Keel Guard for Hulls with Rounded Keel Edge
Serapis
Postby Serapis » Mon Apr 22, 2024 5:14 pm
I have a 1973 17-footer whose hull does not have a keel that is a perfect V-shape, it has a U-shape. I emailed KeelGuard to see if one of their guards would fit on the shape of my hull and they advised it would not.
I would like to hear from others who have experience and success with KeelGuard (or another brand) with hulls that have a rounded keel shape.
Re: Keel Guard
Postby Jefecinco » Tue Apr 23, 2024 10:13 am
You may find a site search useful. I have seen a keel guard used on a small Boston Whaler but don't know what year or model it was.
Re: Keel Guard for Hulls with Rounded Keel Edge
Postby jimh » Tue Apr 23, 2024 10:35 am
Perhaps you can fabricate your own keel guard. The method would be:
  • Apply some release agent to the keel or even a layer of very thin plastic wrap;
  • make a impression mold of the keel, including any portion of the stem that you want to protect;
  • using the mold, create a plug which will serve as a mold without having to use the actual hull;
  • using the plug, laminate your own keel guard using the appropriate materials and resins
  • remove the keel guard from the plug, and trim it to have a uniform edge and size
  • affix the keel guard to the boat using a strong adhesive
You could also attempt to apply the chosen material for the keel guard directly to the hull, but I think the method I propose of making a plug will be easier to actually laminate a keel guard that will exactly fit the hull than if you tried doing on the hull itself.
As for what material to use to make the keel guard, I suppose you could use carbon fiber, but that advice would be tempered by a tendency for carbon fiber to loose strength with abrasion. KEVLAR might also be appropriate.
There are also commercially available kits like these from Keel-Eazy
https://www.keeleazy.com/collections/keeleazy-store
and
https://www.keeleazy.com/pages/faqs
I have no experience with this product, but it looks easy and does not cost a fortune. The material used is apparently able to CONFORM to the shape of the hull bottom to which it will be adhered by an adhesive.
Postby jimh » Tue Apr 23, 2024 10:39 am
Serapis wrote:I have a 1973 17-footer whose hull does not have a keel that is a perfect V-shape, it has a U-shape.
What model is your 1973 17-footer?
In 1973, Boston Whaler referred to their 16-foot 7-inch hull as a 16-footer. The aft portion of that hull is a completely rounded bottom. The bow stem and forward entry part of the hull is a V-shape, but it may not terminal in a razor edge.
