ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: The Whaler GAM or General Area Fuel Consumption of Older 2-cycle versus New 4-cycle
Author | Topic: Fuel Consumption of Older 2-cycle versus New 4-cycle |
sitotis |
posted 01-08-2008 09:43 AM ET (US)
Approximately how much less fuel would I burn by going from a carburetor two-cycle versus a new four-cycle outboard? Would it be 25% less? 50% less? I currently have a 1997 Yamaha 200-HP. With gas likely to be at $4/gal this summer, I want to start evaluating the justification for a repower. |
boatdryver |
posted 01-08-2008 09:50 AM ET (US)
While you are waiting for responses from owners, try the search function on this site. You will find some anecdotal information. JimL |
sitotis |
posted 01-08-2008 10:18 AM ET (US)
There are a lot of in-depth comparisons on the site, but I haven't seen anything this simple. What I would like to see is: For every 100 gallons of gas burned by a carbed 200hp 2-Stroke, the following engines of the same HP would have burned about X gallons: 2-Stroke EFI: I'm just looking for approximations. |
Buckda |
posted 01-08-2008 10:37 AM ET (US)
It will vary. The new technology motors get exceptionally better "fuel economy" at idle, no wake and trolling speeds. The benefits drop off somewhat afterwards, but are still present and significant. Trust me though, I've run the numbers. You have to use your boat a "boatload" of hours (above 300 a season) to justify a new motor based on economics alone. For most people, the benefits of smoke-free, quiet operation, as well as the environmental benefits, factor heavily into the justification. I would check the Whaler Website - I believe they supply both the VERADO (Supercharged 4-stroke) and the Optimax (DFI 2-stroke) numbers on your hull. |
sitotis |
posted 01-08-2008 11:39 AM ET (US)
I looked at the Verado and Optimax comparisons on the Whaler site. My conclusion is that they have comparable fuel efficiency, but the Optimax has better performance. My difficulty is that I don't have these charts for an engine like mine. I also don't have a fuel flow meter to know what I am getting now. Every time I have seen these comparison charts, they are for the newer technology engines. I would expect it be easier to find a chart with a carbed 2-Stroke overlayed as well. Maybe someone knows of one? |
Tohsgib |
posted 01-08-2008 12:17 PM ET (US)
From MY experience I would guess that you burn about 11gph at cruise (<4,000rpm). A new 200 no matter what type would burn about 8. The main thing to know is what do I burn per fillup? Anotherwords my 225hp Johnson would burn about 8gph per tank(64 gals in 8 hours, etc). My 115 4 stroke burns less than 3 per tank. So even if I had twins I would burn less than my single 225 did. Also my 40hp Evinrude 2 smoke burns about the same as my 70hp Suzuki. |
L H G |
Maybe I can help. I have Merc 200 EFI's, 1997 models, similar to your same year carbed Yamaha. When I switched from carbed Merc's to same HP EFI's, I picked up about 10% better fuel economy, on same rig. My Mercury service guy at Sundance Marine in Ft Lauderdale, a highly experienced guy on V-6 outboards, tells me I could see about 45% better overall fuel economy by repowering the EFI's with 175 or 200 HP Optimax engines. That is what his experience has been, from the hundreds of owners he has worked with. From what I can tell, and have seen in test reports, Optimax's are just about the fuel economy champions of all outboards, or at least are right up there with the best 4-strokes. There is also a fuel and rate of return calculator buried somewhere here on CW that helps show the amortization costs of a new repower. My guess is you'll be ahead after about 3 years, and from there on out it's all savings. |
sternorama |
posted 01-08-2008 12:39 PM ET (US)
I don't have the exact answer you are looking for, but would agree with what Buckda says-especially about the justification. Rough numbers, you will use 25-50% less gas. That being said, once you have made the change, there is a strange thing that happens-at least to me. I no longer even think about how much gas I am going to use, because it really isn't that much. Granted, I have a smaller boat and motor than you (Yamaha F115), so my numbers are probably more favorable, but I have made 70 mile trips and come back to the gas station for 15 gallons of gas! Also, I am a fan of quiet motors, so that really is a plus to me. Don't get me wrong, I love the 2-strokes too, but I am quite happy with the 4. |
sitotis |
posted 01-08-2008 12:42 PM ET (US)
So averaging what both you are estimating: Carbed 2-Stroke: 100 Could I expect that an e-Tec and other brand 4-strokes would be in the 60 range also? I read through the threads that the Suzuki's seem to be exceptionally fuel efficient. |
Liteamorn |
posted 01-08-2008 12:49 PM ET (US)
My 1989 Wellcraft Coastal had a carburated Yamaha 150 on it. My 2005 Eastport (about 300 lbs heavier) has an Optimax 150 on it. The Optimax burns approx. 1/3 less fuel. I know it's not a four stroke but it might help some as far as comparisons. |
L H G |
posted 01-08-2008 12:54 PM ET (US)
You might want to check out some the relative information here between the different brands: http://www.mercurymarine.com/look_deeper/head_to_head.php?ID=57&Filter=3 . |
cooper1958nc |
posted 01-08-2008 01:54 PM ET (US)
Two strokes rely on gas dynamics to scavange exhaust and intake fuel/air. Those dynamics change with RPM and manifold pressure. At optimum conditions the intake stays in and the exhaust gets out, but at suboptimum conditions like idle, a lot of intake goes out the exhaust. Computer two strokes solve a lot of gas dynamic problems by regulating the timing and amount of fuel entry. This is designed to let the intake air out the exhaust but without the fuel. The point is that at optimum high speed cruise, specific fuel consumptions of carburated two strokes is probably around .55 to .6 (in lbs/hp-hr), whereas computer two strokes run .50 to .55. At idle, carbs use like .75 or more, and computer engines pretty much stay at .50 range. |
Peter |
posted 01-08-2008 03:13 PM ET (US)
The fuel savings are directly dependent upon usage. For example, a 200 HP carbureted/EFI 2-stroke will burn about 2 GPH at 1000 RPM. See www.yamaha-motor.com/assets/products/otb/bulletins/ bulletin_otb_2StrokePerf_OX666_200hp_02-188-CEN-B.pdf . A 200 HP 4-stroke will burn about 1 GPH at idle. See www.yamaha-motor.com/assets/products/otb/bulletins/ bulletin_4stroke_hpv6_gyt3_alm-tourn195sport-f200txr.pdf . That seems like a huge difference in terms of percentage but its only a savings of about $4.00 per hour at idle speed. Now let's look at cruise. At a 4000 RPM cruise for the 2-stroke, 200, the consumption is about 11 GPH. The 4-stroke won't be able to keep up with the 2-stroke if run at 4000 RPM so you'd have to nudge the throttle up to 4500 RPM. At 4500 RPM, the 200 4-stroke is consuming about 10.5 GPH. So at cruise, you'd be saving about $2.00 per operating hour. So your hourly savings by going to a 4-stroke ranges between $2 and $4 depending on how fast you operate the motor. So for a typical 50 hour season, your gas cost savings will be in the neighborhood of $100 (if all hours are at cruise) to $200 per year (if all hours are at 1000 RPM). How many 50 hour seasons would you have to operate with this kind of savings before you broke even on the cost of the new motor, rigging labor, taxes, less a trivial trade in amount for a 10 year old motor,etc. the net sum of which is probably well north of $12,000? My advice...run your old motor until it dies. |
sitotis |
posted 01-08-2008 04:00 PM ET (US)
If the difference at cruise is really that minimal, you're right. It would meke no sense for me to repower until it dies. We use it mainly for skiing/tubing and for cruising. We rarely troll or idle for long periods of time. |
Perry |
posted 01-08-2008 04:24 PM ET (US)
Peter brings up some good points but the performance bulletins he is using for comparison are EFI 2 stroke vs. EFI 4 stroke. A carburated 2 stroke motor like the one you have on your boat will drink more fuel than the OX66 200 HP Yamaha EFI used as a comparison. Your fuel savings by going to a new 4 stroke may never be recuperated but you will have a quiet, clean, reliable new motor on your boat. |
Peter |
posted 01-08-2008 05:18 PM ET (US)
Perry -- The EFI 2-strokes really aren't any better on gas than the carb'd 2-strokes although some may have been led to believe that they are. At least in the Yamaha world this what Yamaha reports: 150 Carb'd ==> www.yamaha-motor.com/assets/products/otb/bulletins/ bulletin_otb_2StrokePerf_HPMidPort_150hp_02-189-CEN-B.pdf to 150 EFI ==> www.yamaha-motor.com/assets/products/otb/bulletins/ bulletin_otb_2StrokePerf_OX666_150hp_0112-CEN-Z.pdf |
BQUICK |
posted 01-08-2008 05:32 PM ET (US)
