1980 Outrage 21: Chronic Water in Sump
Posted: Wed Oct 19, 2016 12:52 pm
I'm considering the purchase of a 1980 Outrage 21 smooth-side banana hull. I'm currently a Montauk owner, but I have always been on the lookout for an older Outrage 21 boat. The boat's current owner launches the boat in and out of the water very infrequently.
During the course of a full day of boating on fresh waters, he'll notice the [sump pump is] running to empty some water that has accumulated in the sump. This happens two to three times during the course of a day. The indication is that water is not coming over the rail which would be the obvious cause.
For owners of similar models to answer: how often does your [sump pump] run?
Is there a known problem or concern with hull seepage on these [older OUTRAGE 21] models.
If so, how difficult is the repair?
Through some research, It has been indicated that the joint between top and bottom sections along the rub rail can be the source of water that accumulates in the sump. I'm willing to get into some repairs but do not want to have to tear apart the entire deck and hull to solve this one.
New poster here. Thanks in advance for any insight you can provide.
