2016 170 Montauk Fuel Tank Installation
richiemac
Postby richiemac » Sat May 19, 2018 6:21 pm
[I have a 170 MONTAUK that has a] Mercury 90 FOURSTOKE. My 170 came with two 6.5-gallon tanks with ratcheting fill caps, a fuel level gauge, and hose connector plug. There are also two fuel-demand-valves, one for each tank. There is NO primer bulb.
From West Marine, I purchased a Moeller 22-gallon white on-deck fuel tank.
Is [a Moeller 22-gallon white on-deck fuel tank] the correct tank per EPA rules?
For venting safety?
Since I keep the boat in my garage [I am concerned].
[The Moeller 22-gallon white on-deck fuel tank] has a fuel level sensor and fill tube combination and connector for the fuel hose. The fuel cap does not have the ratchet feature. My first problem is the fuel hose coming out of the pickup tube is directly in the way of the right front tank corner.The hose will be pinched if the tank sits directly over it. This can be solved by either a 90 degree brass barbed connector, and raising tank, or drilling and moving hose over 2 to 3 inches.
The Moeller four-clamp kit does not sit properly on the tank indentations with the tank on the floor.
Thank you in advance [for comments about the tank meeting EPA requirements, the mounting problem, and the hose routing problem]
Richard
Re: 2016 170 Montauk Gas Tank Install-
Postby Phil T » Sun May 20, 2018 12:01 pm
For installation help review:
2010 Montauk 170 Moeller 22-gallon On-deck Fuel Tank Installation
http://continuouswave.com/forum/viewtopic.php?t=3046
For hold down just use footman loops and a strap fore-and-aft one-third of the width on both sides.
https://shop.hamiltonmarine.com/inet/storefront/store.php?mode=searchstore&search%5Bsearchfor%5D=footman+loop
It is recommended you install an OEM branded primer bulb; do not use aftermarket, they are inferior quality.
There isn't a ratcheted cap anymore due to updated fuel venting rules. All non-vented tanks have a cap that has a self contained relief valve set to open at 4-PSI.
richiemac
Postby richiemac » Wed May 23, 2018 11:51 am
Thank you. Richard
Re: 2016 170 Montauk Fuel Tank Installation
Postby jimh » Wed May 23, 2018 2:01 pm
richiemac wrote:...Is [a Moeller 22-gallon white on-deck fuel tank] the correct tank per EPA rules?
If the MOELLER tank is being sold in the USA, it must be compliant with any EPA, USCG, or other federal regulations. If it were not compliant, it would be illegal to sell it. Because you bought the Moeller 22-gallon white on-deck fuel tank from a reputable vendor, West Marine, I am sure the tank you bought would be compliant. That a large national retailer would be selling fuel tanks that did not comply with federal regulations about fuel tanks is unlikely.
Postby jimh » Fri May 25, 2018 12:08 pm
More advice, comments, details, and illustrations regarding installation of a Moeller on-deck fuel tank on Boston Whaler 17-foot center console boats can be found in these archived discussions:
New Moeller 24-gallon On-Deck Fuel Tank
http://continuouswave.com/ubb/Forum1/HTML/018886.html
New Moeller 24-Gallon Tank for 150 and 170 Montauk
http://continuouswave.com/ubb/Forum3/HTML/017523.html
2014 Montauk 170 Fuel Tank upgrade to 22 gallon
http://continuouswave.com/ubb/Forum3/HTML/021090.html