Don't forget about cylinder deactivation at low speeds on the injected 2 strokes as a way of increasing economy and emissions. Personally I don't like a motor missing at low speeds. Right now I'm happy to pay the extra fuel to keep my old carbed 2 stroke guzzlers going. Can't afford the new motors anyway...... |
jimp |
posted 01-08-2008 05:33 PM ET (US)
sitotis - In 2003 I repowered my 1990 Revenge 22 W.T. with a new 2003 225 Merc Optimax DFI. The Optimax replaced a carbed 1989 Johnson 225. I never had the numbers, but I always felt that I got about 2.0 nautical miles per gallon on the Johnson. That was at 4,000-4,200 RPM and a bit over 24 knot cruising speed. With the 2003 Optimax, I now cruise at 3,750 RPM and 29.3 knots and getting about 3.1 nautical miles per gallon (or thereabouts). We made one long run (fully loaded with camping gear, extra fuel, water, 2 POB and running at 3,900 RPM) of about 138 nautical miles burning about 46 gallons of gas = 3.0 nmpg. In 2003 the Optimax was several thousand dollars cheaper than the 4-stroke engines. From what I know, the Optimax DFI and 4-stroke are close in fuel consumption at crise. JimP |
contender |
posted 01-08-2008 06:49 PM ET (US)
I totally agree with Peter, The amount you are trying to save vs. just using your old engine is not worth it. If you are buying a new engine thats a different story. I would use my old engine until it dies or if I hit the lotto...good luck |
L H G |
posted 01-08-2008 06:56 PM ET (US)
Yes, I agree with Peter here too. Keep polluting the water and air as long as you can and burning up all that gasoline. That's what most of us here on CW are doing anyway. We all talk a good line here on 3-star fuel economy, as long as it's the other guy spending the money for the new engines. It would be wrong to ask you to do your share of cleaning up the water and air when the rest of us aren't doing it at all. |
sitotis |
posted 01-08-2008 07:20 PM ET (US)
jimp, Your experience agrees with what the Yamaha customer service told me today when I called. Their customer service rep did not have any data to back up his comments, but he expected I would see about 30% better fuel efficiency from a Yamaha HPDI vs. the engine I have now. If I cruise with my current engine at 30mph at say 2mpg, that's 15gph. If I put say 50 cruising hours on the boat in a season, that's 750 gallons of gas. Cost: $3000 Annual savings with a new engine: $1000 At this rate, it would be hard to justify a new engine ($8k-$12K + accessories), but it might be worth actively keeping an eye out for a used one, or a rebuilt. |
jimp |
posted 01-08-2008 07:31 PM ET (US)
sitotis - I had to bite the bullet as my old 1989 225 Johnson self destructed. Local mechanic said $8,000 to fix (block, crankshaft, pistons, etc) a 14 year old engine. So spending $13K for new engine was easy (but still painful). JimP |
gss036 |
posted 01-08-2008 08:53 PM ET (US)
I am in the same boat with a 200 hp carbed Merc. I figure I burn 10-12gph and am happy with that so I will rum my old Mercury until it implodes and then the struggle begins as to what to repower with. That is the $64,000 question for us all. |
posted 01-08-2008 11:24 PM ET (US)
The financial analysis is provided in Engine Cost Analysis Spreadsheet The spreadsheet grew out of a long discussion New Engine: When to Buy The most optimistic prediction of fuel savings is probably about a 50-percent reduction in fuel consumption. The least optimistic is probably about a 30-percent reduction in consumption. As pointed out already, the amount of use becomes an important factor in the calculation. That parameter is an individual factor and depends on each person's habits. |
deepwater |
posted 01-09-2008 12:13 AM ET (US)
Your boat plus your local conditions plus the way you drive and how you trim your boat will determine the amount of fuel used. |
Tohsgib |
posted 01-09-2008 11:55 AM ET (US)
I disagree with one thing...it "might" not take the 4s 4500 to run the same speed as a 2s does at 4k. I say might because it depends on what the 2s engine is. If the 2s redlines at 6k and the 4s redlines at 6k they will probably run within a hundred rpm of each other. If the 2s redlines at 5300 and the 4s redlines at 6200, sure the 4s might have to run at 4500 to do the same but the 2s was also running closer to its redline. For example my friend has a 23 Seacraft that many here have seen. It had twin 130 Yamahas. He repowered with twin 115 Suzuki 4 strokes which weigh about 150lbs more and 30hp less. He lost 1mph at cruise and 1mph at WOT but at cruise he went from 14+gph to 10+. Per tank he was almost 1/2 what the 2s did. Matter of fact his Suzukis are so much more efficient that when he replaced his fuel tank last year he went with a 100gal instead of the 170 in there. My other thought about this is those who have NOT repowered with a 4s or DFI over a conventional 2s, please keep out of these discussions with your flowcharts and biased manufacturers study charts, etc. You REALLY have no idea what the advantages are but when you do "hop on the bandwagon" I can't wait to hear you eat your words, especially when you say "WHY did I nurse that POS for so long? This engine is HEAVEN". Trust me...you will. I have known about 60 good friends who have gone green and NOT one of them regrets it, most are dumbfounded on how nice it is having something so quiet, efficient, reliable, no more priming bulbs, pumping throttles, sneezing, coughing, shaking, stalling, etc. Just turn the key and vroom!....EVERYTIME. Most have done what you guys suggest, and I have also, which is keep her alive till it blows. You know what though? That is the most frustrating last couple seasons you will experience and the amount of time & $$ wasted trying to keep it alive, would have made for a nice down payment and you would still have a running engine to sell or trade-in instead of a blown POS sittin in your yard. Lastly...we assume you have a clean, reliable, smooth running 1997 Yamaa 200(not HPDI) that serves all your needs except it is a tad thirsty. I agree with most that you are beter off keeping it until you need/want to repower. Doing it for a couple GPH is not prudent. If you are concerned about your reliability and wish to repower than do so, but don't don't just do it for MPG unless you put a lot of hours a season on her which in that case your 1997 might be close to worn out after 11 years. |
L H G |
posted 01-09-2008 02:01 PM ET (US)
Nick - don't let "LO-TEC Peter" get to you with his never ending diatribes against Yamaha, Verado and other 4-stroke engines. He's only following the BRP company advertizing pitch, and doing as he's been instructed. |
Tom W Clark |
posted 01-09-2008 02:52 PM ET (US)
I am going to remain a sceptic in this discussion (but would like to be persuaded.) Jim H. in his summary of the presentation of the financial analysis above suggests an improvement of 30-50 percent. Jim P's own experience suggests an improvement of over 50 percent. Nick's friend's experience show an improvement of over 40 percent. If I were take these figures and apply them to my own Revenge 25 Walk Through with twin carburetor equipped two stroke 150 outboard motors, which will get 2.3 MPG, I am lead to believe I could see 3 MPG to 3.5 MPG if I were to repower with four stoke power? I don't think so. Somebody please show me credible documentation of a Revenge 25 Walk Through (or other 25 foot Whaler) that gets 3-3.5 MPG at cruise speed. |
Peter |
posted 01-09-2008 03:01 PM ET (US)
Larry, Larry, Larry -- Sirotis' original quiry was: Approximately how much less fuel would I burn by going from a carburetor two-cycle versus a new four-cycle outboard? So I answered the question and I did it in the context of a Yamaha 200 HP 4-stroke because 1) Sirotis owns a 200 Yamaha, 2) unlike Mercury, Yamaha has a wealth of performance information about its products including products now obsolete like the EFI Ox66 200 which has the same consumption profile as a carbureted 200, and 3) if Sirotis repowered, it would likely be with a Yamaha 4-stroke so he could reuse his controls and SAVE money, which is the underlying basis for Sirotis' inquiry. But to alleviate whatever 4-stroke paranoia you may be experiencing, if Sirotis repowered with a Yamaha because it would require the least rerigging effort and expense, the cost savings would be even less than predicted with the 4-stroke because the HPDI system is not nearly as fuel efficient in the idle speed range as a 4-stroke or the DFI 2-strokes that use stratified charging. If you have any doubts about this, then I suggest you compare the 1000 RPM number from to this www.evinrude.com/NR/rdonlyres/67F35EC8-EFB4-4B38-BD2C-E679A96A7441/0/ PE451.pdf Since you are and have been the resident Mercury sales man here for quite some time, Larry, I'll leave it to you to contribute your own useful Mercury materials rather than the "bias manufacturers study charts" which contain only self promoting conclusions and none of the underlying facts that led them to such. Oh yea, unlike you, Larry, I actually own and operate two DFI 2-strokes that run with the stratified charge mode each of which burn 0.3 GPH at idle and about 0.6 GPH at 1000 RPM per the Navman F3100 (have you got a fuel management computer on your boat?). Unlike you, I've actually owned and operated a carb'd 2-stroke Yamaha. Unlike you, I've actually owned and operated a Yamaha EFI Ox66 2-stroke and have observed the same fuel consumption rates Yamaha sets forth in its published reports. As I said before, there may be other reasons to justify a repower, but fuel cost savings alone rarely provides a sufficient economic reason to repower. Seems like many others come out the same way. |
