Topic: 15-foot Boston Whaler in Ocean Seas
mikejoyce77 |
posted 02-03-2008 10:38 PM ET (US)
I'm planning a trip in the juan de fuca islands in British Columbia, Canada. At times weather can get pretty bad. [What is the maximum] swell and wave that a 15-foot Boston Whaler boat can handle? I know that a [Boston Whaler boat] is an ocean boat, but to what degree? I also understand experience on the water will play a big role. What is safe and what isn't? Thanks. mike
Binkie
posted 02-03-2008 11:51 PM ET (US)
There is no definite answer. Maybe if you have to ask, you should`t ask and get some more experience.rich |
Chuck Tribolet
posted 02-04-2008 02:15 AM ET (US)
Depends on the height and interval. A short swell with a short interval can really suck, a tall swell with a ling interval can be OK (unless you are diving, or trying to get the boat on the trailer).And it depends on the protection. Islands usually have a sheltered side. Chuck
Roarque
posted 02-04-2008 06:27 AM ET (US)
I used a Sport 15 in the gulf islands for one year (2004) before purchasing an Outrage 18. I have used the 18 in the Straits of Georgia for three years. The 15 could handle a five foot swell but you spend your entire voyage feeling stressed. The 18 can handle the same five foot swell and you are relaxed. This is from a BW Sport 15 user of 20 years experience. Hope this helps you decide. |
boatdryver
posted 02-04-2008 10:33 AM ET (US)
Mike I am assuming from your first post that you already have a 15 footer and are not asking advice on how big a boat you need for this trip. I've done a great deal of cruising in the Inland Passage and Gulf Islands and I would say you can have a lot of fun and be safe with a 15 footer if you use common sense and be careful. With so many Islands so close together there will be countless pretty places to stay out of trouble with a small boat. Until you get that experience you mentioned, just avoid the many wide passages where strong tidal currents opposed by strong breezes can turn safe water into a death trap in 30 minutes. Don't underestimate the Strait of Juan de Fuca and the Strait of Georgia. And carry a waterproof chart on board; its easy to lose track of where you are with so may little inlets passages between so many islands. That is one the of the things that makes the area so beautiful. You'll have a great time. JimL |
kglinz
posted 02-04-2008 12:48 PM ET (US)
There are a lot of areas you can go to in the Gulf Islands or around the Mainland of BC using a combination of Ferries and waterways. I see you are from BC. Whats is your Homeport? Where are you planing to go? One of the most important things is to allow plenty of time, so if it's rough you can wait out the weather.Kemp Lindsey |
4whaler
posted 02-04-2008 12:51 PM ET (US)
A classic 15 will stuff its bow into a steep swell in a heart beat, especially if not on plane, if the intreval between is short or the swell doesn't have enough slope to lift the bow before the front gets to the wave. Dead on of plane is the worst approach you will submarine it and turn into the worlds larges diving lure unless you pull power off or hit it to raise nose. IF its a big wave you will fill the boat up to the gunnels with water. You won't sink but it will scare the hell out of you. Been there done that....(more than one time) Also make sure everthing is lashed down or it will wash out the stern when you do hit power to get the water out. The main reason for this is the sharp nose and the real lifing part of the bow is so far back compared to other boats. Any thing over three feet is a potential problem if you have to come off plane. It will take chop up to that hight in stride as long as you keep it on plane. |
Tohsgib
posted 02-04-2008 01:24 PM ET (US)
Main issue is WHAT 15' are you referring to? There are classic 15's, Dauntless 15. Rage 15, and 150 series(sport or montauk).If a classic 15, I agree with the above, I have stuffed the bow numerous times on mine. |
pglein
posted 02-04-2008 05:01 PM ET (US)
