16 SL Tank Level Gauge
loned
Postby loned » Mon Apr 10, 2017 7:03 pm
Hi there. I have a 1993 16 SL down in Baja, and the fuel [tank level] gauge isn't working. I'm back in California, and want to bring down repair parts on my next trip. My understanding is that there are generally three types of fuel [tank level] gauge systems. Assuming it is stock, does anyone know what tank [level] gauge system this would have?
Re: 16 SL Tank Level Gauge
Postby jimh » Thu Apr 13, 2017 11:05 am
Boston Whaler boats typically use a fuel tank level gauge that is magnetically coupled to a mechanical lever float arm. See
http://continuouswave.com/whaler/refere ... #fuelGauge
for more information on the fuel tank level gauge.
I don't know what you are referencing by "three types" of tank level gauges.
On the chance that your 1993 Boston Whaler 16 SL has an electrical fuel tank level sender, it most likely has a rheostat with the standard resistance range used in the USA. Quoting myself:
Historically in the USA a standard has come into use for the fluid tank level sender to provide a variable resistance in a range from 33-Ohms when the tank is full to 240-Ohms when the tank in empty.
Source: http://continuouswave.com/whaler/reference/fluidTankLevelNMEA2000.html
I recommend you call Boston Whaler customer service and inquire with them about the particulars of the fuel tank level gauge used on a 1993 Boston Whaler 16 SL boat. The fine folks at Boston Whaler customer service will be able to give you the best and most reliable information about that particular boat model and year.
loned
Postby loned » Fri Apr 14, 2017 11:56 am
Will do. Thanks very much for the help.
