c.1964 13-footer; Repair of Spider Cracks Throughout Hull and Deck
Posted: Tue Apr 18, 2017 10:33 am
I have a 1964 13-footer with spider cracks throughout the inside and bottom of the hull. I am working on my first restoration project and this is new to me. To get rid of all the cracks should I be:
--sanding and grinding through the gel coat , or
--using a dremel to widen them all and repair them (lots and lots of them), or
--prime over them?
I've seen varying opinions on this. I started grinding to the bare fiberglass on the inside of the bow, but I am have second thoughts now. I would rather fix holes and dents, prime and paint with the roll and tip method instead of re-gel coating the entire boat.
I also want to make sure [the hull] is watertight with the gel coat sanded off.
Any advice on how to proceed would be appreciated. I plan to use Interlux products.
--prime over them?