I'm a little confused. I'm not aware of any group of islands called the "Juan de Fuca Islands". I'm familiar with the Straight of Juan de Fuca, and the Gulf Islands, as well as the San Juan Islands.So, you'll need to clarify a bit. If you're talking about boating in the San Juan and Gulf Islands, I think a 15' is well suited, so long as you carry charts and keep a weather eye. If the chop picks up, you may find yourself ducking for cover. Winter is best to avoid. If you're talking about crossing the straights, either Juan deFuca or Georgia (or Haro for that matter), I think you need to be careful. On a calm day, it would be a fun, but rather boring, ride. But don't let clear skies fool you; a stiff breeze can kick up quite a swell out there in not a lot of time. The 15' can handle most of what the straights can dish out, if the operator knows what they are doing. I highly recommend a chartplotting GPS and a pre-determined route. VHF is a must-have in that area; first for monitoring for commercial traffic, second for calling for help if you get in trouble, and third for checking weather reports. I say the GPS because, I find plotting a triangulated position on a paper chart in a boat that size to be difficult, even when the water is flat. But when you get out there and the swells are rolling, it's damn near impossible. You'll have to stop to do it, which will cause the bow to swing around downwind, which will cause the swells to start coming over the stern. Not safe by any measure. But you can definitely get out there and lose your bearings, especially if there's a swell running. So you need to be able to know your position and heading, or you can get into real trouble. As for exactly what size swell a 15' will handle, it all depends on your speed and skill. To be honest, if you're careful, and know what you're doing, it'll handle anything you throw at it. Of course, you'll probably get very wet in the process. I know from experience, that going too fast in large swells can cause real problems, as the boat hops off the top and crashes into the next wave. |
Dave Sutton
posted 02-04-2008 05:56 PM ET (US)
Basic heavy-weather advice for the 15/16/17 foot Whaler: If you run it slow... it'll handle lots more than the people aboard can. You'll be BEGGING to get off long before it's unsafe. Just go slow... and be ready to use the throttle a lot to climb up the swell faces and to coast down the backside. You'll be soaked... just part of life. If you bury the bow (which one day you will), just use a little throttle to raise the bow, run it out over the transom, and let the pump do it's job. If you ship water more often than "ocassionally", think about just pulling the plug and she'll keep herself dry enough for safety and relative comfort. Wear good rubber soled shoes, and don't hesitate to buy one of the rubber helm-pads for underfoot: You can bruise your feet pretty badly after a few hours of this. Wear a self inflating life jacket (all hands) and use the engine shutoff lanyard even if you have another person in the boat. With murphys law, if one of you gets pitched out, both will. Think about self-recovery techniques, IE: "How do I get back aboard from the water". I leave a loop of line snapped to the lift-ring on the inside of the transom with a rubber band of inner-tube rubber holding it as a bundle. I can reach into the boat from the water, drag it overboard, and pull it free to make a foot-loop to climb back in. Costs little, might save your life. I've had 15's and 17's in short period 6-8 footers and been OK... not happy, but safe. I've had them in long period ground swells of 8-12 feet and it was FUN!!! Dave
Nails
posted 02-04-2008 08:25 PM ET (US)
Dave Sutton:That was a great reply and I hope it is as helpful to Mike Joyce as it is to me. I almost buried my 150 last summer in the Pt Pleasant canal here in NJ and it was an uncomfortable 30 seconds or so until we cleared the disturbance (big boats, big wakes, narrow canal - my nerves were a little frayed, but no other damage to report). I hadn't thought out my recovery techniques to the extent you have, but will be more aware of those options now. Thanks - Tom H |
posted 02-04-2008 09:43 PM ET (US)
A 15-foot boat is suitable only for near shore use and in calm seas. To imagine otherwise is to seriously over estimate the capabilities of a 15-foot boat. |
deepwater
posted 02-04-2008 10:14 PM ET (US)
You have to weigh your experances on the water by the strenght of your faith in your boat,, your boat (whaler) will never let you down,,will you try to keep your boat as safe as it will keep you ,,your whaler will always bring you home (if you can hold on),,will you always bring your whaler home ,,you are the weakiest link in the boat chain here ,, |
