1990 25 Revenge W-T WD Twin Engine Re-power
Posted: Fri Sep 29, 2017 7:53 am
I am considering purchasing a 1990 Revenge 25 W-T WD rigged with 1989 Yamaha150-HP two-stroke engines. It needs repowering. From what I have read, the 25 Whaler Drive models should have 20-inchshaft outboard if running with a dual motor set up. Correct?
What would be the impact of running dual 25-inch-shaft engine besides drawing more water?
My challenge seems to be locating a pair of dual 20-inch-shaft counter-rotating motors. Anyone still produce them? Am I better trying to find a set of low hour used motors? Would prefer Yamaha or E-TEC engines and to keep the weight as low as possible.
Another question: is it possible to convert a right hand rotation outboard to a left hand counter rotating motor?
Tom
Tom
