Source for Seat Cushions, Drain Tubes
ktval
Postby ktval » Mon Mar 27, 2017 5:50 pm
Hello everyone. I [want] to replace the seat cushions in my 1992 Montauk 17 and the main drain tube. Please tell me where i can find these to purchase. Thank you.
1995 Montauk 1995 Merc 90. Port Jefferson and Greenport NY
Re: Source for Seat Cushions, Drain Tubes
Postby jimh » Mon Mar 27, 2017 10:49 pm
You can find recommended sources for upholstery and drain tubes in the REFERENCE section. Read the article
Original Equipment Manufacturers and
Recommended Vendors
http://continuouswave.com/whaler/reference/OEM.html
The article is listed in the TABLE OF CONTENTS of the REFERENCE section under the heading OEM PART SOURCES.
Postby jimh » Mon Mar 27, 2017 10:50 pm
The degree to which owners of MONTAUK 17 boats use downriggers is a good topic for THE GAM. Please use THE GAM for topics like that.
I do not believe that outriggers are the same as downriggers, but since I am not much of an angler, I might be mistaken. Either would be good topic for THE GAM.
ktval
Postby ktval » Tue Mar 28, 2017 2:35 pm
Jim--I am sorry however i do not see anything about drain tubes.
Re: Source for Seat Cushions, Drain Tubes; Frequency of use of Downriggers with MONTAUK 17 Boats
Postby Phil T » Tue Mar 28, 2017 5:42 pm
There are dozens of threads on techniques to replace the tubes.
Here is one:
http://continuouswave.com/ubb/Forum3/HTML/000062.html
As for suppliers see FAQ #12:
http://continuouswave.com/whaler/reference/FAQ/#Q12
Then contact either
Sue Lodel, Parts Manager @ Beacon/Twin Cities Marine
http://www.beacontcm.com
- or -
McCarr Master
https://www.mcmaster.com
Postby jimh » Wed Mar 29, 2017 7:27 am
Sorry--for advice on replacement of drains see the FAQ.
ktval
Postby ktval » Thu Mar 30, 2017 11:10 am
Thank you everyone !