Plotman
posted 02-04-2008 10:30 PM ET (US)
I've had my classic 15 out in short interval steep waves on Lake Superior that were an honest 6 feet (At the helm of my 22 that same day, I would loose the horizon most every wave, and I'm 6'5"). It was not fun, and I got quite wet, but I was able to keep the bow trimmed way up and quarter into the waves reasonably well at a slow plane. I never stuffed seriously stuffed the bow, but I did takes some green water on several occasions. When I could turn downhill, that was a piece of cake. I just kept it on the backside of a wave, or went just a tisch faster than the wave train. At idle, it was uncomfortable, but in no way felt unsafe. The pucker factor was quite high initially, but I did get a sense for the boat pretty quickly. It would have been exhausting to do it for more than an hour or so. I only had 6 or 8 miles to go, and was quite glad to pull behind the island when I did. David |
mikejoyce77
posted 02-04-2008 11:33 PM ET (US)
hey guys, good advice.I will be prepared for my trip in the juan da fuca islands. I have installed a bilge pump with an auto float switch in the back sump. this is if any water comes in the boat, i can remove it quickly. I also have a gps. I do know how weather can turn in an instance. kemp lindsey, I'm still in the process of planning the trip. not sure what islands i'll visit. any advice will be greatfull. will be going the first week of august mike |
Dave Sutton
posted 02-05-2008 10:13 AM ET (US)
Nails, thanks for the reply. I run that canal too... and it can be 'interesting'. As someone who regularly runs these in an environment where we fill them "to the brim' on about one out of three trips, spearfishing in The Race (HUGE rips between Connecticut and Long Island), let me comment on this: " I have installed a bilge pump with an auto float switch in the back sump. this is if any water comes in the boat, i can remove it quickly." If you REALLY think you might fill one of these up, NO PUMP that fits in the back sump is large enough.
Think this over for a second: Do I need a larger pump in my 42 Grand Banks, or in my Whaler? Answer: In my Whaler. In the 42 footer, I am only likely to be able to take aboard whatever water comes in thru a broken hose until I get the seacock closed, and (literally) 5000 *gallons* of water in the bilge is a drop in the bucket. I carry 1000 gallons of fresh water in tanks, another 1000 gallons of diesel, and her waterline full of fuel and water or empty changes about 3 inches... The bottom line is that I can pump 5000 gallons out at leisure. In the Whaler, I can re-fill the boat continuously in a really heavy sea state, and 500 gallons of water there is FULL. You want to be able to get it out NOW. No, the boat will not sink if filled, but it becomes a WHOLE lot less stable. We have rolled them over more than once. In my experience, we have (3) different levels of dewatering a Whaler: (1): RUNNING IT OUT: When we take a hull full of blue water aboard, the first thing we do is to head the boat 'uphill' and accellerate the engine to SLOSH the water over the transom. This is where having sufficient power is essential. Yeah, you can plane on 40 horses... but can you accellerate with a hull full of water? In rough seas it might mean your life. (2): CRASH PUMP it out. In our boats, we mount a 1500 GPM (yeah, one thousand, five hundred gallons per minute) pump on the deck in one of the aft corners with a float switch. This is for GROSS DEWATERING, and it only comes on if there is more than about 2 inches of water in the hull. Generally if we take blue water, this pump will trigger for 10 seconds or so, and when it quits, we're just 'damp'. (3) FINISH THE JOB. This is where the 'little pump' in the rear well comes in. It finishess the job, and is the pump that keeps her dry under "normal' use. Rainwater, spray, water from the kids swimming and coming aboard, etc.. that's what this pump is for. This system works, and it works well. I am often amazed at the tiny pumps that folks mount in their boats. The smaller the boat, the bigger the pump: I can ignore 500 gallons of water in my Trawler, but 500 gallons in the Whaler in rough seas needs to get gone NOW.