L H G |
posted 01-09-2008 03:11 PM ET (US)
Tom: First of all those doggy old Merc 150's of yours are giving remarkably good mileage at 2.3 MPG on a boat that size. JimH's smaller, and much lighter 22 Revenge with 225 single OMC only gets 1.75 MPG. My 25 with the 200EFI's only gets 2.0 MPG. If you look at Cetacesa Page 78 you will see JimH and I, and ladies + driver, riding in BW 240 Outrage, dry hull weight of 4400#, heavier hull and deeper Vee than your Revenge, with twin 150 Opti's running 19" Vengeance props. The boat was running 51 MPH on GPS and registering 3.1 MPG wide open. So your figures may be OK, or close. I know where you can buy a new CR pair of Gen I Verado 150's for 18.3K if interested! |
L H G |
posted 01-09-2008 03:14 PM ET (US)
As I have said before, Peter, I am very much aware that you and Fourdy walk on water. |
Tom W Clark |
posted 01-09-2008 03:26 PM ET (US)
Larry, I am sorry, you are wrong. The Outrage 240 you were in was not getting 3.1 MPG at WOT. Perhaps you were looking at the readout of just one of the two engines which would suggest the boat was getting 1.55 MPG at WOT which is consistent with Whaler's performance data of that boat and motor combination. http://www.whaler.com/rec/pdfs/performance/13.pdf But all of these is misses the point. I would like to see a [b]four stroke[/] power option that offers me 3-3.5 MPG on my boat. I don't think the Verado 150s are going to be the answer as Whaler's performance data for the aforementioned Outrage 240 with Verado 150s show that it actually gets worse fuel mileage than the two stroke outboards. Perhaps my expectations are too high. Is there a four stroke power option that would offer an fuel mileage improvement of any kind? |
L H G |
posted 01-09-2008 06:17 PM ET (US)
Tom: Looking at that report, I note that my actual experience in that boat was slighly better than Whaler indicates. I know I saw the 51.x MPH top end, and I also know I saw the Smartcraft readout on combined engine fuel economy of 3.1 MPG. But looking at the Whaler figures at 3500/30 MPH cruise, I see 2.86 MPG, so the economy figure I saw must have also been at that cruise. Maybe Jimh can verify. But isn't that what you were looking for anyway? I assume your 2.3 figure was cruise also. For me, the 150 Opti's would be a 50% improvement, for you with less HP and smaller cubes, somewhat less, but still pretty good. |
Tom W Clark |
posted 01-09-2008 11:47 PM ET (US)
Again, I ask: what four stroke power will give my boat 3-3.5 MPG fuel mileage? |
posted 01-10-2008 12:00 AM ET (US)
My 225-HP Evinrude V6 gets between 1.9 and 2.3 MPG at around 27-MPH cruise, depending on: --air temperature (colder is better) and this is really where the engine and boat operate most efficiently. At any other speed range, at idle, slower, or faster, the MPG declines. On a long term basis I have collected some data at: http://continuouswave.com/whaler/reference/propellerWDSingle. html#seasonalData which shows that 1.7 to 1.8 MPG average is about right, but that includes a lot of low speed operation where the motor is very wasteful of fuel. What I have learned, however, is that the total fuel economy is most influenced by the fuel economy where most of the fuel is burned. Because so much more fuel is burned at cruise than at idle, the fuel economy differential at cruise will have the biggest impact on the total fuel economy average. This means that a new engine will probably be better at cruise, of course, but it won't be twice as good, that is, it won't cut the fuel in half. I'd say more like a 30-percent improvement. So if I get 2-MPG now, I'd be happy with 2.6-MPG with the new motor, and anything more would be a bonus. At lower speeds the difference will be much greater. At idle, where now I get sometimes a fuel economy of a terrible 1.5-MPG, I would probably get 4-MPG or higher. The irony of this, and not very clear to most people, is that the better the fuel economy at idle, the less it effects the average fuel economy, even if you spend a lot of time at idle. I explain this in my reference article, but it does not seem to have made much impact on readers. Regarding the mileage for the pair of OptiMax engines mentioned above and in Cetacea Page 78, I really do not recall now any particular figure, and I would have to go with whatever I wrote in the article, when it was much fresher in my mind. I am a bit more suspicious of any motor's self-measured fuel economy numbers now than I used to be. I think they all are a little on the optimistic side of complete accuracy. |
posted 01-10-2008 12:11 AM ET (US)
Also, the MPG mentioned in the Cetacea article might have been grabbed off the readout at some point where there were favorable wind, current, and tide all assisting the vessel. It was just a number that popped up on the readout of the multi-function gauge, not a scientific measurement over a measured course with runs in both directions. |
posted 01-10-2008 12:21 AM ET (US)
My apologies, I didn't read with enough care: Let me clarify my recollection. The OUTRAGE with twin OptiMax and 3.1-MPG was at a cruise speed, albeit a fast one, but not at WOT. Probably at 28-MPH to 30-MPH. That I do seem to recall with some certainty. Heck, if I could get 3.1-MPG at cruise on my boat, well, I'd do 50-percent more boating! Actually, I want the better mileage not so much to save a buck--although believe me, I like saving a buck as much or more than most--but more for increase in range. I'd like to make some long runs up in Lake Superior some time in the future, and more MPG means more range. Right now, if I want to run 45-miles offshore to Michipicoten Island, cruise around for a day, then run 100 miles up the coast to the next port, I will be running on fumes from my 77-gallon tank with the current set up. If I can bump up to 3-MPG, I can increase my range to 200-miles between gas stops. |
posted 01-10-2008 12:52 AM ET (US)
Forgive me, but I am really waxing prolix tonight. If Tom says he gets 2.3-MPG at cruise now with his old two-cycle motors, and if we apply the 30-percent improvement factor, he will have to get 3-MPG with the new motors. It may be hard to find a set up where he is going to get 3-MPG from a pair of new motors at cruise. Like Tom, I have looked at fuel consumption rates for modern motors in applications which I think are reasonably comparable to my current boat and motor situation, and, as Tom Clark has suggested, it is hard to find examples where you can see a stunning improvement in MPG at optimum cruise speed. In my case I figure my reliable cruise is about 2.0 to 2.1-MPG, so I just have to get up to 2.6 to 2.7-MPG to make a 30-percent improvement. When I look at test results for single 225-HP motors spinning 17-inch propellers on fairly big 22 to 24 foot boats, I don't see too many numbers better than 2.7-MPG. Here is a typical report, a 225-HP E-TEC on a big 22-footer: http://www.evinrude.com/NR/rdonlyres/ 586B65F8-5917-4131-B887-581555C8D507/0/PE444.pdf The fuel economy at cruise is 2.7-MPG. I use that as a guideline to what I would probably get. That's a 30-percent improvement at cruise. I doubt you can do much better. Now that same report shows about 7-MPG at idle or no-wake speed, which is vastly better than my current 1.5 to 1.7-MPG. That is where I will pick a lot of improvement. That's my method of estimating the future. Find a report for a situation close to yours and compare. |
Perry |
posted 01-10-2008 01:33 AM ET (US)
Jim, here is a performance report of a 22.5 foot walkaround with a 225 4 stroke. It gets 3.9 MPG at cruise. http://www.honda-marine.com/pdfs/ptPROLINE%209.pdf And this Mako 232 CC also with a 225 4 stroke that gets 3 MPG cruise. And a 23.5 foot walkaround with a 225 4 stroke that gets 3.1 MPG cruise. These may not be identical to you boat but I think you can get 3+ MPG with a 225 4 stroke on your 22 foot Revenge. |
Jordi |
posted 01-10-2008 08:21 AM ET (US)
Tom, At the Whaler 25 foot range a 3-3.5 MPG cruise is simply not achievable currently. I get 3-3.5 MPG cruise in my 210 Outrage 6 cyl. 200 which I consider reasonable for the heavy 21 foot hull. Jordi |
