Repair of Hull Surface Gouges, Stripped Fastener Holes
PatSea
Postby PatSea » Tue May 09, 2017 6:54 pm
I just removed the railing around my Sport 13. The stanchion on the front of the boat has three stripped holes. How do I go about repairing this? I've never done any fiberglass work, but time to learn as there are a few hull surface gouges that need repair also. Thanks.
Re: How to repair stripped holes
Postby Phil T » Tue May 09, 2017 10:56 pm
While there are many methods, one of the straightforward ones is this. Tried and true.
Tape off the area with painters tape.
Slightly over drill the hole slightly enlarging it (not too large, still covered by base plate)
Fill the screw hole 1/2 way with Gorilla Glue (a polyurathane expanding adhesive). Let cure. Trim off excess and retap the screw hole.
Remove tape.
Postby jimh » Wed May 10, 2017 9:31 am
PLEASE do not use MARKETPLACE to ask questions about repairs. Your article has been moved to REPAIRS and MODIFICATIONS.
Re: Repair of Hull Surface Gouges, Stripped Fastener Holes
Postby jimh » Wed May 10, 2017 9:35 am
To repair holes for railing stanchions, see the answer to your question in the FREQUENTLY ASKED QUESTIONS at
Q7: How Do I Repair Loose Railing Anchor Bases?
http://continuouswave.com/whaler/reference/FAQ/#Q7
Postby jimh » Wed May 10, 2017 9:39 am
To learn about making repairs to damaged surfaces of the hull of a Boston Whaler boat, please see the answer to your question in the FREQUENTLY ASKED QUESTIONS at
Q5: How Do I Repair Damage to the Hull?
http://continuouswave.com/whaler/reference/FAQ/#Q5
Please note that the FREQUENTLY ASKED QUESTIONS article in the REFERENCE section contains well-researched and concise answers to many common questions related to repair or use of Boston Whaler boats.
The REFERENCE section also contains many well-researched and long-form articles on many topics related to Boston Whaler boats. See