Best,
Dave |
kglinz
posted 02-05-2008 11:35 AM ET (US)
Gee Dave, you you must have the optional tanks in your GB. You carry about twice the normal fuel and four times the normal water. |
Sal DiMercurio
posted 02-05-2008 11:46 AM ET (US)
Dave, I believe you mean a 1,500 gallons per hour, not minute. Not even a 1" jabsco turning at 3,000 rpms mounted to a pulley on the engine, can get rid of 1,500 gallons in 1 minute. When I commercial fished Alaska, the biggest commercial electric Rule pump we could get, was 2500 gph.[ gallons per hour ], I had 6 of them in my bilges, plus 2 - 1" jabscos on the engine, plus a whale gusher pump for backup. 1,500 GPM means moving 7-1/2 - 50 gallon drums of water, through a 2.5" fire hose in 1 minute, I don't think so. The exhaust end of the hose coming off a 1,500 gpm hose, could be used to propel the boat like a pump [ jet ] boat. Sal
Tohsgib
posted 02-05-2008 12:20 PM ET (US)
Again...what 15' are you talking about?A 1500 Rule is only about $20 more than a 500gph and about the same size, go with a bigger one. Fill the boat up a couple inches while on the trailer and see how long even a 1500gph one takes. You can drink a beer while waiting. |
pglein
posted 02-05-2008 01:40 PM ET (US)
Bilge pumps on small boats are for preventing rainwater from accumulating in the boat while moored, not for evacuating water taken over the side or bow. That's what the drain plug is for. |
Buckda
posted 02-05-2008 02:36 PM ET (US)
Evacuating lots of water over the transom is what a transom notch is for.Having owned a classic 15' Sport (1989) and used it on the Great Lakes, I can concur that you may wish to consider a larger Whaler...perhaps a 17' Montauk or other 17' model (the Newport is nice for touring with folks aboard). My 15' would indeed have a tendency to "stuff" the bow when idling into the face of steep waves. It made trolling on Lake Michigan nearly impossible in anything over 3' chop, unless you really wanted to get wet. I pushed my 15' Hull further than I probably should have - running across the North Channel of Lake Huron (60 miles of open water) in 2003 or 2004, but after that trip, I realized I needed a bigger boat, and began my search for a nice 17' Montauk or 18' Outrage. I found the Outrage and believe it is one of the most capable "coastal" Whalers around - meaning it can venture offshore in moderate conditions and handles big bays and big inland lakes well. There are still days on Lakes Erie, Huron or Michigan that I've yearned for a few more feet at waterline and had the headache when I got home to remind me that it's still an 18' boat. Regarding dewatering a boat in rough seas, I agree with the above posts. My 18' Outrage has a 1,500 GPH pump in the splashwell, and a second 1,000 GPH pump in the sump...but when I'm in the rough stuff, I simply pull the plugs and let the spray and any green water (when in the REALLY rough stuff) flow out as it comes in. To date, I've not yet stuffed the bow and put a tremendous amount of water on deck - but I'm confident that with 180 HP and a big transom notch, I can evacuate the majority of that water in short order and let the open drains do the rest via the venturi effect. |
Dave Sutton
posted 02-05-2008 04:46 PM ET (US)
Yup.... simple math baffles the common test-pilot, it's a 1500 Gallon Per *hour* pump... duh!Yes, the 42GB has custom tanks, new stainless ones. Basic fuel on them is 600 Diesel and 300 Water. I set this one up for long distance cruising in the Carribean, using saddle tanks, and I'm* never* gonna change those damned things again (or buy water in the islands for more than the cost of Diesel)! Once is enough on changing tanks. The difference in seakeeping between a 15 and a 17 is 'noticable', but each will take more after the folks aboard have said "Holy CRAP!" for the 1000th time.... Tell you what, though: It's confidence inspiring to stuff the nose, take a few hundred gallons of green water aboard, and see how the boat handles it. Take a lot to get the bow under, with the flare they have decent reserve bouyancy, but it can be done. We've also taken green water over the transom while holding position to bring a diver aboard... and again, seeing how the boats behave is really awesome. These things are safe..... just do like my Grandpa taught me so long ago when he said "Son, Never turn your back on the Sea..." Dave ============================================== "Toll the bell, call up the ghosts, summon out the lifesavers and the pirates.The shoals are there still, the winds howl loud, the rain beats down, the waves burst strong. Some night, in the chill darkness, someone will make a mistake: The sea will show him no mercy". |