itl |
posted 01-10-2008 08:24 AM ET (US)
Rule of thumb: Traditional 2 stroke WOT fuel consumption (gph) is hp/7.2 For example, if we have 100hp 4 stroke and 2 stroke engines. WOT gas consumption is around: When running cruise speed, the difference between 4 and stroke is much smaller, but at idle the difference is much bigger. These figures are not scientific accurate, more like rough estimates. |
Peter |
posted 01-10-2008 08:44 AM ET (US)
Perry -- All of the boats in your list have a higher Crouch hull factor than Jim's Revenge. The Mako's factor is 195, the Proline's is 205 and the Triton's is 215. What that means is that they are all easier to push through the water than a Revenge. Accordingly, they will get better fuel economy than what you can expect from the Revenge, particularly one with a Whaler Drive. Using Jim's data for the 4000 RPM point for the 15 x 17 SST propeller, I calculate the consumption rate for his carb'd motor to be about 12.6 GPH. If it were an Evinrude DFI 2-stroke, he would see that consumption rate drop to about 10.5 to 11 GPH at the same 29 MPH or about 2.75 MPG. Still not quite 3 MPG at cruise but about a 20 percent improvement at 29 MPH. With a modern DFI 2-stroke or 4-stroke, the significant improvement in fuel economy over a carb'd 2-stroke comes in the off-plane, no wake speeds. For example, my twin 225 Fichts at 1000 RPM consume approximately 1.5 to 2 GPH combined pushing the 27 Whaler WD 6 MPH in the channel yielding about 3 to 4 MPG depending on the current and wind. The carb'd versions of those motors, which Jim has, would burn approximately 2.5 to 3 GPH each or about 5 to 6 GPH combined at the same RPM pushing the boat the same speed yielding about 1 MPG. Generally speaking, with carb'd 2-strokes, the MPG at off-plane, no wake speed is worse than the MPG on-plane at cruise speed. The opposite is so with DFI 2-strokes or 4-strokes, the off-plane, no wake MPG is better than the on-plane MPG. Tom would certainly see an improvement in fuel economy switching out his 150 HP Mercury 2-strokes for any of the 150 HP 4-strokes but not knowing the consumption rate for the carb'd Mercury 150s, its difficult to tell how much of an improvement. Whatever it was, most of it would come at the no-wake speeds. |
Brian7son |
posted 01-10-2008 09:15 AM ET (US)
sitotis, Several posters far more knowledgeable than I have given you some estimations on the percentage that you will save on fuel economy. I see that you are an engineer like several of my best friends. Most of my engineer friends are "very" analytical when it comes to making purchase decisions about their boats (e.g. cost vs benefit etc.). Based upon the fact that you currently own a 97 Yamaha 200 hp, I am going to assume that you own it outright "free and clear". For the heck of it, I went on Ed's Marine (website)to check the prices of 3 different new 200 hp o/b's. Suzuki 4-stroke 200hp ($10K), E-Tech 200 hp ($14.5K), Merc. Opti 200 hp ($12.8K). Let's say you go with the least expensive at $10K. Let's say you use 30% less fuel with every fill up on the 4 stroke on a 100 gallon tank. If gas is $4.00 a gallon, you would burn $120.00 less in fuel with the 4-stroke per 100 gallon tank. You would break even after the 83rd time that you bought 100 gallons of gas. So, if it's all about cost analysis to you, you should certainly consider how many time per year that you fill up your tank. If you purchased 100 gallons of gas 1 time per month, it would take almost 7 years to break even. My brief 2 cents on 2-stroke vs 4-stroke. I owned a 1999 200 hp Merc 2 stroke for 7 years and for the past 2 years have owned twin 225 2004 Merc 4-strokes. This is just based on my experience with my motors, others certainly may vary. 2-stroke had better hole shot and was a fast running engine. However, it was loud, smoky and didn’t get great fuel economy. I never knew how much the difference (noise and smoke) was until I went to 4 strokes. 4-strokes, less of a hole shot. Other than that, I have been very happy. My twins are so quiet that on several occassions, when a dock master has been casting off my lines for me at different marinas, they would say: “OK Capt. You can start your motors”. I would reply: “they are already on”. No smoke and very good fuel economy. Great for long range trips on the water. You can have a conversation while running at higher speeds without having to screami at the person standing right next to you. Good luck with your decision. Brian
Tom W Clark |
posted 01-10-2008 11:14 AM ET (US)
quote: I can imagine seeing an improvement, but I am looking for the alleged 30-50 percent improvement that is still being claimed possible when going from old carb'd two strokes to modern four strokes. It is not an improvement at idle speed that I seek; I spend very little time idling my motors and when I do, as in a Marina, I often am running only one motor. I am looking for real fuel savings, i.e. at cruise speeds. Would anybody care to make a prediction of what I could realistically expect? For the record I have measured and calculated my fuel consumption very carefully using my calibrated FloScan TwinScan fuel flow meter/totalizer. I have also verified my 2.3 MPG fuel mileage over a four hour trip between Seattle and Neah Bay last summer. Fuel consumption at optimal cruise is 14.6 gallons/hour. Fuel consumption at WOT is 31 gallons/hour. OK, offer me your best suggestions for new power along with predicted fuel mileage... |
Peter |
posted 01-10-2008 11:27 AM ET (US)
Tom -- What speed does 14.6 GPH produce and what is your top speed at 31 GPH? Also, what is the estimated weight of your boat with those results? |
Tom W Clark |
posted 01-10-2008 11:39 AM ET (US)
Peter, Now you are on to my dirty little secret: optimal cruise speed is 33.8 MPH and 47.2 at WOT. The fuel mileage verifying trip last summer was made starting with full fuel and oil, three adults, downriggers, cannon balls, god knows how many tackle boxes, three full coolers, duffle bags, camera bags, full canvas, etc. We were loaded for five days of fishing. I estimate our starting weight at 6500-7000 pounds, based on Whaler published weight of the Revenge 25 Walk Through of 4000 pounds. |
Peter |
posted 01-10-2008 12:18 PM ET (US)
Tom -- Below is what I believe to be fairly representative of what you would see with a pair of F150s assuming the weight isn't a problem. |
Tom W Clark |
posted 01-10-2008 12:27 PM ET (US)
Wow, lighter weight boat, slower top speed, and even worse fuel mileage than I get now with my old carb'd two strokes. Next? |
Peter |
posted 01-10-2008 01:23 PM ET (US)
Tom -- Here is another that is just a little faster than yours, putting your boat pretty much in between these two. I'll save you the trouble -- Next? ;) |
newt |
From my calculations, the tested weight they report is low. 4600 lb Dry weight |
newt |
posted 01-10-2008 01:26 PM ET (US)
My post was referring to the Pursuit OS 255 |
Tom W Clark |
posted 01-10-2008 01:42 PM ET (US)
OK, now you got me searching. I went to Mercury's web site and looked for some performance data for a boat with twin 150 HP four stroke power (Verado 150s) and they have none. Whaler at least has some data. The current production Whaler closest to my Revenge 25 Walk Through is the Conquest 255. Here is the test data for that boat: http://www.whaler.com/rec/pdfs/performance/14.pdf Weight as tested is 6812 pounds which comparable to my own, but look at the fuel mileage! Those Verados only get 2.29 MPG and the top speed is a mere 43.6 MPH. Next? |
JMARTIN |
posted 01-10-2008 02:27 PM ET (US)
What about a 300 single for Tom? Jeepers, you cruise fast, 34 mph. My optimum is similar to Jimh, at 2.3 average at cruise on a 22 Revenge with a 200 looper. Thats about 3500 rpm, 26 mph, two guys and gear. I do not have the Whaler Drive and my figures are a tad better. It's hard to get a really accurate figure due to the current and I am too lazy and cheap to turn aroun and get an average. I plan on running old Smokey until she croaks. John |
L H G |
posted 01-10-2008 03:29 PM ET (US)
Well, Tom's figures have confirmed to me what I already know - that the little 2.0 liter Merc 150's from 1976-1995 are among the most powerful and most economical carbed 2-strokes ever made. It does seem that even brand new Merc Opti's and E-tecs can't compete, and are not worth the money they cost. I also have one of these hot little motors on my ribside, and there it gets 3.0 MPG. Not bad, I guess - except somebody else here, with the same ribside and Merc 150 Opti, says he gets 5 mpg. Now I'm really confused. I guess I'm going to have to attack him as an uncredible witness however, since Optimax owners are known to be big liars on this site. |
Tom W Clark |
posted 01-10-2008 04:05 PM ET (US)
