Red Dot Hull
777AIA
Red Dot Hull
Postby 777AIA » Mon Aug 24, 2020 12:58 pm
I have a 1986 SUPER SPORT 15 that I have owned for over 30 years. I have followed [continuouswave.com] for years.
Fig. 1. Red Dot Hull
Tell me about the red lucite dot behind my Whaler logo?
I don't see it on anybody else's boat.
I am getting ready to restore this winter, and am trying to be careful about this dot. But I don't know what it’s made of, or why I have one and nobody else does.
Feedback appreciated.
frontier
Re: Red Dot Hull
Postby frontier » Mon Aug 24, 2020 1:23 pm
The red dot designates your Boston Whaler has the "Workboat Specifications" option . Listed in the 1986 Boston Whaler "Boat Prices and Specifications" booklet as option number 15-0480-00. A $773.00 option in 1986. On a 15' boat, "Workboat Specifications " adds 90 pounds more glass and resin to the boat.
777AIA
Re: Red Dot Hull
Postby 777AIA » Mon Aug 24, 2020 1:35 pm
Thank you. Good to know.
Re: Red Dot Hull
Postby jimh » Mon Aug 24, 2020 2:01 pm
Information about a Red Dot Hull is given in the Frequently Asked Question answers. See
The dot is gel coat resin.
Re: Red Dot Hull
Postby jimh » Mon Aug 24, 2020 2:04 pm
The rub rail shown above is not OEM.
The Boston Whaler decal looks crooked.
Two problems to remedy in the restoration.
Re: Red Dot Hull
Postby biggiefl » Tue Aug 25, 2020 11:14 am
What engine do you have? That waterline is really high for a 15'.
Don McIntyre - MI
Re: Red Dot Hull
Postby Don McIntyre - MI » Tue Aug 25, 2020 8:29 pm
I think that hull is fairly rare. I'd bet not many 15-footers were ordered with workboat specs.
Re: Red Dot Hull
Postby biggiefl » Tue Aug 25, 2020 9:24 pm
No doubt Don....I have NEVER seen a red dot 15". My concern is the waterline but not a concern with the correct answer from the owner.
Re: Red Dot Hull
Postby jimh » Wed Aug 26, 2020 8:24 am
I am not clear what particular advantage would accrue to having the 15-foot hull with heavier lay-up for a typical recreational boater. I owned a 1976 15-footer, one of the first hulls made, and it was quite light. I believe that the hull weight was noted as increasing from the earliest production hulls after a few years. Perhaps a heavier layup was used on those later models.
There was never any particular reason to want the hull layup to be heavier or to be workboat specification that I could see. My old 1976 boat is now 44-years-old. It's hull is still in perfect condition.
The non OEM-rubrail suggests perhaps the boat under discussion here has seen some hard use that damaged the original rub rail. Maybe the workboat layup was a good choice for its initial owner.
Don SSDD
Re: Red Dot Hull
Postby Don SSDD » Wed Aug 26, 2020 5:37 pm
I would have thought the commercial hull would add more than 90 lbs, my 18 outrages were 1250 lbs for regular hull and 1750 lbs for commercial hull, that’s 40% more for the commercial. With the 1986 15 weighing 500/550, 40% would be over 200 lbs. 200 lbs would effect the water line on a 15 foot hull.
Nova Scotia
