C.1980 Outrage 25 200-HP
Ltwhaler
Postby Ltwhaler » Tue Oct 01, 2019 8:18 am
Would a single 200-HP four-stroke-power-cycle outboard engine be adequate power for a c.1980 OUTRAGE 25 notched transom boat?
The intended target boat speed is be 37 to 39-MPH and for the boat to plane properly and not struggle.
Ltwhaler
Re: 25 Outrage 1980's 200hp
Postby Ltwhaler » Tue Oct 01, 2019 8:25 am
Advice based on first hand experience with an OUTRAGE 25 with a single 200-HP engine of four-stroke-power-cycle design is solicited.
Re: C.1980 Outrage 25 200-HP
Postby jimh » Tue Oct 01, 2019 11:28 am
I cannot offer any first-hand experience with a c.1980 OUTRAGE 25 notched transom boat with a 200-
HP four-stroke-power-cycle engine for maximum speed and ease of acceleration to hydroplane.
I can point to the specification by the boat builder that the minimum power to reach plane is 115-HP.
Cf.:
http://continuouswave.com/whaler/reference/specifications.html#hulls24-31
Ltwhaler
Postby Ltwhaler » Tue Oct 01, 2019 12:38 pm
Thanks for the link but I've already about worn out that page looking and researching and double checking.
Postby jimh » Tue Oct 01, 2019 1:29 pm
A corollary: my REVENGE 22 W-T WD is the same length as an OUTRAGE 25 notched transom boat, but with a narrower hull that may be harder to plane. It is at least 600-lbs lighter, so perhaps a bit unsuitable for direct comparison. With 225-HP it jumps on plane and goes 44-MPH when light and in favorable good conditions.
Q: Which 200-HP engine are you specifically thinking about?
Ltwhaler
Postby Ltwhaler » Tue Oct 01, 2019 1:41 pm
jimh wrote:Which 200-HP engine are you specifically thinking about?
Suzuki 200. I believe they are large displacement four-cylinders
Postby jimh » Wed Oct 02, 2019 7:19 am
Your description is ambiguous. There are several SUZUKI engines available at the 200-HP rating. Some are V6 3.6-liter engines, which would be considered large displacement, and others are L4 2.87-liter engines, which are not considered large displacement.
Please disambiguate the particular SUZUKI 200-HP engine you are considering for powering the OUTRAGE 25.
Ltwhaler
Postby Ltwhaler » Thu Oct 03, 2019 6:01 am
jimh wrote:Your description is ambiguous. There are several SUZUKI engines available at the 200-HP rating. Some are V6 3.6-liter engines, which would be considered large displacement, and others are L4 2.87-liter engines, which are not considered large displacement.
200's are 4 cylinders. 2.9 liters I believe. " DF200A is an "In Line" four-stroke outboard is packed with technology. This four-stroke engine has large displacement, lots of torque and plenty of power"
V6's start at 225.
Postby jimh » Thu Oct 03, 2019 8:08 am
The Suzuki DF200 is a V6 3.6-liter engine. The DF200A is an L4 2.87-liter.
Which one were you planning to use?
Postby biggiefl » Mon Oct 07, 2019 11:25 am
Did they make the 25 in 1979? If so the 1979 brochure was the last year they posted performance numbers with the max and min hp. I would think I would want the larger displacement engine if going with a 200. The difference of a 200 vs 225 would be minimal in my opinion.