John, That is a thought and one I have thought of myself with the anticipated Yamaha F300. Unfortunately, Whaler has no data for the Conquest 255 with the Verado 300. They do have test data for the Verado 275 however and it does get better fuel mileage than the twin Verado 150s, but at only 2.45 MPG is a pretty marginal improvement and the top speed is no better at a rather sluggish 43.4 MPH. Next? |
Jordi |
posted 01-10-2008 05:34 PM ET (US)
Tom, Wax that baby and plan on running old Smokey until she croaks as John states. It's amazing how much effort is consumed to justify fuel efficiency in our minds. Next, Jordi |
Perry |
posted 01-10-2008 08:51 PM ET (US)
Tom, here is a 24' Mckee w/ twin 150 4 strokes loaded weight 6626 lbs that gets 3.1 MPG and similar top speed. http://www.honda-marine.com/pdfs/ptMc_kee_CRAFT_2.pdf And a 24' Carolina Skiff w/ twin 150 4 strokes that only weighs 5700 lbs loaded but gets 3.44 MPG cruise and 51 MPH top speed. Fair comparison? |
posted 01-10-2008 11:33 PM ET (US)
This is an excellent discussion. I am thoroughly enjoying it. When I look for comparable results with other hulls and motors, I look for the same horsepower and the same top speed range. I had not thought about computing the HULL FACTOR from the test data, but that is a good method. You want to compare to a hull which is similar to your hull. Tom's situation may be a bit harder to optimize because of the twin engine configuration. If he goes to twin four-cycle engines, he will add some weight. The extra weight has to be overcome, and that takes a little off the top of any gain in fuel economy from the motor. Tom--I bet your current rather fast optimum cruise puts your engine speed in the 3,500 to 4,000-RPM range. Am I right? |
Tom W Clark |
posted 01-10-2008 11:49 PM ET (US)
Perry, Good on you for finding something that might theoretically provide fuel mileage for my boat that is 30 percent better than what I get now. Of your two examples, only the McKee 24 Freedom is a good comp, and only if we take the "loaded weight" to mean "weight as tested". Note the hull weight is listed as 3600 pounds, 400 pounds less than my boat, but perhaps the difference is the added engine weight itself, as Jim points out. Also note that these twin Honda BF150s make their best mileage at only 23.6 MPH which would be a HUGE improvement for my boat. Jim, Yes, I find the best fuel mileage for my motors comes when running them at 4000-4200 RPM. That is their sweet spot. The reason I mentioned my "dirty little secret" above is that in order to achieve 2.3 MPH in my boat, it has to be run at this speed, which is VERY uncomfortable in anything but very calm conditions. In anything more than a one foot chop, I have to slow down to avoid getting beat up. This is a large part of my love/hate relationship with these motors; sure they run great but only if you go fast. This is also why I would seriously consider repowering with slightly less power. If I could achieve best fuel mileage at 25 MPH that would be wonderful. Now that I know what I am burning, it is hard for me to run the boat at 25 MPH knowing I am only getting 1.8 or 1.9 MPG when I could be getting 2.3 MPG. |
posted 01-11-2008 12:03 AM ET (US)
Tom--you and I have the same problem: we have instantaneous fuel economy read out (from our respective FloScan or Navman instruments). Having those numbers staring you in the face makes it hard to not run the boat at optimum fuel economy. If you didn't have the FloScan you'd be much happier cruising at 24-MPH. |
Tom W Clark |
OK, let's go back to John's suggestion of a single four stroke 300. Suzuki makes such a motor (the DF300) and it weighs about 600 pounds with 4.0 liters of displacement, almost exactly the total weight and displacement of my current motors. http://www.suzukimarine.com/boat_builders/boat_tests/key_west_boats_inc/ key_west_268_cc/df300/ This boat, which is clearly a larger (though perhaps not heavier) is getting 3.3 MPH at 21.5 MPH and 3.1 MPG at 25.1 MPH! Maybe there is something to be said for lower gearing turning a larger propeller ;-) |
Tom W Clark |
posted 01-11-2008 12:07 AM ET (US)
Or how about this ProLine that gets 4.0 MPH with the DF300: http://www.suzukimarine.com/boat_builders/boat_tests/proline_boats/ proline_24_super_sport/df300/ |
Perry |
posted 01-11-2008 01:47 PM ET (US)
We've discussed the possible 30-50% improvement in fuel economy on jimh's 22 Revenge and Tom's 25 Revenge but how about a more popular set-up like a carbed 150 2 stroke versus a 150 4 stroke? Many here claim 3 to 3.5 MPG with a carbed 150 HP 2 stroke on an Outrage 18. I don't think it would be too far fetched to see 4.5 to 5.5 MPG with a 150 4 stroke or DFI on a 18 Outrage. |
Tohsgib |
posted 01-11-2008 02:03 PM ET (US)
I get between 5-6mpg on my 1650lb revenge with 2 people and full fuel at 4000rpm and about 25-26mph with a DF115. I would find it pretty easy to get 4.5+ with a DF150 on the lighter 18 outrage. |
Peter |
posted 01-11-2008 03:06 PM ET (US)
Wait a minute there Tom. Are you changing the rules of the game? Are we allowed to pick 3.0 MPG wherever it may land, not just at 33 MPH? ;) If so, I think it is possible that a single 250+ 4-stroke (or even one of those "gas guzzling" DFI 2-strokes) could get you very close to, if not in, the 3 MPG cruise promised land since you don't have a Whaler Drive. That Pro-Line report looks very impressive, almost seems too good to be true. Between the two reports it seems that if you keep the Suzuki 300 at 4000 RPM or below, it has very good fuel consumption numbers. I'm guessing that 4000 RPM is probably the point where the variable valve timing (VVT) changes modes in some significant way. Perry -- Regarding the 18 Outrage, I think this is fairly representative of what you'd see for gas mileage with a 150 4-stroke or DFI 2-stroke. www.yamaha-motor.com/assets/products/otb/bulletins/ bulletin_otb_4StrokePerf_HPV6_150hp_03-16-EDG-C.pdf . |
Perry |
posted 01-11-2008 04:22 PM ET (US)
Peter I was also thinking that 6+ MPG is attainable on an 18 Outrage with a 150 4 stroke. If that is the case, we are at that magic 50% better fuel economy at cruise. According to this thread started by Buckda, he also saw around 3 MPG with his old 150 Mercury at cruise and others agree that it is a normal fuel consumption rate for his set-up. http://continuouswave.com/ubb/Forum4/HTML/003812.html So on certain applications, 50% or greater fuel economy can be achieved by repowering with a new 4 stroke. |
Peter |
posted 01-11-2008 05:25 PM ET (US)
Perry -- I don't think you'll see a 50 percent improvement in fuel efficiency at cruise on an 18 Outrage going from 2-stroke to 4-stroke, if that's what you're suggesting. The carb'd 2-strokes are thirsty but not that thirsty and especially not in the 3500 to 4000 RPM range. Overall, depending on how the boat is used, 50 percent is possible. The RPM versus speed numbers reported for the carb'd Yamaha 150 2-stroke in this report
Perry |
posted 01-11-2008 07:31 PM ET (US)
Peter, I didn't know you were comparing the fuel efficiency at the same 30 MPH speed. I was using the speed in which each motor achieved its best fuel economy as its cruise speed. Like Tom stated earlier, his optimal cruise speed was 33.8 MPH because that is where his carbed 2 strokes achieved their best fuel economy. He used the word optimal because that is where his motors burn the least amount of fuel, not because it is the most comfortable cruise speed. The link you provided to the performance test of the 18.6' Edgewater showed the F150 burned arounf 6.5 GPH at 30 MPH but it also only burnded 3.5 GPH at 20 MPH. So for the sake of a fair comparison, let's use the speed in which each motor achieves its best fuel effiniency as its cruise speed. If that is the case, 50% or greater fuel economy at cruise speed can be achieved by repowering with a new 4 stroke. |
Tom W Clark |
posted 01-12-2008 01:12 AM ET (US)
Yes, Carson is right, I don't care what the speed of best fuel mileage is (well that is not true) I'm just looking for the optimal fuel mileage in this academic discussion. I'd like to be led to believe that at least a 30 percent improvement could be had and I'd really like to see a 50 percent improvement demonstrated. In truth, I would prefer that my boat achieved it optimal fuel mileage between 25 and 30 MPH. That would make it a MUCH more comfortable boat to cruise in. Carson, There is no way that Dave "Gambler" got only 3 MPG when it had its 150 Mercury two stroke on it. That is exactly the motor I have on my Revenge x two. My boat is more than twice the boat of an Outrage 18 and uses the same pitch propeller and is capable of the same speeds. i would expect it to be able to achieve at least twice the fuel mileage if not more. That would be 4.6 MPG if not 5 MPG or more. For a four stroke to best that by 30-50 percent would really be something, and i do not believe that is going to happen.
