2005 DAUNTLESS 180 Ignition Key Switch
tlsch377
Postby tlsch377 » Mon Aug 19, 2019 9:05 pm
The engine ignition key switch on my 2005 180 Dauntless is very tight, and I am afraid a key may break off. There is not much room to get in behind the switch to pull it out and replace it. I've ordered a replacement.
What difficulty can I expect to have in replacing the ignition key switch?
Re: 2005 DAUNTLESS 180 Ignition KeybSwitch
Postby jimh » Tue Aug 20, 2019 6:19 am
Is the switch shown on the boat’s electrical schematic diagram? Check to see if there is a connector between the switch and the main engine harness.
What engine is on the boat?
Is the switch mounted on its own sub panel?
floater
Re: 2005 DAUNTLESS 180 Ignition Key Switch
Postby floater » Tue Aug 20, 2019 10:33 am
I just replaced the Mercury Key Switch on my 1988 Revenge 20 WT. The original switch had ten wires coming out the back and the replacement only had six. It was a very easy switch over. The wires on my original and the replacement matched color so it was simply a case of cut the original wire and solder in the new with a marine shrink wrap over top. Very easy too do. I made a diagram where each wire goes anyways just to be sure.
Postby biggiefl » Tue Aug 20, 2019 11:19 am
Have you tried spraying WD40 in the switch to loosen it up?
