11 TENDER Plans to Change to Cable Steering
Lost1
Postby Lost1 » Tue Feb 02, 2021 10:43 am
Hi all, I am a new guy here with an 11 TENDER. The 11 TENDER has the classic wire-rope-and-pulley steering system. I am considering changing to a rotary steering system, maybe a Safe-T QC rotary steering system.
[Question soliciting a survey has been removed. Do not ask questions that are in the form of a survey, such as "Has anyone..." Instead, please ask a direct question.--Moderator.]
[The implied content of this thread is to solicit advice about installation of a cable steering system on an 11 TENDER, in particular the SAFE-T QC rotary steering system. Please respond if you have advice to offer.--Moderator]
ASIDE: I am currently preparing the hull for new paint.
Re: 11 TENDER Plans to Change to Cable Steering
Postby jimh » Tue Feb 02, 2021 11:29 am
I do not have actual experience with installation of a cable steering system on an 11 TENDER, but I do suggest that you give careful consideration to how the actuator rod of a cable steering system will be anchored in place. Usually the actuator rod on a cable steering system is passed through the engine tilt tube. This requires the transom to have a straight, non-curved profile. In some smaller Boston Whaler boats the actuator for cable steering was anchored to the transom using a specialized pivoting bracket.
Fig. 1. A cable steering system with the actuator fixed to the curved transom of a small Boston Whaler boat using a pivoting bracket. In this instance the boat is an older 13-footer.
Also, use of a through-tilt-tube actuator requires the engine to have a tilt tube.
Postby biggiefl » Tue Feb 02, 2021 12:23 pm
Aside: A TENDER model would not have steering, it would be a tiller model. The SPORT model has a side console and steering whether it is used as a tender to a yacht or not.
Lost1
Postby Lost1 » Tue Feb 02, 2021 5:06 pm
Thanks for the response's. My apologies for not following posting format. Tender or Sport? Mine has a wheel and was a tender on a large Hatteras.
Postby biggiefl » Wed Feb 03, 2021 10:31 am
A Sport T/T