Perry |
posted 01-12-2008 02:39 AM ET (US)
Tom, Dave had a Navman 2100 on Gambler when he observed 7-8 GPH at 24-25 MPH which equates to roughly 3 MPG and in the same thread I linked above, you said: "Dave, Sounds normal to me. Your fuel consumption figues are very similar to what I get with my Mercury 150s." I also searched Continuous Wave and found user vdbgroup stated he got 3-3.5 MPG cruise on his Outrage 18 with Yamaha 150 2 stroke. And user myakka stated his Outrage 18 with Mercury 150 2 stroke got 3.45 MPG cruise. So it appears 3-3.5 MPG cruise with a 150 carbed 2 stroke on an Outrage 18 is the norm. I am perplexed by the low fuel consumption of the carbed 2 strokes on your Revenge. Somehow you really have them sipping the gas. I bet your good fuel economy is related in part to the fact that you have your motors in good running condition and mounted at the proper height and your props are dialed in just right. |
tmann45 |
posted 01-12-2008 09:23 AM ET (US)
Perry, quote: My 1996 Outrage 21 with 1998 200 carb Mercury run similar to Tom Clark's. Maximum MPG is between 3800-4400 RPM at 3.4-3.5 MPG. Speed at this RPM is 31-36 MPH. Calibrated FloScan and GPS data. I will email two Excel files to you and Tom Clark with this data and a comparison of all of the Whaler Outrage 210 engine test data graphed. Some interesting ideas came to me looking at the graphs. Tom Manning |
Peter |
posted 01-12-2008 09:39 AM ET (US)
Right around 9 to 10.5 GPH at 3800 to 4400 RPM. Seems about right for a 200+. For carb'd 2-strokes with a redline in the 5500 RPM, the 4000 RPM point is about where their consumption rate is about 50 percent, give or take about 5, of the maximum. |
Tom W Clark |
posted 01-12-2008 11:21 AM ET (US)
Carson, OK, I certainly am not questioning the veracity of Dave's data but we are starting to cloud the discussion by mixing up two very different ideas of fuel economy. There is fuel economy at the cruise speed one usually runs one's boat, and then there is optimal fuel economy. Let's not mix them up. My boats gets its best fuel economy, 2.3 MPG at 34 MPH. At 25 MPH my motors burn about 6.5 gallons per hour I believe (I don't have my data sheets in front of me this morning.) I would like to see a full test report of speeds (measured and averaged from two directions), RPM and fuel consumption rates for Gambler when it had its Mercury 150. I suspect we will see that the best fuel economy for that motor was when it was running over 4000 RPM and at that engine speed the boat would have to be going well into the 30s which is not a comfortable cruise in an Outrage 18 in anything but baby-butt smooth water. When I bought my Revenge I was a little slow to figure this all out. It was my brother who pointed out that we could accelerate from 25 MPH to 35 MPH and the fuel flow meter hardy indicated any increase in fuel consumption. Only after running numerous propeller tests with different props did I really start to pay attention to the fuel economy figures as well. It also went against my long held belief that an outboard powered boat would get its best fuel economy at minimum planing speed when the thing was just loafing along. THIS IS NOT SO. But the real world is full of wind and waves on the water and the reality is that we may not want to, or be able to, run our boats as fast as necessary to achieve the very best fuel economy. This is where we are getting many of the anecdotal reports of fuel economy cited above. And I want to emphasize that I think it is good to discuss the fuel economy our boats get the way we actually use them because that is more realistic. But for the purposes of comparisons, let us not mix the two types of fuel economy up. In a recent too-long discussion we threw out all manner of fuel economy data from tests of different outboard motors and boats. All of these data points were OPTIMAL fuel economy, not necessarily the fuel economy one would see if they owned the boat and ran it at a different speed. There is also the fuel economy that is measured against the length of a trip against the fuel burned. In this case, idling, trolling low sped, no wake speed and cruising speed are all mixed into the calculation. This is usually going to yield a different result. The confirmed 2.3 MPG I saw last summer on my trip to Neah Bay was, in fact, a total trip measurement but one in which I was deliberately trying to see if I could achieve the fuel mileage I had been measuring with my FloScan. It included the start and warm up at the ramp and the idling out of the marina. The total time included three brief stops to urinate and there were two area where the water was way too rough to maintain my fast cruise speed. In spite of all that, I covered 200 NM with 60 gallons of gasoline. |
Tom W Clark |
correction: 120 NM on 60 gallons of gasoline. |
Tom W Clark |
posted 01-12-2008 11:37 AM ET (US)
quote: Carson, When I take the Revenge out for a spin and look at my fuel totalizer, or fill the tank of the gas station, I do not think of my motors as "sipping" the gas. That is why I have been so keen to try to maximize the fuel economy if I can. When I bought the Revenge 25 from the original owner it had Mercury aluminum three blade propellers. It appeared that it was always so equipped. The motors had also been mounted as low as they could be. The boat was capable of 45 MPH and got 2.0 MPG at best. The performance of the boat was not bad but once I started fooling with the props (mostly to see if I could find a way to claim bragging rights of a 50 MPH boat) I came to realize in a way I never had before through the ownership of over a dozen boats, that a propeller can have a really significant impact on the performance of a boat. Not only is top speed affected, but acceleration grip, and fuel economy as well. This is where I started to get really curious about propellers two years ago and I have had a lot of fun and learned a great deal since then. It is an area of interest I am trying share with others now. I still have two sets of propellers in my basement that I have yet to try on my boat so maybe I can still do better, but for the record, I am currently running 15-1/4" x 19" counter rotating MIRAGEplus propellers on my motors which I have raised one set of bolt holes. |
Peter |
posted 01-12-2008 12:40 PM ET (US)
Tom -- It surprises me that your boat's "optimal" cruising speed (25 to 30 MPH) and the motors' "optimal" running speed don't seem to intersect. Wonder if this has something to do with engine height and also possibly the toe-in setting (perhaps not enough for the slower cruise speed). Have you run the Mirage Plus at different engine heights? If so, what have you seen in terms of maximums for the different heights? |
Tom W Clark |
posted 01-12-2008 12:42 PM ET (US)
Peter, Why does that surprise you? |
Peter |
