Another common problem with the white all-round lamp on a pole is the electrical connection. For a long time Boston Whaler used a rubber-body two-pole polarized connector set with bronze or some copper alloy contacts, made by Cole-Hersee and identified as their M-121 connector. This connector is still made and is still listed in the catalogue, although Cole-Hersee is now part of the LITTLEFUSE conglomerate. See
https://www.littelfuse.com/products/oth ... m_121.aspx
Fig. 1. A Cole-Hersee set of M-121 connectors as used in many Boston Whaler pole lamp circuits.The two connectors were often left unconnected, and also unprotected from the weather. The outcome was a very unreliable connection due to oxidation of the contacts.
Ages ago there was a long discussion about a better connector for these lamps. Like just about every old discussion, this topic is still in the achives and still on-line. See
Navigation Lamp Connectorshttps://continuouswave.com/ubb/Forum6/HTML/002500.htmlThe above thread goes on for many comments,
I settled on my own solution, which was to use Deutsch DT-series two-pole connectors with silver contacts, adding hoods to the cable ends to both connectors to provide better protection against water splashes, and to buy mating dummy plugs to use as covers when the connectors were not mated. The silver connectors are better because if oxidation occurs, silver oxide is still a conductor; with copper or bronze, the oxide is not a conductor, which is the real cause of all the problems with the M-121 connectors. I switched to the Deutsch connectors in 2009, so I can say that in 2024, after 15-years in service, they work perfectly and exactly as they did on the first day I installed them.
The two connectors are the DT04-2P (house for male terminals) and its mate, DT06-2P (housing for female terminals). I used the silver terminals and soldered the conductors instead of crimping them (as I was not sure I had a proper crimp tool for these particular contacts). The wedge locks and individual contacts are ordered as separate components. You will need a W2S and a W2P wedge lock, and for silver contacts, you have to buy them individually.
Here is a list with part numbers
Contacts are
2 x PIN = 0460-202-16141 - SOLID PIN - SIZE 16 - 16-20 AWG - 13 AMPS - NICKEL = $0.55
2 x SOCKET = 0462-201-16141 - SOLID SOCKET - SIZE 16 - 16-20 AWG - 13 AMPS - NICKEL PLATED = $0.69
The boots are
DT2S-BT - DT SERIES - 2 CAVITY PLUG BOOT - GRAY = $1.40
DT2P-BT - DT SERIES - 2 CAVITY RECEPTACLE BOOT - GRAY = $1.60
Connector housings are
DT06-2S - DT SERIES - 2 SOCKET PLUG - GRAY = $1.39
DT04-2P - DT SERIES - 2 PIN RECEPTACLE - GRAY = $1.21
The dust caps are
1011-344-0205 - DT SERIES - DUST CAP FOR 2 CAVITY PLUG - BLACK = $1.08
[No dust cap for receptacle listed.]
I think the dummy sealing plugs I ordered 15-years ago are no longer a standard part; but I presume you could just order a mating housing and use a bit of sealant at the wire entrance seals to prevent any ingress of water from the back of the connector body.
