3:32 pm
dtmackey wrote:Now that enforcement of use of the safety lanyard shut off has increased...
This comment caused me to investigate more closely the change in federal regulations that require the operator of a recreational boat to employ an engine shut off switch. Rather than distract this discussion, I moved my findings to their own thread.
Federal Regulations for Engine Shut Off Switch Use
https://continuouswave.com/forum/viewto ... 247#p41242
Postby jimh » Fri Apr 22, 2022 3:57 pm
The FELL MARINE MOB+ basic system comes with these components:
  • HUB
  • FOB
  • antenna
  • wiring harness, and
  • crimp connectors
The FELL MARINE MOB+ base unit must be provided 12-Volt DC electrical power. The power can be fused at 3-Amperes. The source of the power must not sag below 7-Volts. If that occurs the unit reboots and will stop the engine. This means that if the engine cranking battery is the source of power, and if the engine cranking battery is in a low state of charge and its voltage sags below 7-Volts during engine starting, there may be a conflict.
The FELL MARINE MOB+ must be integrated with the specific engine that it is going to shut off. The base unit has to be electrically connected to the engine wiring harness.
The integration will be simple if the specific engine employs a switch arrangement in which the engine shut off switch is normally-open and must be closed to shut off the engine. For that configuration, the FELL MARINE MOB+ relay contacts is just wired in parallel with the switch.
The resting state of the relay in the FELL MARINE MOB+ is to be normally closed. That means that the engine won't be able to start until the FELL MARINE MOB+ has detected the presence of a fob signal.
dtmackey
Postby dtmackey » Fri Apr 22, 2022 4:06 pm
jimh wrote:The resting state of the relay in the FELL MARINE MOB+ is to be normally closed. That means that the engine won't be able to start until the FELL MARINE MOB+ has detected the presence of a fob signal.
It is important to note that the system has an override feature, should the fob be misplaced or forgotten.
Postby jimh » Fri Apr 22, 2022 5:43 pm
dtmackey wrote:It is important to note that the system has an override feature, should the fob be misplaced or forgotten.
I think it is even more important to note that the "plus" part or the "intelligent" part of the system is that the number of remote devices or "fobs" that can be monitored is greater than one. I believe that before you try to start an engine you have to first operate the fob in a specific manner so the fob transmits a signal to the base station to let the base station know that the fob is aboard the boat and the base station should monitor that fob. In this way the MOB+ device can be informed of how many fobs are in use at any particular engine start sequence, and loss of signal from any one fob will cause the engine to shut down.
It is also important to note that the so-called "override" function actually ruins another function, albeit perhaps a collateral function, which is that the engine start could not be accomplished unless at least one registered fob was aboard the boat. That would be a useful security function. To make a comparison to a modern automobile, you cannot start the car engine without the key fob being in the vicinity of the key fob sensor. That would be true for the MOB+ device, except that the need for a fob to be aboard the boat and working properly can be easily overridden (by pressing a front panel button for ten seconds), which then allows the engine to be started.
Because the typical ignition key switch for an outboard engine is generally panel mounted and the back side of the switch with the switch terminals is easily accessed, a simple jumper or two on the switch terminals would start the engine. If a fob were still required, it would add a secondary measure of security.
Postby jimh » Fri Apr 22, 2022 5:51 pm
In a prior article I created a poll to ask about use of a lanyard-operated engine cut off switch. In that poll, 60-percent of the respondents said they used a safety lanyard "always" or "often."
ASIDE: the switch action that must occur to stop the engine in many engine stop switches is typically a switch closure. This has an effect on how much safety there is in the system.
If the normal or resting state of an engine shut off switch is an open circuit, then a fault in the circuit could occur elsewhere that created an open circuit, and actuation of the switch would NOT shut off the engine when the switch was operated to its active state. There is a somewhat infamous incident in which a USCG patrol boat collided with another boat, the crew of the USCG boat were ejected, but the impact of the collision damaged the engine cut off switch, creating an open circuit. The result was the engine could not be shut off. The boat continued to run at high speed in circles, actually running over the crew in the water, who had to dive to avoid the boat. Even when the boat ran ashore, the safety switch circuit was so damaged that the engine could not be shut off using that circuit.