posted 01-12-2008 12:55 PM ET (US)
In all my experience, the two seem to come together. |
Tom W Clark |
posted 01-12-2008 01:32 PM ET (US)
Peter, I honestly do not understand your question. Optimal fuel economy is achieved at a speed and RPM where the most ground is covered for the least fuel consumed. On my boat this occurs around 35 MPH. Best fuel economy is an objective measurement. Prefered cruising speed is a subjective choice. The two have little to do with each other. I would prefer to have a power source that achieves its optimal fuel economy at a slower speed because here on Puget Sound the boat is more comfortable to be in at 25-30 MPH. Fuel economy depends on the motor, in this case the motor is most efficient at around 4000-4200 RPM and I think this is typical, is it not? The speed at which I cruise is dependent on the boat and the condition in which it runs. If it is smooth or rippled my boat is great at 35 MPH or more. Unfortunately, here on Puget Sound we have a lot of tidal current, wind and boat traffic, both commercial and recreational. It often is choppy and sloppy with waves coming from many directions at once. A Revenge 25 is not a smooth ride at 35 MPH in those conditions. This is also why I do not think the 25 foot Whaler should be powered beyond its 300 HP limit if fuel economy is of any concern, in fact the boat might really be happier with less power that achieves it best fuel mileage at a slower speed. |
Perry |
posted 01-12-2008 02:00 PM ET (US)
Tom, I assumed that 3200 RPM and 24-25 MPH was Dave's optimal cruise speed for fuel economy because that is where my motor is most efficient. You are probably correct in saying that he would have better fuel economy at 30-32 MPH like your motors. When I said your motors sip gas I meant relatively speaking. Maybe this 30-50% improvement theory will be put to the test when someone (you?) actually repowers with a new DFI or 4 stroke and compares the fuel consumption on the same hull. |
Peter |
posted 01-12-2008 03:08 PM ET (US)
Tom -- My simple observation from my Whalers over the years is that they tended to be comfortable cruisers in the 25 to 30 MPH range. Higher than 30 tends not to be so comfortable in a chop. Also, it's my simple observation from my various Whalers with different 2-stroke V6 motors that maximum fuel economy tended to coincide with about 28 to 30 MPH. All of these Whalers were powered to reach 45 MPH approximate top end give or take 1 or 2 MPH and as such in the 25 to 30 MPH zone (what I call the maximum cruising comfort zone) they were turning about 3500 to 4000 RPM (what I think is typically the maximum efficiency zone for most V6 2-strokes). So in trying to "size" the 2-stroke power for a classic Whaler V hull so the "maximum" efficiency coincided with the comfort zone, I've always tried to select motors capable pushing the boat in the 25 to 30 MPH zone while turning 3500 to 4000 RPM. So, if running lower than 3500 at 30 MPH, for example, I think there could be a case that the boat has too much motor and if running much higher than 4000 RPM at 30, not enough motor. Sort of fits with your notion of "the boat might really be happier with less power". Does that make any sense? Thus, in any case, I was just suprised to find that in your case that the maximum came at 33 MPH speed. I would have guessed it falling around 28 to 30. I was not thinking your boat had "too much power". |
Tom W Clark |
posted 01-12-2008 03:17 PM ET (US)
OK, now we are getting somewhere. In the discussion of fuel economy of old two stroke and new four stroke motors, what is the typical RPM where the motors are most fuel efficient? I have provided one data point for my boat. Maybe it is an anomaly. I can back up my data with solid documentation. I would like to see some other well documented data points showing where the best fuel economy is with different motors. Peter - Let's start with your current Outrage 18 with its Johnson 150 HP motor. Do you have some good Speed-RPM-Fuel Consumption data taken throughout the motors RPM range? What other boats have you owned that also have good data to go with them? Dave Buckalew (buckda) - Could you please join us here and share your data from before and after repowering your Outrage 18? Anybody else? This is a genuine request. Please share. |
WT |
posted 01-12-2008 03:35 PM ET (US)
Here's some mpg data for my 170 Montauk with Mercury FOURSTROKE "Veradito". 188.64 miles http://continuouswave.com/ubb/Forum1/HTML/015291.html Here's data on another trip with my 2004 90 carbureated Mercury/Yamaha. 1) 99.38 miles round trip Here's a trip with the FOURSTROKE. 1) Average speed 19.6 miles per hour. http://continuouswave.com/ubb/Forum7/HTML/000823.html I can probably get 8 mpg if I average 20 mph on a long trip. Warren |
WT |
posted 01-12-2008 03:39 PM ET (US)
The third trip was horrible water conditions. White cap conditions for about 15 of the total miles.
If the water is flat I can get 7-8 mpg going slow. Warren |
Tom W Clark |
posted 01-12-2008 03:59 PM ET (US)
Warren, Do you the data showing the fuel consumption rate and speed at different RPMs between planing speed and WOT? |
WT |
posted 01-12-2008 04:03 PM ET (US)
One more. http://continuouswave.com/ubb/Forum7/HTML/000797.html Trip data with 90 FOURSTROKE 1) round trip 191.96 miles |
WT |
posted 01-12-2008 04:07 PM ET (US)
Tom, no I don't but here is the BW performance information on the new 170 Montauks. Looks like they changed some of the data, top speed used to be higher and also mpg also used to show 8 mpg for the 90 FOURSTROKE 90. http://www.whaler.com/rec/pdfs/performance/6.pdf Warren |
Perry |
posted 01-12-2008 04:15 PM ET (US)
Tom, good idea getting some hard data to work with. When you plug in 47-48 MPH, 150 HP, 2600 lbs, for the Outrage 18 you get a hull factor of around 200. When I plug in the data for the 190 Outrage, according to Boston Whaler's test report, it predicts a hull factor of 205 which is fairly close to the Outrage 18. So I will enter the data from a prop test on my boat as a reference. I used a calibrated Navman 3100 Fuel and it was set on MPG. Speed measured by Garmin GPS. Performance of my BF135 Should be identical to a BF150 up until 4200 RPM when the BF150 benifits from VTEC. Boat:......190 Nantucket w/T-Top RPM.........MPH..........MPG Minimum planning speed:.18 MPH |
Yiddil |
posted 01-12-2008 04:44 PM ET (US)
I wonder what it would be for my 115-2 classic...with Das Boat....I can't remember but I thought it was like 3.5 mpg...am I that oof??? thanks, henry |
WT |
posted 01-12-2008 05:04 PM ET (US)
I'd like to see actual operating data for mpg. It's pretty simple, fill you gas tank, reset your trip odometer to zero, at the end of your trip fill the gas tank up and divide into miles traveled. I think you will be shocked at real operating mpg.
