2016 150 MONTAUK: Locating Glassed-in Reinforcements
bobrocke
Postby bobrocke » Wed Aug 22, 2018 12:59 pm
My Montauk 150 manual is very helpful and shows the size, type, and general location of all the glassed-in reinforcement pads. But the location is not very specific.
A Whaler Customer Service Representative suggested using a stud finder to locate the pads I'm interested in. So I tried that. My problem is that I can't get signals to repeat reliably enough for me to be sure I've properly located a pad. And some pads seem to be in places the diagram in the manual suggests there is no pad.
Is there a technique I'm missing?
Bob
Bob Rockefeller
Midway, GA
2016 Montauk 150
Re: 2016 150 MONTAUK: Locating Glassed-in Reinforcements
Postby jimh » Thu Aug 23, 2018 8:58 am
I believe you are looking for embedded material in the hull, as shown in this diagram from the 2016 150 MONTAUK owner's manual:
Fig. 1. 2016 150 Montauk hull reinforcement location diagram from owner's manual
You can deduce the approximate location of the embedded material from the drawing, which appears to have been made to scale.
Regarding use of a stud-finder to locate the embedded material: that sounds like an excellent method. To test the sensitivity of the device you are using which apparently has failed to locate any material, perform a test:
--place a small block of wood of size and thickness similar to the embedded material in the boat behind a thin plastic material such as a polyethylene sheet;
--use your particular stud-finder and try to detect the location of the wood behind the plastic sheet;
--if your particular stud-finder fails to detect the wood, then it probably won't be useful in finding the wood embedded in the boat hull;
--try a different stud-finder, perhaps one with more sensitivity (or a fresh battery).
Another method to locate embedded material is to tap the hull with a plastic hammer, listening for a change in the report (sound) of the tap. Usually there will be a noticeable change in the sound produced by tapping when you are tapping on a reinforced area. However, I would expect the stud-finder method would be more precise.