One might argue that the normal state of the entire engine stop circuit ought to be a closed circuit, so that to stop the engine the circuit must be opened. In this way, at engine start you would know that the circuit was working. If the normal circuit is to be an open circuit, then at engine start you really cannot tell is the circuit is intact and just the engine stop switch is in the open position, or if there is some other circuit fault that creates the open circuit.
A corollary action: one ought to periodically actually test any sort of device or circuit that is supposed to shut off the engine to verify that the engine can be shut off when the device is actuated, whether by mechanical linkage or electronic wireless linkage.
dtmackey
Postby dtmackey » Sun Apr 24, 2022 10:35 pm
jimh wrote:In a prior article I created a poll to ask about use of a lanyard-operated engine cut off switch. In that poll, 60-percent of the respondents said they used a safety lanyard "always" or "often."
The poll is great, but the poll takes into account such a small portion of the toal boating population that it is not a valid measure of true use. I would put real world usage at 15-percent at best. When I scan most dinghies at the local dinghy dock, most of the tether cords are cut so they don't get tangled by the operators, but I'd imagine that will change over time.
dockthedog
Postby dockthedog » Fri May 20, 2022 9:14 am
Having fallen out of a boat when I was a teenager I always wear an [Engine Safety Shut Off] switch when I'm alone in the boat or with non-boater passengers.
In 2021 I installed the Fell Marine wireless system. The Fell Marine wireless system works great.
Note: the wireless transmitter or "fob" battery is quickly discharged. The reason I have experienced rapid discharge of the fob battery is I forget to "turn off" the fob when I come home from boating. Keeping a four-pack of replacement batteries in the boat for the wireless fob is recommended.
If the wireless fob has a discharged battery, the Fell Marine wireless system provides an override so the boat can be operated [without use of the wireless fob transmitter].
I plan to re-install the original Engine Safety Shut Off switch and it lanyard next to the Fell Marine wireless systems sensor, and then to wire the original switch in parallel with the Fell Marine Safety Shut Off switch. In this way I can go "old school" if I need to.
Postby jimh » Fri May 20, 2022 11:56 am
dockthedog wrote:I plan to re-install the original Engine Safety Shut Off switch and lanyard next to the Fell Marine wireless systems sensor, and then to wire the original switch in parallel with the Fell Marine Safety Shut Off switch.
Typically a conventional electrical-mechanical switch used as a Engine Safety Shut Off mechanism will be of one to types:
  1. the switch is a normally-closed switch that is held in the open-circuit position until the lanyard is removed, or
  2. the switch is a normally-open switch that is held in the closed-circuit position until the lanyard is removed
Since you are planning to wire "in parallel" your older OEM electrical-mechanical switch with the Fell Marine Wireless system, please explain which switch behavior (A or B above) your existing Engine Safety Shut Off switch uses, and exactly how you will wire it to the Fell Marine Wireless system. This information will be very useful to readers.
Does Fell Marine provide information on connecting a electrical-mechanical Engine Safety Shut Off switch in parallel with their system?
Does Fell Marine provide information on using both normally-closed and normally-open switches?
Postby jimh » Fri May 20, 2022 12:11 pm
dtmackey wrote:...a poll takes into account such a small portion of the total boating population is not a valid measure of true use. I would put real world usage at 15-percent at best. When I scan most dinghies at the local dinghy dock, most of the tether cords are cut so they don't get tangled by the operators, but I'd imagine that will change over time.
When participating in a survey or poll, many respondents submit replies that tend to conform with expectations or with behaviors considered to be proper.
If surveying a population of perhaps 5,000,000 recreational boaters, in order for the results to have statistical significance, the limited number of respondents would need to be very carefully chosen to be representative of the total population. For example, Nielsen television ratings are based on a very small sample of carefully chosen participants that are considered to reflect the total television viewing population of more than 150-million people (in this particular case, people who are likely to respond to television advertising).