Perry |
posted 01-12-2008 05:40 PM ET (US)
Warren, I can reset my GPS before a single outing or let it go for any number of miles or hours and look at my fuel flow meter to determine real operating MPG but this discussion is about optimal fuel economy at cruise speed. |
tmann45 |
posted 01-12-2008 06:56 PM ET (US)
quote: Boat:......1996 Outrage 21 RPM.......GPH.....MPH......MPG Data between 2400 and 3200 is missing due to eratic RPM while transitioning to plane. |
cooper1958nc |
posted 01-12-2008 09:44 PM ET (US)
The problem with thinking about fuel efficiency is that from the numbers given it is impossible to separate the engine efficienty from the hull efficiency. The two stroke engine is a gas dynamic engine, and best efficiency occurs when the least amount of intake charge goes out the exhaust. This is not merely an RPM issue but is an issue of RPM and load. The hull has two kinds of drag: wave making (form) and frictional. Frictional goes up as the square of the speed, but is also dependent on the surface area in the water. Wave making decreases with the square of the speed above planing. The net result of the drag is a U shaped curve with minimum drag somewhere above clean planing speed but increasing after that. |
Tollyfamily |
posted 01-12-2008 11:30 PM ET (US)
I have been using the following estimates my entire life and is seems not much has changed. Outboard: 10% of the HP per hour for gallons used. 4000 rpm optimum. There is no magic with EFI, a carbed motor and EFI will have similar mixture and timing at optimum RPM. Any motor will have detonation problems if it is run lean or with too much timing. So maybe 10% better for EFI if it has a O2 sensor to control the mixture, the carb is probably jetted a little rich for extra insurance and maybe that’s why they are still running fine after 20 years like mine. We know that at slow speed the carbed engine wastes most of its fuel out the exhaust so there is potential for big savings if you troll or go slow a lot. I would love to have a shiny new motor but just can’t justify it until the old one goes boom. Dan |
Bulldog |
posted 01-13-2008 08:28 AM ET (US)
Tom, I'm a novice with this, but I think it would be interesting to see what happens when you play around with those props in your basement. I would think that a boat that gets the mileage you are and can run that fast would be the most efficent. Would changing prop size lower your cruising speed and raise the MPG? It sounds to me like you have two great engines dialed in pretty great already, you just have to keep the MPG while dropping off the speed, simple right? I get between 2.5 to 3 mpg in my little Revenge....Jack |
macfam |
posted 01-13-2008 09:44 AM ET (US)
Tom W. Clark, I find this discussion most interesting. Dan from Tollyfamily has given some estimates above(gph), but I'm not certain that his estimates are for maximun efficiency or average use, or full throttle. I also have some estimates that have proven very close over time, although never measured with the accuracy of a Flo-scan. I have always estimated that with 2-strokes, at maximum rpm was close to 10% of horsepower, and maximum efficiency was just about half at around 5%. The OX66 was super strong and never caused any problems, but if I were to re-power that hull, I would have leaned toward the Suzuki 250 or 300 with the larger prop and gear reduction. I think it would have been the most efficient available. |
boatdryver |
posted 01-13-2008 10:51 AM ET (US)
Tom W Clark, regarding your situation of having an optimal cruise speed so high, I just spent a few minutes on the Boston Whaler site looking at performance data for all the various engine options on the Conquest 205,235, and 255 models. It is interesting that with all engine options on the smaller 205 and 235 Conquest boats the optimal mpg occurs at boat speeds between 19 and 26.8 mph, a pretty big range. On the 255 Conquest the same is true till you get to twin 200 Verados. In that case there is a pretty flat band between 16 and 30 mph for optimal cruise. JimL |
Jordi |
posted 01-13-2008 11:58 AM ET (US)
Tom, My numbers are almost identical to the performance data on BW site regarding the 210 Outrage. On average 3.5 MPG cruising at 26 MPH at 3500 RPM. If the conditions are very poor and I have to use my trim tabs (100%) I drop to 3000 RPM at 20 MPH at 2.5 MPG. I too like to maximize the "comfort" of the ride when possible and the trim tabs although increase my MPG are a must for rough conditions. It sounds like you are trying to find the sweet spot between fuel efficiency and comfort ride. I too have observed like many on this forum that just because the hull is capable of slamming thru the waves the body will pay the price the following day. Jordi
posted 01-13-2008 12:04 PM ET (US)
Two factors influence the fuel economy; --the motor For two-stroke motors there tends to be a sweet-spot in the operating speed range where they produce power most efficiently. The 4,000-RPM range seems to be a common speed. Once a boat gets on plane it ought to operate at a fairly constant efficiency, and one would expect that further speed increases will require more power in a more or less consistent fashion. However, I believe there is another trend occurring in the hull behavior as speed increases. Generally in a planing boat as speed increases the wetted surface decreases. This should reduce drag. With the Boston Whaler classic v-hull, it seems like some configurations of engine and propeller can lift the hull farther out of the water while on plane than others. The more hull out of the water the less hull drag. So we see a trend where the HULL FACTOR may tend to increase with increasing speed. This may account for Tom Clark's observation that this optimum fuel economy occurs at a relatively high speed. The two factors, engine and hull, are aligning at 4,000-RPM. |
Peter |
posted 01-13-2008 04:06 PM ET (US)
Tom -- I don't have a fuel flow gauge on the 18 Outrage yet and I don't have a fuel consumption curve (GPH v. RPM) for the 2003 Johnson 150. I intend to put a fuel flow gauge on the Outrage this Spring so I should be able to develop a fuel consumption curve from that. The 1985 1.8L Johnson 140 V4 (I suspect this motor was about 125 HP) that I recently removed from the 18 Outrage had to run between 4250 to 4500 to reach 30 MPH. Much too busy for my liking and probably past the optimal fuel efficiency point for that motor. In contrast, I can run the 2.6L 150 at 3700 RPM or so to get the 18 Outrage moving 30 MPH. I had a fuel consumption curve for the Yamaha Ox66 225 that I had on the 22 Revenge which was confirmed by a friend's Yamaha Fuel Management gauge for his Ox66 225. It's been more than 4 years since I've had that boat so I'm not sure what I've done with the curve but distinctly remember that 4000 RPM was the inflection point on the curve for that motor where fuel consumption starting going up significantly per RPM. I recollect a little over 9 GPH at 3500 and about 11 GPH at 4000 RPM for that motor. Best fuel economy occured in the 3500 to 4000 RPM range which coincided with the 25 to 30 MPH "comfort zone". The Revenge had a top speed of 44 MPH at 5400 RPM. The 27 Whaler WD with twin 225 Fichts has a Navman F3100 fuel flow gauge. I haven't recorded data at all the RPM points but can tell you absolutely that the best fuel economy (approximately 1.4 MPG) occurs at 29 MPH (4000 RPM). With that big MPG readout, you can't ignore the economy, its staring you in the face all the time. The cruising "comfort zone" for the 27 Whaler is about 27 MPH (3750 RPM) to 31 MPH (4250 RPM). Top speed is 45 MPH and the Navman indicates just slightly over 1 MPG at this speed (44 GPH). So just by the "seat of the pants" feel, for my Whalers powered with 2-stroke V6s to reach the 45 MPH zone, the 4000 RPM point seemed to be the point where fuel economy and comfort started dropping off together. Thus, I rarely ran or run any of the motors above 4000 RPM and they all seemed to be quite at ease with that. |
mikejoyce77 |
posted 01-19-2008 06:45 PM ET (US)
I once had a 1984 ELPTO 75 mercury outboard (4 cylinders) on a 15 ft whaler. I just purchased a 50hp nissan tldi. What do you think the difference in fuel would be. I'm hoping it will be a big difference. |
posted 01-19-2008 07:42 PM ET (US)
Mike--The older Mercury and the new Nissan are both two-cycle motors, so they don't quite fit into this discussion comparing older two-cycle motors to new four-cycle motors. However, the Nissan is a direct-injection two-cycle, and in general the fuel economy of direct-injection two-cycle motors is on par with most new four-cycle motors. The very best of the new four-cycle motors tend to get better fuel economy than the two-cycle direct-injection motors. But with that in mind, everything already said will apply to your situation, viz., you probably will see about 25-percent to 45-percent improvement, a slight revision of my earlier estimate by downgrading by 5-percent the amount of improvement because of the two-cycle to two-cycle comparison instead of a two-cycle to four-cycle comparison. The fuel efficiency is not tied only to the motor, but it is quite complex. If the new motor weighs more, its weight works against improved fuel economy. If the new motor is not fitted with the optimum propeller, it works against improved fuel economy. If the overall combination does not put the motor into its most optimum operating range, it works against improved fuel economy. There is a general feeling that the brake specific fuel consumption of a motor is not constant, but, rather, the specific fuel consumption changes slightly as a function of the operating speed of the motor. It is widely recognized that specific fuel consumption tends to be best around 70-percent to 80-percent of full operating RPM. For example, Tom W Clark says his motor produces the best fuel economy at 4,200-RPM. If we can guess that his maximum engine speed is about 5,500-RPM, then 4,200-RPM is about 76-percent of full throttle, or right in the middle of the range suggested as being the optimum specific fuel consumption. It may also be that this engine speed gives a good boat speed and puts the propeller into spin at a rate where its efficiency tends to peak as well. And the hull may contribute to the improvement, too. Perhaps the hull generates enough lift at this speed to reduce the wetted surface, resulting in less drag. So when you ask us to predict the results, it is really quite a difficult problem, and no one can give you a very precise answer. |
Tohsgib |
posted 01-20-2008 11:14 AM ET (US)
Actually since you went from a 75 to a 50TLDI you can dismiss most of what jim just told you. You will probably cut your GPH in half, probably more. That 50 should burn about 2gph at cruise. The 75 probably did over 5. |
posted 01-21-2008 09:40 AM ET (US)
Nick--Yes, I didn't realize the question was even farther off topic because of the very large difference in horsepower involved. Fuel consumption is proportional to horsepower, so if you reduce the horsepower by 33-percent, the fuel consumption will be reduced proportionately. Proposals to reduce the horsepower of the engine used on a boat now leads us to a different topic, again, which is whether running a smaller engine near maximum is as efficient as running a larger engine at a lower speed. This really is a completely different discussion, as it involves determining the change in specific fuel consumption rate with engine speed. It's a good topic, but just not what is being discussed here. |
