13-footer Transom Reinforcement
Posted: Tue Jun 05, 2018 1:41 pm
I am currently restoring a 1968 13-footer. The engine is an Evinrude 40-HP short-shaft. Being a rounded transom, I know I need to make some sort of shim in order to get the motor to sit flat on the back. However, I was thinking about killing two birds with one stone: reinforcing the transom with a 1/4-inch to 3/8-inch [thick] aluminum plate and using the plate as a base for the shims. I have access to a machine shop so I can make whatever I need. I was thinking an 18-inch-wide or so plate that extends a few inches below the bottom of the motor mount.
Does anyone have any experience with this? Any comments? Any ideas?
Regards
Regards