Whalerdog
posted 02-05-2008 05:41 PM ET (US)
I agree with Binkie you need to know your boats limits and your limits it's always the weakest length is it you or the boat? Fun for some is a scary horrible ride for others. |
sapple
posted 02-05-2008 06:42 PM ET (US)
Holly S**T !! I can't believe what some of you guys do !!Being a relatively new power boater I got flustered this summer the one time I took about 3 gallons over the bow of my Sport 130 from a boat wake. It sure is reassuring to hear what these boats can really handle. Its also extreamly helpful to hear from the experienced skippers what to do if I end up taking on some real water. Thanks for sharing your experience to help us newbies learn... not the hard way. |
Dave Sutton
posted 02-05-2008 09:03 PM ET (US)
If anyone wants "Confidence Lessons" in the Northeast, I give private seamanship tutoring up here anyplace between NJ and RI. The rips in Long Island sound are a great place to get your feet wet (literally), so come on and play. Your boat or mine. Dave
WT
posted 02-05-2008 09:14 PM ET (US)
Boating in rough waters in a 15 foot Whaler, especially in the seated position, is a glutton for punishment.The waves looked bigger while seated! :-) Warren |
prxmid
posted 02-05-2008 10:53 PM ET (US)
I bekieve JimH is correct, owning a classic 15 and a newer 18, Rough open water is no place for the 15. Just because you make it doesn't mean it's prudent.Now the 18 is a whole nuther story |
jgkmmoore
posted 02-06-2008 04:58 AM ET (US)
If you remain IN the San Juan group of islands, there is almost always a safe cove or protected area where you can take refuge. In the 15 tho, you just have to consider the wind very carefully, and get where you are going before it begins. Usually, noon to 1 pm in the summer months, a riffle gives you a heads up. PAY ATTENTION. GIT!. And then hide for the rest of the day.Anything more than 10 mph wind will give the 15 a challenge in the more open channels,and especially the Straights of Juan de Fuca,Georgia, and Rosario. Remaining between the centrally located larger islands in the smaller waterways is the best way to enjoy the islands anyway. San Juan Channel (east of San Juan Island)can be beastly with a short chop in 10 knots wind and the hinky currents, and the passage between Speiden Isl and San Juan on the way into Roche can work up some very confused water in certain combos of tide/wind. It takes a few years to figure out where the anomalies are unless you spend hours with someone that has cruised there for years. It's all just like Deception Pass....flat as a board one time, and the next time you're taking your life in your hands in any size boat. Do your running in the mornings, and plan on getting on the anchor (or dock/buoy) no later 1 pm. Do carry a spare prop. Carry a map that shows obstructions....and READ IT before you start the motor. There aren't many deepwater rocks that you can hit with a 15, but you WILL FIND ONE if you use an oil company roadmap. I have pushed every Whaler size from the 13 to the 21'Outrage around this area, and find the 18 Outrage I have now gives me the dryest ride.Most exciting, was surfing a HUGE following sea in the old 21...phenominal speeds, but 'hair fine' steering was absolutely necessary to avoid a broach or pitchpole. Not for the weak of heart (I was much younger then). You can do the Gulf Island group all the way from South Pender to Nanaimo in the 15....in one day if you want, and in very nice water almost all the time.Gas 'er up!(In the US)..much cheaper than your gas. |
jgkmmoore
posted 02-06-2008 05:21 AM ET (US)
*******This is NOT a suggestion to anyone**************** And I don't have a cavalier attitude about this. I never have had a dewatering device in any of my Whalers. I ran 'em all, especially the 15,with the plugs out all the time. I don't even carry plugs in the boat. I have dewatered from 'swamped' conditiion in all but my 13 footer, and they all have been fine.The 15 was the least stable of all with a load of water aboard, and the '86 Montauk wanted to roll if you turned while throttling up. I tested all the boats in shallow, warm summer (freshwater/warm) conditions the first time, to get the feel for the handling.While it's not fun, I highly recommend trying it before you ever test your boat in threatening weather.Doing the same thing in wind and ice cold water would be a whole different thing.Trying to pull any of the Whaler plugs with freezing hands in heaving seas, in a swamped boat is not any fun at all.Trying to pilot any of the boats while swamped, is really pucker time. |
sapple