In the case of a poll conducted among active participants of this forum, I would characterize the number of moderately active participants as perhaps about about 100. The poll elicited replies from 49-participants. That is a survey size of about 50-percent of the total population. It is quite reasonable to assume the survey results reflect the general population of active participants in the forum. However, as you note, those participants may not reflect the total boating population, and as I note, their replies may not reflect the actual behavior of the respondents.
dockthedog
Postby dockthedog » Fri May 20, 2022 2:00 pm
jimh wrote:Since you are planning to wire "in parallel" your older OEM electrical-mechanical switch with the Fell Marine Wireless system, please explain which switch behavior (A or B above) your existing Engine Safety Shut Off switch uses, and exactly how you will wire it to the Fell Marine Wireless system. This information will be very useful to readers.
My engine is Mercury. Mercury is "Close-to-kill" type switch, (option 'A' above.) Fell provides different instructions for different engine brands and the instructions for Mercury engines do explain wiring the Fell in parallel with the existing mechanical switch: https://supportcenter.fellmarine.com/hc/en-us.
Postby jimh » Fri May 20, 2022 10:17 pm
dockthedog wrote:Mercury is "close-to-shut off engine" type switch, (option 'A' above.)
That type switch can be added in parallel with others.
The B-type switch (normally closed and opens to indicate engine shut off) would need to be in series with others, so that any switch going to open circuit would cause the engine to shut off.
raaron
Postby raaron » Wed Dec 21, 2022 10:35 am
I have installed the MOB+ wireless engine safety shut off switch system from Fell Marine on my boat, and I recommend it.
The Fell Marine wireless safety engine shut off system works. We use it 100-percent of the time the boat is in operation. It was easy to install.
We will not have to deal with a tangled red pig tail cord again.
imhoff
Postby imhoff » Mon Dec 18, 2023 9:45 am
On my 1998 DAUNTLESS 15 boat the engine shut off safety lanyard switch fell apart.
[To replace the 25-year-old engine shut off safety switch] I bought the FELL Marine Mob+ Wireless Man Overboard System.
My younger son will be the boat's primary user, which gives me peace of mind. You can easily shut off the engine by pressing a button on the neck, life vest, or belt-mounted remote, or if the remote is submerged in water the engine will shut off.
After an event, [the system causes an aural alert of] beeping. The engine can be restarted (to pick up the captain who fell overboard). You can also override it if you forget the remote or easily disconnect it altogether.
Postby jimh » Mon Dec 18, 2023 11:21 am
As far as I have found, there are only two devices on the market that use wireless sensors to replace the normal physical lanyard engine shut off safety switch. Both devices are aftermarket products that are to be installed by the buyer. The two brands are FELL MARINE and ACR.
The FELL MARINE wireless sensor device is reported above by several users.
The ACR OLAS device is called the GUARDIAN. It retails for $250. More information is available at
https://www.acrartex.com/products/acr-olas-guardian/
The remote sensor for the ACR OLAS GUARDIAN is in the form of a wrist band that has a clasp, much like a watch band. As many as 25 sensors can be used simultaneously. The sensors can be designated as either driver or passenger. If a sensor designated as passenger is detected out of range, the engine is not shut off, and instead only a MAN OVER BOARD (MOD) alarm sounds to alert the driver. If the sensor designated as driver is detected out of range, the engine is shut off within two seconds. After a delay of seven seconds, the engine can be restarted normally. In addition to the aural alert, a bright red lamp will illuminate to give a visual indication of MOB.
A mobile app is provided which can communicate with the system to allow setting of parameters and configuration of remotes. By using the mobile app the battery in all connected remotes can be monitored for state of charge.
