CONTACT: [ No direct means of contact provided. Posts to MARKETPLACE must provide a means of direct contact that does not rely on the website to act as an intermediary to the communication.]
I will remove the audio systems, the trolling motor, Hummingbird fish-finder and put them on my new used boat.
The newly installed battery switch, wires, Blue-sea waterproof deck switch panel, amazon bimimi will remain on the Mischief.
The Hull is solid and has no soft spot. the hill bottom might need some paint, but solid.
I drilled 1/4-inch holes four holes on the upper desk yo mount some gears. The buyer can fix these holes with fiberglass.
A recently added a "Taylor Made" windshield that cost $500 can be removed if not wanted without damage to the hull
