1996 Evinrude OceanPro 200 Timing Base Plate
wamair
Postby wamair » Tue Nov 14, 2017 7:26 pm
I left the engine throttle [for a 1996 Evinrude Ocean Pro] at wide open for a week after checking compressions. Now [the throttle] is stuck and the culprit is the timing base plate. How freely should the timing base plate move with the engine not running?
Any tips on repairs?
Thanks Phil
Re: 1996 Evinrude OceanPro 200 Timing Base Plate
Postby jimh » Fri Nov 17, 2017 11:23 am
I'll offer some uninformed comments, since no one else has jumped in:
--the timing base is moved by the throttle lever linkage, so it should be quite easy to move it; the force needed should not be any greater than the force exerted by the throttle lever linkage;
--my off-the-cuff suggestion: disconnect the throttle lever linkage and try to move the timer base by hand; perhaps some corrosion developed in the week it was left in the full-throttle position, and the base is stuck in place from that.
Again, this advice is just seat-of-the-pants advice. Perhaps a real mechanic can comment.