ACR is a globally recognized marine electronics manufacturer that produced the technology-leading emergency position-indicating rescue beacon (EPIRB) and personal locator beacon (PLB) devices of the highest quality. ACR products are sold through authorized dealers, such as West Marine.
msteinkampf
Postby msteinkampf » Wed May 15, 2024 9:38 am
The engine rigging on my 1990 Montauk 17 does not have an engine shut-off safety switch, and neither federal law nor Louisiana state law (where I do most of my boating) law currently requires one, but I am contemplating installing an engine shut-off safetey switch, anyway.
A wirelessly-operated system seem attractive, but I am concerned about the reliability. Reviews of the FELL system on Amazon mention instances of the device failing and leaving the operator stranded.
Also, I occasionally operate in rough water, and getting splashed by spray or a wave (or rain) is a distinct possibility.
Q1: will getting splashed while underway activate [a wireless engine shut-off safety] switch and stop the engine?
If yes, then I would not install a wireless engine shut-off safety switch.
Q2. among FELL Marine, ACR, and Mercury 1stMate, which system is recommended?
Postby jimh » Wed May 15, 2024 1:24 pm
To assess the effect of a splash of seawater or freshwater on the operation of a wireless engine shut-off safety switch, I recommend you contact each of the three manufacturers you mention and get their opinion.
The general basis for the operation of these wireless implementations of an engine shut-off safety switch is the concept of radio signal transmission. As long as the receiver in the base unit can detect transmission of signals from the remote worn device, the system assumes that the wearer of the transmitting device is still aboard.
In my uninformed opinion--I have no knowledge of the actual circuits or the construction of the remote transmitters--if a device is designed to operate in an open boat navigating on the ocean, there is an expectation that a momentary splash of water onto the device would not cause its most basic operation to stop. For example, although total immersion of an outboard engine would cause the engine to stop running, exposure to splashing of water onto the engine cowling or other external surfaces of the engine will not cause the engine top stop running.
The most basic operation of the remote device or fob or wrist band (or whatever you call them) is to be able to transmit a signal back to the receiver that determines when to stop the engine. The inference that this most basic function would be disabled by incidental and momentary contact with water seems irrational, but, hey, who really knows other than the designers of the system.
Also, in a properly designed system, there may be a threshold set at the receiver that imposes a certain duration during which the signal must be lost before the decision that someone has gone overboard is to be implemented. In any radio communication, there is always an expectation that the propagation path loss might suddenly and temporarily increase to the point of perhaps loss of signal, and then the propagation fade goes away and the normal signal returns. A well-designed system would take the chance of a very short duration loss of signal as a possibility, and would impose some threshold on the duration of loss of signal before determining the loss of signal was due to a crew going overboard.
porthole
Postby porthole » Wed May 15, 2024 1:28 pm
My Fell MOB fob will not shutdown the engines with either spray or heavy rain, nor will it shut down dropped into the wash bucket.
As to leaving someone stranded, there is a bypass dongle that simply plugs into the harness to allow engine starting for a system failure.
I am on my second installation, and if I buy another boat I'll have a third installation.
Duane
2016 World Cat 230DC
1997 Outrage 18, Yamaha 125
1983 15 SS, Honda 50
1980 42 Post
1983 34 Luhrs 340 SF
Postby jimh » Wed May 15, 2024 1:47 pm
porthole wrote:My Fell MOB fob will not shutdown the engines with either spray or heavy rain,
That behavior probably occurs because the criteria for engine shut-down probably requires more signals attenuation than the amount that occurs if the fob gets a bit wet.
porthole wrote:...nor will it shut down dropped into the wash bucket.
As for dropping in a wash bucket, I assume you mean a bucket with water in it. I would expect more radio signal attenuation to occur from total immersion of the fob in water. But the bucket is also anticipated to be still on the boat.
The effect of water molecules on propagation of radio waves varies significantly with the actual frequency. The relationship is the HIGHER the radio frequency, the HIGHER the chances of absorption of the energy in the radio frequency wave. This is due to the relationship between the wavelength of the radio wave and the size of the molecules in the intervening substance.
