1986 Montauk Steering Wheel Cap, Bezel
Bearsville
Postby Bearsville » Sun Mar 29, 2020 11:22 am
[Where can I buy] a a new steering wheel cap and new steering wheel bezel for a 1986 Montauk [17]? [Please always mention the length or the boat--jimh]
The bezel is aluminum but badly pitted. I have a Teleflex Safe-T steering system. I see there is a plastic bezel kit but to replace with a metal bezel might be nice. Thanks.
Oldslowandugly
Re: 1986 Montauk Steering Wheel, Bezel
Postby Oldslowandugly » Mon Mar 30, 2020 10:52 am
[Boat steering wheel caps are sold on] eBay.
Caps from Boston Whaler are expensive.
I have a Teleflex plastic bezel that has stood up very well.
Re: 1986 Montauk Steering Wheel Cap, Bezel
Postby jimh » Mon Mar 30, 2020 11:03 am
Any marine retailer or vendor that sells any kind of boat steering will have replacement steering wheel center caps. You just need to specify the diameter of the cap you need for your current steering wheel, which you have not described. For example:
https://www.amazon.com/boat-steering-wh ... center+cap
If you want a steering wheel cap engraved with the Boston Whaler logotype or name, contact TWIN CITIES MARINE in Wisconsin.
If you want a replacement bezel for the helm assembly, look for a replacement part from the OEM. It is likely that the OEM was Teleflex, which is now sold under the name SEASTAR SOLUTIONS. See
http://www.seastarsolutions.com/
Their products are in wide distribution and should be easily purchased. Contact them for further advice if you have trouble locating a local supplier of their products.
For advice on steering wheel replacement, see the article in REFERENCE on OEM vendors:
Original Equipment Manufacturers and
Recommended Vendors
http://continuouswave.com/whaler/reference/OEM.html
Postby biggiefl » Mon Mar 30, 2020 11:09 am
Bezels are available in anodized aluminum, and they look nice when you have matching gauge bezels.
Bearsville
Postby Bearsville » Mon Mar 30, 2020 2:00 pm
Everyone—Thanks for the responses,
I thought I was a very good "Googler" and had done a good job looking for the steering wheel cap. However, Kudos to jimh for being the master searcher.
I will look into the SeaStar info for the anodized bezel.
