MONTAUK 17: Source for Replacement Windshields
fina
Postby fina » Fri Jun 25, 2021 11:43 am
Both my 2002 and 2004 Montauk 17 have broken windshields.
What vendor has the cheapest replacement windshields?
Re: MONTAUK 17: Source for Replacement Windshields
Postby jimh » Fri Jun 25, 2021 2:31 pm
I suspect that any source for a replacement windshield for a classic MONTAUK 17 won't have the item sitting on the shelf. A vendor would likely make a replacement windshield once he receives your order and pre-payment.
If you are located in a reasonably-sized metropolitan area, there may be a custom plexiglass shop that could make a replacement windshield for you using the existing windshields as a pattern.
Perhaps others know of a vendor who ships replacements to customers and has a stock pattern.
A good place to start to determine a price: call an authorized Boston Whaler dealer who specializes in replacement parts, such as
--TWIN CITIES MARINE in Wisconsin
--NAUSET MARINE in Massachusetts
They should be able to give you a quote. You can decide how much further effort is required for you to find a less-expensive source.
Postby Phil T » Tue Jun 29, 2021 7:17 pm
Fina -
UPD is the primary vendor that Sue and Nauset uses.
They are backed up MONTHS.
Considering this, get a sheet and heat it and bend it yourself.
fina
Postby fina » Thu Jul 08, 2021 3:36 pm
Thanks for the replies.