posted 02-06-2008 09:03 AM ET (US)
jgkmmoore, when you say the 15 was the least stable of all in swamped conditions does this apply equally to classic and new 15s ? |
Dave Sutton
posted 02-06-2008 09:12 AM ET (US)
Prior Post is right on regarding the plugs. Plugs are "impossible to get to and remove" when they need to come out. LONG before you think they ought to come out, they need to come out. I do carry them, and use them for nice days. I also use the "flip-over" type and not the "screw down the "T" handle type" and make a loop of BRIGHT ORANGE line thru the flip-lever and lead it out of the well so the line can be grabbed and pulled to yank the plug if needed. "Hey YOU.... Pull that orange line like your life depends on it, because it does" is sufficient instruction for anyone, as opposed to "Hey YOU.. kneel down there and grope into the 8 inches of cold water and feel under the pump and wires and all that crap and see if you can feel a little "T" handle... now loosen it, and try to yank the plug out..." Good luck. I also carry a cut-off window washing fluid jug made into a scoop-bailer for (1) bailing, and for (2) bringing onboard salt water to scrub down the boat (think fish blood, etc). Really, you can get a LOT of water out FAST with one of these. Like Grandpa said, "There's no bilge pump like a frightened man with a bucket". Mine has a dog-snap on it, and it snaps to one of the steering cables and is there 100% of the time. Makes a handy piss-pot too in windy weather (and is nice and flexable for "her" to pee in too). Stability of a flooded boat is marginal, and we have capsized one 17 Montauk while boating a large fish (one diver hanging on the rail, and two guys on the same side lifting a 40 pound fish over the rail in a beam sea). Yeah it floated "as advertised", upside down. We were able to right it, restart it, and get home. Didn't do the electrics any favors. Dave Sutton
Whalerdog
posted 02-06-2008 06:10 PM ET (US)
Dave Sutton we need to ride around together for some wave riding, I think it could be fun. I'am in Freeport.john |
jgkmmoore
posted 02-06-2008 06:32 PM ET (US)
Sapple- No. Never had or tested a Dauntless.Sorry for not mentioning: mine was a 1983 sport w/Stinger 75.Dave S- I like your idea of the cords on the flip-top plugs. I live in Seattle tho, and would probably have to go with colors like mauve, or avacado. Cool.We ARE GREEN up here, dontcha know? And, yer Grampa sure had his stuff together about the 'bailer'! I forgot I had one...it lives in the anchor locker area. Your idea is a lot better...I'm going with the dog snap in the back of the boat. I saved the price of a Porta Potti by using that thing.Women will always use it when their bladder is about to burst, and then commend the thing for being reasonably comfortable. Good for fish guts during cleaning too. When buying an electric bilge pump,be sure to get one that claims to pump TWICE (at least) what you need.Their real capacity is normally about half their advertised capacity. Caution: The 'floppy arm' type pump switch will, sooner or later, kill your battery by getting stuck 'up'. They will also sink your boat (if not a Whaler) for the same reason.If you have to drive any length of time to get to your boat, a dead battery will certainly jerk your chain. I believe pglein said it right....pumps are to get rid of rainwater, not to save your boat in threatening circumstances. |
DeeVee
posted 02-06-2008 09:52 PM ET (US)
20+ years ago I used to take my 15 Striper across the Wesport, WA bar and fish salmon with at least one other person on the boat with me. It was only done in good weather. Even in good weather, one felt like he had just had a really good physical work out once back on the beach. I never felt unsafe while in the 15, but always was respectful and watchful of weather conditions. Doug |
pglein
posted 02-07-2008 05:51 PM ET (US)
I'm still not clear on where this guy is wanting to take his boat. The San Juan Islands? |
mikejoyce77
posted 02-07-2008 09:39 PM ET (US)
hey guys,The bilge pump that i'm putting in the 15' whaler (classic) pumps 900 gph. I feel that this pump is enough for what i need. I take caution at all times with weather. For those that don't know where the Juan de fuca islands are, they are locted in British Columbia, Canada. off the inner coast of Vancouver island. All your ideas are helpfull. I'm hopping for sunny skies and calm seas. |