For more background, read this summary of an Institute of Electrical and Electronic Engineers (IEEE) paper"
Review of Temperature and Humidity Impacts on RF Signals
https://ieeexplore.ieee.org/document/9299327
Excerpt from IEEE Paper wrote:Signal strength of radio waves propagating from transmitter to receiver can be affected by atmospheric conditions even in line-of-sight situation. These atmospheric conditions cause the propagated waves to vary from the anticipated range. Higher frequencies can result in weak signals as they have shorter wavelengths. High frequency increases the chances of hitting obstacles such as water molecules in the atmosphere when radio waves propagate. This will cause a weakening effect as water absorbs some of the energy from the waves and scatters the rest of it.
Most boaters are already acquainted with this behavior of radio waves and water if they have ever heated any food in a microwave oven. The heating that occurs in a microwave oven is the result of (water) molecules in the food absorbing the energy of the radio waves being directed onto them. The frequency of radiation used in a microwave oven is generally optimized to cause water molecules to absorb the radio wave energy. The basis for this is examined in another paper,
Physics of the microwave oven
https://www.sfu.ca/phys/346/121/resourc ... _ovens.pdf
In the section under the heading
Heating of food in a microwave oven
Absorption of microwaves by water
the following explanation is provided:
from source cited above wrote:Electromagnetic waves may be absorbed by matter in many different ways depending on their
wavelength and the state of the matter (gas, liquid, solid)...solids and liquids may absorb microwaves due to the polarization induced by the external oscillating electric field. In a microwave oven, the electrically dipolar water molecules absorb most of the microwave energy.
The inference to be made from these observations: the frequency for the remote transmitter devices in a wireless engine shut-off safety switch system was most likely selected on the basis of not being particularly sensitive to being absorbed by water.
The actual frequencies in used by either manufacturer are not known to me, but I would expect that the frequencies used would need to be in a radio band that permitted such unlicensed use. Further investigation in to the particular devices should be able to discover what FCC-allocated radio band is being used.
Postby jimh » Wed May 15, 2024 1:54 pm
Regarding choosing between devices made by FELL or made by ACR, my opinion, based just on the size of the company, the resources of the company, and the chances of the company remaining in business for the next ten years, favors ACR as the choice.
ACR is manufacturing marine safety electronic devices of high complexity and design, such as EPIRB, PLN, and AIS safety devies, and are selling them into a global market of highly regulated products associated with safety of life in operation of vessels of all types and sizes.
I believe FELL Marine is a smaller company, selling mainly into the recreational boating market in North American, with a limited range of products, and since their products only work with each other, there is no need for compliance with any regulated safety equipment like EPIRB, PLN, AIS, or other marine safety devices,
In the field of marine electronics there is a well demonstrated tendency for larger companies with greater operating capital to acquire smaller companies typically producing one product (which competes with one of the larger company's products) and is run by the principal engineer of those products.
I cannot endorse the Brunswick product sold under the Mercury Marine brand as I do not have an outboard engine that supports the proprietary network protocol SmartCraft. The Ist-Mate engine shut-off safety switch appears to only be useful on engines with SmartCraft interfaces, which means only Mercury Marine branded engines.
A further tendency to avoid Mercury engine shut-off safety switches was their traditional poor design using a normally open switch which had to be closed to complete the circuit to actuate engine shut off. This design approach caused the possibility of malfunction of the safety switch when any part of the wiring involved became an open circuit, such as break in a connection from vibration over time or from forces generated by impact of the boat with other objects. (See the earlier account of the USCG vessel whose engine continued to run even after the crew were ejected overboard because the wiring to the safety switch was damaged and became an open circuit, indicating normal operation, that is, no engine shut off.)
On the other hand, there seems to be an astonishing trend to install high-horsepower Mercury engines in multiple of as many as five, so if fitting a wireless engine shut-off safety switch to a boat with two, three, four, or five or more Mercury engines, the SmartCraft Ist-Mate may be much preferred as it seems to connect to the SmartCraft network and may shut off engines with a network command rather than by some rudimentary wiring to a mechanical lanyard switch.
